Markadopolus
92 Hardbody
LA CA
1-13-2009
| « Re: quick way to lower a nissan/datsun pickup (PEZi303) | 2:59 AM 2/24/2009 |
Nice write up. I'll try to get some pics of the torsion bars of my 92 because they are ever so slightly different than your 720. Just a little tip: When I was lowering my front torsion bars, I used a "Locking Flex Ratcheting Combination Wrench" It made lowering the front a whole lot easier than using an open ended wrench because of the limited space. The nuts for the torsion bar adjustment on my 92 hardbody were both 19mm, but it may be different for other years.
Reverend D
Supporting Member
1995 Nissan D21 Hardbody KA24E
Western NY
1-12-2003
Awesome work guys! I vote sticky.
FlatBlackIan
Articles Managing Lumberjack
S13 Chuki, S13 Zenki, A34 Maxima, 1983 C10 pickup.
Creepy cabin in the woods MN
12-23-2004
| « Re: (Reverend D) | 7:12 AM 2/24/2009 |
Looks good Anthony.
>>The FlatBlack Rally Blog<<
Markadopolus
92 Hardbody
LA CA
1-13-2009
| « Re: quick way to lower a nissan/datsun pickup (PEZi303) | 3:02 PM 2/24/2009 |
Here's a pic of the 90's 2WD torsion bar adjusting nuts. As you can see there are plenty of threads left on the stock bolt.
Reverend D
Supporting Member
Western NY
1-12-2003
The only thing I might want to suggest is re-indexing your control arm bushings with the weight of the truck on them. This will prevent over extending them since they were torqued with the original ride height in mind. It's just a matter of loosening them and re-torquing them which allows them to adjust to the new ride height. Bushings only have so much travel and by lowering the truck they go out of their "range" thus shortening their life. Re-indexing them allows for the new ride height while keeping the bushings within "range".
young-gunn
Near Winnipeg Manitoba
10-16-2005
| « Re: (Reverend D) | 3:04 PM 2/27/2009 |
I dropped mine last night and aligned it this afternoon, but it's very bouncy. is there any way to sidden the front up? I'm going to be buying some aftermarket shocks too once winter is over.
| Quote, originally posted by jeff420 » | | the 240 vtak secret is out. ohh nooz!!!! |
| Quote, originally posted by mrgreeneyes » | | he has unlocked a fabled secret. praise him. he can cut holes in ****. |
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « Re: (young-gunn) | 3:13 PM 3/2/2009 |
| Quote, originally posted by young-gunn » | | I dropped mine last night and aligned it this afternoon, but it's very bouncy. is there any way to sidden the front up? I'm going to be buying some aftermarket shocks too once winter is over. |
the aftermarket shocks should fix it... mine is extremely stiff because i wanted to keep it ready for auto x.there are many options out there in that respect including KYB monomax that are pretty good... but if you're really looking for the 'perfect' ride they make adjustable KONI's that can be found on summitracing.com... that way you get to choose exactly what ride you get out of the vehicle... most expensive option of course
young-gunn
10-16-2005
| « Re: quick way to lower a nissan/datsun pickup (PEZi303) | 11:01 PM 3/6/2009 |
is there any way to get my truck any lower without resorting to air? There's lots of the ones built for drift that are right low, and I cant imagine them using air.
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « Re: quick way to lower a nissan/datsun pickup (young-gunn) | 5:33 PM 3/7/2009 |
for the front you can get drop spindles... that with the torsion bars can lower you to the ground if you wantfor the rear couple the lowering blocks with along with a re-arch of the leaf springs (or flip the eyelets of the leaf springs) but that needs to be done at a spring shop.
rizzobc
1987 nissan hardbody
montgomery al
6-17-2009
| « Re: (Reverend D) | 6:01 PM 6/18/2009 |
ok, you guys are great. you have helped me ou so much, but i do hve a question. how do you reindex the control arm bushings? you see this is all new to me. thanks Rizz
Desert Rat
Trucks/Murano Moderator
1998 Frontier 4x4, 2002 Xterra 4x4, 2007 Murano S AWD
Mesa AZ
1-17-2007
| « Re: (rizzobc) | 7:03 AM 6/19/2009 |
I can lower your truck faster.Let the air out of the tires
 1998 Frontier SAS / 2002 Xterra SAS / 2007 Murano S AWD / 2000 Z28 350Z eater / 2004 Suzuki Intruder VS800
flinterman2000
2000 Nissan Wingroad, 85 Datsun 720 Pick Up, 84 laurel
La Brea San Fernando
5-4-2009
| « Re: quick way to lower a nissan/datsun pickup (PEZi720) | 4:35 AM 7/17/2009 |
My brother had an83 king cab and lowered his about three inches with lowering blocks. I also know that he cut the chassis and installed a piece of 4" pipe to get the full travel of the diff. Is that really necessary for that kind of drop or only if you are going really radical.
kibatheloanwolf
1989 Nissan D-21 Hardbody 2.4L Z24i dualplug L-4 5speed "POS won't run right"
Four oaks NC
5-31-2009
| « Re: (Desert Rat) | 7:54 AM 7/17/2009 |
| Quote, originally posted by Desert Rat » | | I can lower your truck faster. Let the air out of the tires  | No no no you for got one other option Desert Rat You for got taking the rims off :P
When history witnesses a great change, Razgriz reveals its self, first as a dark demon. As a demon, it uses its power to rain death upon the land, and then it dies. However, after a period of slumber, Razgriz returns, this time as a great hero.
lavagray
San Jose CA
7-27-2009
More info on: reindex the control arm bushings?Changing the shocks will get you close to stock ride again? Sorry for the noobie question.
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 10:20 PM 7/28/2009 |
if you search for re-indexing you should find a thread... i know there was one specifically on re-indexing possibly in the ODPL section of NICOshocks will not change your ride height unless the current ones are completely shot and even then it wouldn't take you up much
97PickUp
1997 Nissan Hardbody
Cary NC
4-7-2009
| « Re: quick way to lower a nissan/datsun pickup (PEZi720) | 9:38 PM 7/30/2009 |
I found this way of removing the stock U bolts easier:
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 10:11 PM 7/30/2009 |
hot damn! mine came off pretty easy the normal way... but yeah that works too!
97PickUp
Cary NC
4-7-2009
| « Re: FN-QR (PEZi720) | 3:19 PM 7/31/2009 |
Hahaha. to be fair, the bolts were rusted to all hell.and just a side note ^ On my '97 I found it was also a 19 or 3/4 for the torsion bars (3/4 seemed to work better for some reason)
lavagray
San Jose CA
7-27-2009
Sorry. My question is if the truck is lowered, do you lose much on the ride comfort? The rears I would think is the same ride, so does the front ride get harsher?
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 11:03 PM 8/1/2009 |
its not as comfortable no... but it can be helped by getting better shocks
Jamman
1994 Nissan D21 Pickup 2.4L 2wd
San Diego CA
8-4-2009
| « Re: (young-gunn) | 8:50 PM 8/4/2009 |
Remember that you can lower out the front suspension travel. Which will give you no travel and an unsafe ride not to mention destroy your truck and maybe even teeth
LVM
90 300zx 2+2, 97 hardbody kingcab 4x2
Sewickley PA
1-10-2009
| « Re: (Jamman) | 12:20 PM 9/9/2009 |
What is the difference out of the drop spindles as opposed to the drop control arms? Does anyone have problems with the drop blocks and is it worth the money to get drop leafs? Summit sells them, and I know blocks are illegal in some states, but do they cause any issues with the way you are able to drive your truck. In the near future once I figure out where my rear end is coming from, I'm going to start drifting my truck, and I wasn't sure if anyone has had issues or not.
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « Re: (LVM) | 5:04 PM 9/9/2009 |
| Quote, originally posted by LVM » | What is the difference out of the drop spindles as opposed to the drop control arms? Does anyone have problems with the drop blocks and is it worth the money to get drop leafs? Summit sells them, and I know blocks are illegal in some states, but do they cause any issues with the way you are able to drive your truck. In the near future once I figure out where my rear end is coming from, I'm going to start drifting my truck, and I wasn't sure if anyone has had issues or not. |
with the power these trucks make the rear drop blocks don't cause any issues... however... with higher HP they will allow for 'axle wrap' and not be all that fun... remember this is the 'quick way to lower it' if you want to drift either get drop leafs or if you want to be completely sure about your purchase have them lowered at a spring shop... i autocross and have no issues with the blocks until the back end breaks loose... but considering i'm not supposed to be breaking loose i'll leave it until i do my suspension build as far as the front... i've never heard of drop control arms... but the spindles will work great! i'm sure someone here has heard of the control arms but i haven't... so i'll let them tell you about those
kibatheloanwolf
Four oaks NC
5-31-2009
| « Re: (PEZi720) | 11:34 AM 9/16/2009 |
Two questions 1. Why are the hard body's a** end always higher than the front of the truck?2. suppose I wanna Raise the nose of my truck how would I do that?
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « Re: (kibatheloanwolf) | 2:16 PM 9/16/2009 |
to raise the front you just 'tighten' the torsion bar bolts (turn to the right)but personally i like the front lower... i lowered my front more than the rear... helps my driving style at autocross too
kibatheloanwolf
Four oaks NC
5-31-2009
| « Re: (PEZi720) | 7:32 PM 9/16/2009 |
Do I need to put it on stands first?
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 9:24 PM 9/16/2009 |
yep
kibatheloanwolf
Four oaks NC
5-31-2009
| « Re: FN-QR (PEZi720) | 9:37 PM 9/16/2009 |
Thanks PEZi Anything I wanna check While it's on the stands?
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 10:35 PM 9/16/2009 |
check the bushings... every last little rubber piece under there
pejsa s-13
91 HardBody
El cajon Ca
9-18-2008
| « Re: FN-QR (PEZi720) | 12:26 PM 9/17/2009 |
two questions for you pezi:1. some odpl guy told me if i took the thick a** leaf off the bottom of the leaf pack and put it on the top instead, it would give me 2 more inches of drop, by flattening out the leafs and give me stiffer rear ride (true or false) 2. was your truck competive in auto x, like whats another vehicle that was there one day that had the same times as you?
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 3:47 PM 9/17/2009 |
answer to first question... i dunno... but i want to know as well because once i make some more power i'll need to get rid of the blockssecond question... this is a little harder to answer because i'm running in a class that is for cars built for the track only (which mine still has a long way to go in order to be competitive in) BUT... as far as being competitive against other 'street' cars... yes it is here are a few times from a previous event my truck (less than 100whp / truck suspension) - 64.801 '93 240sx (KA port and polished w/full exhaust / full suspension) - 65.235 '07 STi (300whp / full suspension) - 64.145 '06 s2000 (stock but good tires) - 65.055 now like i said... there is a lot of room to play in my class... and to be competitive in my class i need to build the truck to be much better... the guy who took 2nd in nationals in my class was there this same day and... '87 corolla gt-s AE68 (250 whp / FULL CUSTOM suspension / 1700 lbs) - 55.247
pejsa s-13
91 HardBody
El cajon Ca
9-18-2008
| « Re: FN-QR (PEZi720) | 7:00 PM 9/17/2009 |
cool thats pretty much exactly what i wanted to knowand ill expirement with the leafs on sunday and let you know the results.
bracktheron720
1984 720 with 1980 datsun front end,1972 yamaha cs3
kennewick wa
10-24-2009
| « Re: FN-QR (pejsa s-13) | 11:46 PM 10/24/2009 |
| Quote, originally posted by pejsa s-13 » | | cool thats pretty much exactly what i wanted to know and ill expirement with the leafs on sunday and let you know the results. |
did you caome up with anything??i wanna do the leaf fswitch if it worked for you!!!
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 6:44 PM 11/1/2009 |
i've been thinking about this leaf swap... and i feel it wouldn't be 'stable' for performance... probably ok in a DD that doesn't see a lot of hard use but a simple re-arch from a spring shop would give you the same result without compromising performance
bracktheron720
kennewick wa
10-24-2009
| « Re: FN-QR (PEZi720) | 10:40 PM 11/1/2009 |
rite on thats kinda the answer i was looking for!!im not goin for a strait up track vehicle more of an agressive DD..i love the look of my truck just want a little more perfomce and handling out of her!!lowering helped with the cornering alot!!in the rear mine has helper springs for hauling heavier loads will removing them do anything to the ride hight??as far as looks go i just want to get the stance rite still...iv alredy converted the front clip to an earlier model Datsun insted of my 84 front end was a little work but came out sweet!!
Frankie Pintado
2001 Nissan Frontier (sold),1987 d21 2wd, 1972 VW Karmann Ghia
Washington VA
7-3-2009
| « Re: FN-QR (PEZi720) | 10:14 PM 11/3/2009 |
OK, I've been watching this thread lately, and I've got a truck that I am willing to try the spring swap on. I also see a few potential problems: mainly that with that configuration, the suspension may get softer as it compresses. not good. However, I admit that it is difficult to picture exactly what the effect will be without trying it. Since the body is such a heap of rust and bondo, and has mold and grass growing on it, I volunteer to try this probably bad idea. It may be a week or two, but I'll get back to you all with some pictures and reviews.
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
| « FN-QR | 12:51 PM 11/4/2009 |
sweet thanks man!
bracktheron720
kennewick wa
10-24-2009
| « Re: FN-QR (Frankie Pintado) | 2:55 PM 11/4/2009 |
awsome!!!im gunna try to patiantly wait to hear back on it!!
Reverend D
Supporting Member
Western NY
1-12-2003
| « Re: (lavagray) | 5:02 PM 11/4/2009 |
| Quote, originally posted by lavagray » | | More info on: reindex the control arm bushings? Sorry for the noobie question. |
Control arm bushings are tightened with all four wheels on the ground. They have a predetermined range of motion once tightened down. By lowering the truck automatically those bushings are out of range due to the new angle of the control arms to the frame. To fix this you must loosen the control arm bushings, set the truck back on the ground then re tighten them to spec. This will allow them to adjust to the new control arm angle to the frame. Otherwise they will be ripped apart in a shorter amount of time because their range of motion is out of limits. Easiest to perform on an alignment rack.
| First 1 2 > Last |
