 electrical issues
johnfaze
bushkill pa
6-21-2009
  electrical issues
hi. i have a problem with the windshield wipers cutting out in the rain.the fan motor cuts out at the same time as does the side power mirrors. any idea where to start looking? its a 93 j30. thanks
driverdriver
NICO's longtime resident Canuck!!!
Toronto, Canada
8-1-2003
Sounds almost fuse related.
Here's the section of the FSM that will be of interest to you:
http://www.nicoclub.com/FSM/J30/1994_J30/el.pdf
Currently in the Garage:
Daily Driver: Acura EL
Daily Driver: Saab 9-5 2.3t Aero Sportwagon
Spring/Summer/Fall Screamer: '94 Infiniti J30t gold package w/HICAS (10+ years of ownership and she still looks&runs like day one!!!)
yodawill2000
94 Infinti J30
Grand Prairie Tx
3-24-2005
Only happens in the rain ??
Sounds like a uninsulated wire somewhere.
94 J30 w/180 K miles
Dark green and sexah !!!
johnfaze
bushkill pa
6-21-2009
 « Re: (yodawill2000)
thanks guys. i was also told to check for clogged/leaking drains from the sunroof. hope its not too bad.
driverdriver
Toronto, Canada
8-1-2003
To clear clogged sunroof drains, use canned air(the type used for clearing computer keyboards). The drains are in the front corners of the sunroof frame. Spray air gently into them, don't force it. The drain tube gets delicate with age.
salaguinto
1993 Infiniti J30
Budd Lake NJ
6-23-2009
 « Re: (driverdriver)
Speaking of fuses, reason I was scanning this forum was I was looking for discussion on a specific electrical problem - while driving home, my dashboard lights all went out (all dashboard gauges, heater/ac/console background or outline lights - although the heater/ac display is ok and radio is aftermarket so its still on) and my headlights are stuck on high-beam.
Tried looking for similar discussion until I got to page 12 and didn't find any. Any thoughts? Thanks.
yodawill2000
94 Infinti J30
Grand Prairie Tx
3-24-2005
Sounds like the dimmer switch over on the left of the steering wheel.
Give it a good SMACK and see if they come back on.
If so you have a cold solder joint on the connector or the switch is bad.
The headlights thing may be the headlight relay
in the engine bay.
Common problem on the J's.
http://www.fuzzycats.com/docs/headlight_relay.pdf
» Return to J30 Forum / M30 Forum
