The exhaust housing is smaller I believe. Bottom mount for what reason? That s*** sucks. Good luck building that manifold. Go with the hx35.
Chris28 wrote:I'm glad I checked the sr section, I plan on using a holset for my next KA-T setup. A few quick questions: Why the HY series? I know Kentuckyslider went with the HX series, just wondering if the exhaust housing size was your reason for the HY. How does it compare to the size of a t28? I'm going to keep my setup bottom mount and want to know if I'm going to have any clearance issues.
This one is for both Kentuckyslider and the OP: In regards to the hx and hy series, which will spool faster? I'm either going to get an HY30, the HY35, or the HX30. I want it to spool really quickly but be capable of around 300-350hp. Sorry to threadjack, I just didn't want to start a whole new thread when my question is pretty specific haha. Thanks.
-Chris
Ok so update. -Rear subframe pulled-all bushings burned out, collars removed, sprayed with degreaser, pressure washed.-solid subframe and diff bushings in-polyurethane bushings pressed in for the rest of the the subframe.-everything primered with some coats and then added crazy colors. Looks like a skittle sponsered subframe.
I still cant connect the consult cable for my nistune to my computer. It wont read it on my laptop or my buddies.
Re-checked the wiring for the consult cable since the s13 is not OB2 and you have to wire it up. To fix this I would have to send my ECU back to Australia with the nistune board for them to install and make sure it works. Its going to take for ever for that to get sent back though. Im contemplating taking the loss and go JWT just so I can get this running asap and prob sell the nistune. WWJD ???I rlly am f***ing fead up with it lol
