Hardwire Radar Detector?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
dx3
Car: 2006 Infiniti QX56
Has anyone hardwired in their radar detector? Or do I get to be the first to start cutting wires
Jonny
Guju Rider
Car: 2004 Infiniti G35 Desert Platinum (Sedan)
no need to splice any wires on the car..just go to autozone or any place of such kind and ask about a gizzmo called "add-a-circuit"...i prefer to use the fuse for the cigarette lighter..also u might want to pick up a small pack of 3A fuses...place the power end of the radar into the "add-a-circuit" and ground the other one..place the cigarette lighter fuse and the 3A fuse on to the "add-a-circuit" and plug it in the place where you pulled out the fuse for the cigarette lighter..this way you dont have to cut any wires..no electrical tape..and you can transfer this whole set up if/when you decide to get rid of the armada.
hope this helps..
Warped161
Car: 90 s13 the never ending project
you may be able to get a kit from the manufacturer, mine was like 15 bucks it is a simple kit that splices into the cigarette lighter wire. actually it just snapped over the wires to splice in.
dx3
I think you guys are missing what I am going for. The point is to not have wires anywhere visible... Tapping into the fuse would do this. Hence, if you tap into the homelink right there then you will have about 2 inches max of visible wires...
Jonny
EvilJack
Car: 2008 QX56
dx3 wrote:Has anyone hardwired in their radar detector? Or do I get to be the first to start cutting wires
Jonny
I was about to do this as I had mine hard wired in my previous car but then came across a WAY better solution. I bought:
One of these: http://store.nexternal.com/sha...s.asp
And one of these: http://www.stealthcords.com/shop/
The whole solution is so slick! No more suction cups, and no wires showing at all - it is wired into the rear view mirror power. And the RD is higher where it performs better and blends into the rear view mirror. I can't believe I didn't always have it this way. Here are a few pics from my QX....
** I had some troubles (Google Checkout issues) with my order at Stealth Cords and the guys there responded immediately and personally and bumped my shipping up to overnight without extra charge. And the product they delivered was top quality. No affiliation, just a very good experience to pass on.
Modified by EvilJack at 5:35 PM 7/25/2009
Modified by EvilJack at 5:36 PM 7/25/2009
Modified by EvilJack at 5:37 PM 7/25/2009
dx3
Is this link supposed to go to the blendmount kit? Thanks man,Jonny
EvilJack
Car: 2008 QX56
Yes, the BlendMount kit. I couldn't seem to get the link to go directly to the kit.
dx3
Now did you just do this to bypass the suction cups on your windshield? Not quite understanding what this particular thing offers??
Thanks man,Jonny
EvilJack
Car: 2008 QX56
It offers a number of things. Yes it does eliminate the suction cups, but more importantly (to me) it essentially eliminates the power cable also. Yes there is a power cable involved, but it is 6 inches long and goes into the back of your powered rear view mirror - this is where the RD now gets the power from. And from where I sit, I can not see the wire at all. This is opposed to the cable coming out of the RD, going down the windshield to the crevice in the dash, across the windshield, then down into the undernearth of the dash where you will need to find a fuse or power supply to connect it to. So you no longer have a cable laying across the dash. It also keeps the RD up higher where it is said to perform better. And it integrates / blends into the rear view mirror where it is not nearly as noticeable (to cops or thieves). and the fit or the mount in general is so much better. It is a much steadier solution than the suction cups. It sits very securely in the BlendMount kit, it doesn't jiggle or bounce.
So for me it looks better, it is mounted more securely, it performs better, it eliminates the clutter of cables, and it is safer there from prying eyes. A no brainer for me.
dx3
EvilJack wrote:It offers a number of things. Yes it does eliminate the suction cups, but more importantly (to me) it essentially eliminates the power cable also. Yes there is a power cable involved, but it is 6 inches long and goes into the back of your powered rear view mirror - this is where the RD now gets the power from. And from where I sit, I can not see the wire at all. This is opposed to the cable coming out of the RD, going down the windshield to the crevice in the dash, across the windshield, then down into the undernearth of the dash where you will need to find a fuse or power supply to connect it to. So you no longer have a cable laying across the dash. It also keeps the RD up higher where it is said to perform better. And it integrates / blends into the rear view mirror where it is not nearly as noticeable (to cops or thieves). and the fit or the mount in general is so much better. It is a much steadier solution than the suction cups. It sits very securely in the BlendMount kit, it doesn't jiggle or bounce.
Sorry - I should clarify. I completely understand your reasoning for using the power wire from the mirror. It was the BlendMount Kit I was asking your about. But thank you for your answer.
Regards,Jonny
Return to “Armada Forum / QX56 Forum / QX80 Forum”
