Okay guys, I normally figure s*** out on my own, but this is bugging me!ESPECIALLY since I have an aftermarket alarm system installed.
When I lock the doors arming the system, the rear doors do not lock, as if the solenoids are REALLY weak. When I disarm the system, they will not unlock, if manually locked. It just doesn't seem to have the power to unlock?
Anyone else having/had this issue? What did you do to resolve it? I had removed the door panel from the driver side rear door, and sprayed a bit of WD on the lock mechanism itself, but not on the lock motor or door latch assemblies.
I'm going to try it tonight, but want to know what others have done to fix it.
Thanks!
'98 200sx SE-R - 411whp @ 11psi = WTF was I thinking?!
'05 Armada - Tow Truck with style
