12 Volt Resource cd rom
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
noonooJAY
Car: 2005 QX56
Does anyone have or know where I can get the 12 volt resource Nissan & Infiniti Mobile Installation cd rom? Or even the one for all vehicles? I did some soul searching and found that at one point it was available for free download via rapidshare, media-fire etc. I really dont want to pay the 14.95 as shown here:
http://www.12voltresource.com/...=1017
I'm trying to find A good 12 volt source in my QX to tap into for my illuminated door sills. Something along the kick plates would be perfect.
dx3
Car: 2006 Infiniti QX56
Do you know how to use a Voltmeter?
Jonny
noonooJAY
Car: 2005 QX56
haha yah funny thing is i just bought one but do not know how to use. do you know what setting it needs to be on ? i.e dc or ac, 2.5 or 50? jeez im so clueless right about now.
dx3
H
noonooJAY wrote:haha yah funny thing is i just bought one but do not know how to use. do you know what setting it needs to be on ? i.e dc or ac, 2.5 or 50? jeez im so clueless right about now.
Hey man,
All part of learning. I am sure everyone does it differently. I believe I set mine to 20v but am not 100%. To verofy you are doing it right, set it to 20v or 50v and put the pos+ (red) prong on the positive battery post and the neg-(black on the negative post. You should get a reading of 12v +/-. Now you know it is working.
So on the basis you are still trying to wire in your kickplate. Turn your key to ACC. Under the drivers and passenger seat are the footwell lights. I am not sure how much juice they have running to them. So stab the pos+ prong into each wire in the plug for these footwell lights one at a time, while grounding out the black prong. You can ground on anything that is metal (not painted.) Once you find something giving you 12v, that should be an accessory wire. Try turning the ignition all the way to off to verify and make sure that is an accessory and not a constant. If it stays at 12v it is a constant. If it goes to 0 then it is an accessory.
Hope this helps. If you are not good with wiring/soldering I would suggest visiting Waytek and getting some solderless connectors.
Regards,Jonny
noonooJAY
Car: 2005 QX56
Hey Jonny,
Thanks for the detailed information, that's the best information I've got out of all the forums i frequent. As for the solderless connectors, I'm going to look into that. I already made some connections with the grounds to the door switches via "t taps". I hope those are okay. Man I was using that volt meter totally wrong. I was grounding to a painted surface and you said that's a no go lol. So I ended up taking the sucker back for an exchange thinking it was broken.
dx3
noonooJAY wrote:Hey Jonny,
Always glad to help a fellow forum member
Yes, for the ground you need bare metal to have a true ground. Most people use the black or chassis, but being that you are inside you could probably find a grounding block somewhere in there or a metal bracket.
T-taps are certainly ok, they just aren't what I use. This is what I use:
http://order.waytekwire.com/pr...0AND/
You crimp the wires, then using a heatgun it melts the solder so you have a crimped and soldered connection. You can't beat that! Also, remember to wrap everything in electrical tape.
Let me know if I can do anything else to help. Regards,Jonny
dx3
Pay aprticular attention to the orange wires as they should be accessory. And then look at black for grounds. Obviously check them first to make sure, but from my research that is what you are looking for.
Jonny
noonooJAY
Car: 2005 QX56
Hey I got it working Jonny. I tapped the green power wire at the starter harness, and am now in the process of buttoning everything down. I tested them and they work good, when each door opens, they light up and turn off when they close. But I was interrupted by my kids so its going to have to wait til later lol. But as soon as I'm done I'm going to post pics of all the mods I've done including this one so you can see it.
Thanks again man, you really helped out.
dx3
Awesome man - congrats on getting it done Just make sure you have your connections taped up well with electrical tape.
Look forward to the pictures.
Regards,Jonny
noonooJAY
Car: 2005 QX56
For sure man, got plenty of electrical tape. Pics comin soon. Oh yeah, any idea where I can get some super bright led lights for the interior dome lights?
dx3
noonooJAY wrote:For sure man, got plenty of electrical tape. Pics comin soon. Oh yeah, any idea where I can get some super bright led lights for the interior dome lights?
Funny you mention this. I just made my final order and replaced EVERY interior, and several exterior lights with "cool white" leds.
You kinda nailed it with your question - the website is actually called http://www.superbrightleds.com
If Timmbo wants, I can collect all the bulb information I ordered and we could make a sticky for LED bulb replacement. Or perhaps a DIY sticky for simple mods...
Regards,Jonny
noonooJAY
Car: 2005 QX56
Man I feel like a kid in candy store right now looking through this website you recommended. There is so much to chose from lol. If you don't mind me asking, what did you go with for the side mirrors,foot wells, and the 194 door/step lights?
dx3
I felt the same man. Here is my order... I ordered 1-2 spares for some of them just in case I had a problem:
Quantity: 8Product: 921-x9 Wedge Base LED bulb $ 1.95 (each)Options: White 921-W9 1.75
These are for your side mirrors, and also your lights above your headlights etc...
Quantity: 12Product: WLED-x5 LED Wide Angle LED bulb $ 2.99 (each)Options: Cool White WLED-CW5 0.95
These are for all of your personal lights, lower foot well lights etc etc.
Quantity: 4Product: 3022-x4 LED Festoon bulb $ 1.89 (each)Options: Cool White 3022-CW4 0.95
The festoon bulbs are for the interior lights when you open your car (in the center that you push the light to turn on and off) and then for the light that comes on when you open the rear hatch.
Hope this helps Jonny
noonooJAY
Car: 2005 QX56
Yes indeed. Do you notice a significant difference? Ive been buying these cheesy lights from autozone and i keep taking them back cause they all suck. I went with these sylvania hyper White light for my fogs, but it really doesn't look that different. I want my fogs to match the color of my head lights,I hate the fact that they are 2 different colors. Any suggestions for the fogs?
dx3
noonooJAY wrote:Yes indeed. Do you notice a significant difference? Ive been buying these cheesy lights from autozone and i keep taking them back cause they all suck. I went with these sylvania hyper White light for my fogs, but it really doesn't look that different. I want my fogs to match the color of my head lights,I hate the fact that they are 2 different colors. Any suggestions for the fogs?
Yes, it looks awesome. I will get you come pictures tomorrow night of how it looks at night.
Yes - get some H3 HID's. They are plug and play install and takes about 5 minutes per side. I thought my headlights were 6000k, so I got the 6k fogs. Now it seems that the headlights are 4300k so they are not a perfect match
Looks much better than the yellow though...
Jonny
noonooJAY
Car: 2005 QX56
Ok kool. I just made an order from that site you hooked me up with. Are they pretty quick with the shipping? Man I cant wait to see what it looks like. I wanted to get the H3's they had on there but I wasn't sure. did you get your H3's from superbright?
dx3
noonooJAY wrote:Ok kool. I just made an order from that site you hooked me up with. Are they pretty quick with the shipping? Man I cant wait to see what it looks like. I wanted to get the H3's they had on there but I wasn't sure. did you get your H3's from superbright?
Yes, they are superfast. They ship the same day and I usually get mine within 2 days
No, don't get the H3's from there. You should get HID H3's, not regular LED ones.
If you want a cheap set follow this link
http://www.clublexus.com/forum....html
or else XenonDepot is pretty cheap too.
Hope this helps,Jonny
noonooJAY
Car: 2005 QX56
Awesome thanks Jonny . Im still working on my QX lol, then I got side tracked with the whole lighting thing. Got one side buttoned up though. Will keep ya updated.
dx3
You are welcome man Let me know if you need help with anything else...
Jonny
noonooJAY
Car: 2005 QX56
HEY MAN AS PROMISED, HERE ARE THE PICS. I POSTED EM UP IN THE "POST ALL YOUR PICS HERE" SECTION THAT TIMBO PUT TOGETHER BUT I FIGURED YOU MIGHT NOT SEE EM. THANKS FOR ALL YOUR HELP MAN.
<center><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /></center>
<center>
<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /></center><center><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /></center>
dx3
Looks really good man - well done. Looks a lot like mine (except for my 6 TV's )
Keep up the modding
Jonny
noonooJAY
Car: 2005 QX56
HAHAHAHA. six???? well we know you like to floss now dont we haha. but didnt you say you have a supercharger? wow
dx3
Yes sir - although I was not the one to install the TV's or supercharger, so no props to me. I lucked out this time and bought everything already done. A pleasant change I might add
There are 4 headrest TV's, a flip down in the center, and then the NAV screen which turns into a TV with the flip of a switch.
As for the supercharger, it is the Stillen supercharger that has been mentioned previously on here by Timmbo and InifiniteBeyond. I will try and get some pictures/video of it so you can at least somewhat experience it. Certainly a funny toy to have on tap
Regards,Jonny
noonooJAY
Car: 2005 QX56
Dope man, yah pics would be nice. I may need your expert level guidance again as i am planing to do the whole nav/dvd thingy. You said you bought it like that. But can you turn me in the right direction?
dx3
noonooJAY wrote:Dope man, yah pics would be nice. I may need your expert level guidance again as i am planing to do the whole nav/dvd thingy. You said you bought it like that. But can you turn me in the right direction?
Hey man,
I am not sure how much help I can be, but I will certainly do what I can to assist you.
Regards,Jonny
Return to “Armada Forum / QX56 Forum / QX80 Forum”
