 LED Upgrade Project + Dome Light ConversionFirst  1 2 >  Last
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
AD1787
2007 M45 Sport Twilight Blue
Chandler AZ
12-1-2008
 « Re: LED Upgrade Project + Dome Light Conversion (infinitiandbeyond)
Awesome post. Thanks for all the info
I would love to see people's reaction to your backup lights. It would be fun just to throw it into reverse at a stop light and scare the crap out of the people behind you
I was wondering on the footwell light if the one stated in your post ended up being significantly brighter and worth the effort. I feel like i should be a gymnast to change that bulb.
"Dont comment that I should have bought a cheaper car with cheaper service fees or that I could do all the repairs myself"
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (AD1787)
Good question. I should point out that I did not put the black lenses back into place yet. So, I have very bright footwells at the moment!
I took a pic of one of the clear lenses from the trunk and emailed it to a couple of online suppliers. Too pricey IMO to just buy two clear lenses.
However, superbrightleds.com has a good selection of single led's. I'd recommend those for that particular location. You could then drill a hole in the black lens and put it back into place. A clear one to diffuse the light somewhat would be nice, though.
Bruno
2008 M35x
Parkesburg pa
12-16-2008
Wow, excellent write up and great pix and narrative. Looks great.
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (infinitiandbeyond)**UPDATE**
AN IMPORTANT UPDATE!! The 14-LED high power CANNOT be used for parking lights up front. There will be an issue with heat.
The alternative, which I've seen others here use, is the standard 27-led.
M4T5
2007 Infiniti M45
Spring TX
12-30-2008
 « Re: LED Upgrade Project + Dome Light Conversion ( ... (infinitiandbeyond)
DUDE! Your car is going to MELT!
J
Element114 CAI Kit 4-Sale: http://forums.nicoclub.com/zer...8-m45
07' Infiniti M45--Ext: Platinum Graphite--Int: Black--Aero Pkg-- Element 114 Exhaust--Throttle Body Coolant Bypass--Air Box Resonator Removed
abhik.light
Mercedes
Pune Jharkhand
1-22-2009
It was a excellent write up and good information.
Lighting LED Bulbs
M4T5
2007 Infiniti M45
Spring TX
12-30-2008
So..... will the V-LED #921_14_HP_W rear reverse lights increase the light intensity and help you see better than the OEM back up lights?
I keep reading mixed opinions on this issue.
J
Excellent09
Brooklyn NY
12-1-2008
Thanks for the link...Can the fog lights be replaces with LED?
paigoomein
Irvine CA
3-30-2007
 « Re: LED Upgrade Project + Dome Light Conversion (M4T5)
I have the same question on the back-up lights. are they actually brighter than OEM and do they provide better visibility? any comparison pics you can put up of the two?
Quote, originally posted by M4T5 »
J
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (paigoomein)
Backups ARE certainly brighter than OEM. Both through the backup cam and turning and looking backward.
As far as replacing front FOGS, i also did that but the "jury is still out". Again, it depends on if you are after looks (these will do the trick!) or better lighting performance.
As another poster pointed out, they are just fog lights...use in fog or rainy conditions.
I don't know that I'll keep the LED's in my fogs. I may put that money into better headlight bulbs.
blazin_lo
infiniti m35x vip
T DOT Ont
11-16-2008
is there anyway to make the m35 daytime running lights white or hid
DaleHeller
07 M35, Obsidian Black
Nashville TN
1-1-2008
 « Re: LED Upgrade Project + Dome Light Conversion (blazin_lo)
I did the fog lights with H11 from V-Leds.com and the effect is awesome, much brighter and matches the other leds I put in....
They are mucho fun to replace too ....
cmark
2006 M35 Sport
Seattle WA
12-10-2008
 « Re: LED Upgrade Project + Dome Light Conversion (DaleHeller)
pics please!!
YMm45
m45 s
gibsonton florida
2-27-2009
 « Re: LED Upgrade Project + Dome Light Conversion (cmark)
looks great i think this is my next project to my M
choochmpls
Minneapolis mn
3-6-2009
Quote, originally posted by infinitiandbeyond »
Did you have an issue with the hi power 14led's? The housing also holds the high beam halogen, which would seem like it would be WAY hotter than any LED light. Why shouldn't we use the Hi power 14 led?
rsg123
2006 M45 Sport
Sacramento area CA
9-14-2008
The domelight/map bulbs are NOT 1157 (these are much too large to fit). Sylvania's site lists the bulb as either a 7443 or 3175 but neither of these is a twist and lock bulb as pictured in the original post in this thread. Does anyone know # this bulb is?
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: (rsg123)
It actually might be an 1156 instead. Best bet is to take it out and into the store.
Sylvania's reference to a "dome" light only applies to rear seat lights, a "Festoon" type DE3157.
ajgsport7
Infinti M35 Sport
Los Angeles California
6-30-2009
what is the V-led model # of the 27 led model i should buy for the "driving light"?
I would love a "cool" white effect any reccomendations? that wont have issues with heat?
08m35
M35
gulfport ms
4-24-2009
GREAT post and awesome pictures. This is diffently one of the best posts i've seen.
rsg123
2006 M45 Sport
Sacramento area CA
9-14-2008
The domelight bulbs are BA9S. Instead of permanently modifying the posts and connections as shown in this guide, just buy one of the LED arrays on eBay which offer adapters for different types of bulbs. Just search for BA9S. The installation took me about 2 minutes and I have 24 SMD LEDs (you could cram even more in there, but this produced more than adequate lighting).
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: (rsg123)
Pics?
About Tree Fiddy
2009 M35S
Chandler AZ
2-7-2009
 « Re: (infinitiandbeyond)
I just completed my LED upgrade and wanted to thank infinitiandbeyond for the original post which took most of the work out of doing the upgrades.
I started about 4 months ago and changed out the front parking lamps, the trunk lights, backup light, license plate light and door courtesy puddle lights. Because I didn't want to permanently modify my new M35S I stopped short of doing the interior lights. Well, when this post was revived it motivated me to complete the job.
First thing I did was pop the DIY 30 SMT W's out of the trunk lights. Because they were just loosely floating around behind the diffuser lens you could always see that the LED panels were crooked. I put a small amount of clear, high-tech polymer adhesive/caulking on the edges of the LED panels and stuck it to the diffuser lenses. Now the LED's panels are lined up nice parallel to the top and bottom of the lens. Probably a little AR, but it looks more professional now.
Next to the interior. The rear 16 LED - 3175_16_SMT_W were plug and play. On to the front dome/maps lights. I took rsg123's suggestion of using an array and used the same 30 LED - DIY 30 SMT W I used in the trunk with the supplied adapter. You can get similar LED's on ebay but V-LED's gives me such good service I just ordered them from there and had them in 2 days. Note, if you use the DIY 30 SMT W from V-LED's with the supplied adapter they won't work out of the box because the polarity is backwards on the adapter. You need to gently pry or pull the 3-pin connector off the adapter and flip it around 180º and push it back on then they will work fine.
While the look of the LED's pressed up against the diffuser lens is fine for the trunk I really didn't want that look in the dome lights. To get around this I just used the existing post in the housing (the one infinitiandbeyond ground off in his installation) to "mount" the LED panel. To do this just used the same polymer adhesive I used in the trunk and stuck the back of LED panel to the bottom of the post. This recesses the array to about the same depth as the original bulb and give a much more diffuse light instead of seeing the 30 individual light sources as you see in the trunk. Plus, it is completely reversible if you ever need/want to go back.
I didn't bother with the footwell lights since I have never noticed they were there plus I forgot to order any LED's for them. Maybe later.
Anyway, the interior is really bright and really white now.
And the monster bent down and said "I need about tree fiddy."
DRIPS
2003 Infiniti M45
Dover NH
10-24-2007
 « Re: (About Tree Fiddy)
great stuff all!!!
2003 Infiniti M45
~Pearl White~
Y34 Spottings: 6
BRIANxJDM
07 G35 Sedan Sport
San Gabriel CA
7-7-2009
ay man wheree you get the mounting thing at?
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (BRIANxJDM)
Brian,
Great question. Go to http://www.superbrightleds.com/festoon.html for the festoon bulb sockets if that is what you are referring to.
SteveTheTech
Technical Moderator
95 Infiniti J30
Alexandria VA
8-16-2008
That is great I really like the enhanced light from the array setups. I have seen many people with simple ebay sets and the light saturation is weak.
Thanks for the hard work.
-------------------------------- Nissan Sport Magazine
mcp6530
2006 M35x Navitech
aurora il
7-19-2008
What did you use specifically for your fog lights? The conversion kit H11 or something else? I don't need more light, just a better looking light than the stock junk. Thanks!
rsg123
2006 M45 Sport
Sacramento area CA
9-14-2008
Quote, originally posted by About Tree Fiddy »
I would suggest doing this. I replaced the footwell bulbs with white SMD LEDs and removed the black tinted lens. The white light on the black carpets and your shoes is very nice. With the tinting removed, you will definitely notice the lights.
It's just a shame I drive my car 95% during daytime so I can't appreciate the lighting upgrades (or the awesome adaptive headlights).
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (mcp6530)
No conversion since they are already H11. I might suggest these...
http://www.v-leds.com/Exterior....html
mcp6530
2006 M35x Navitech
aurora il
7-19-2008
You used H11 LED's for your fog lights? Are they bright enough? Can't decide between HID conversion or LED's for fog lights.
rsg123
2006 M45 Sport
Sacramento area CA
9-14-2008
Choose HID for enhanced lighting and improved color. Choose LED for severely reduced lighting (from all of the bulbs I have seen) and improved color.
mcp6530
2006 M35x Navitech
aurora il
7-19-2008
 « Re: LED Upgrade Project + Dome Light Conversion (rsg123)
So, whats the final verdict on the front parking lights?? Not the high power 14's, but what is the right number 19 or 27 or another one?
Please advise - thank you!
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
MCP,
These are what you want...
mcp6530
2006 M35x Navitech
aurora il
7-19-2008
MCP,
Thank you! Order has been placed!
Popster
2007 M35
Wylie TX
8-23-2009
The replacement clear lenses for the footwell lights can be purchased from Infiniti. The clear lenses in the trunk are the same as the footwell.
infinitiandbeyond
2007 M35x
Fishers in
6-28-2007
 « Re: LED Upgrade Project + Dome Light Conversion (Popster)
I found it to be a mute transaction to replace them with clear. Even if they cost very little, BUT they didn't.
If you install a single LED, it lights it up real nicely and it won't come out of the socket.
rsg123
2006 M45 Sport
Sacramento area CA
9-14-2008
The only way you can see if there is no lens covering the footwell bulbs is if you get your head down there. The lenses are cheap, but add in shipping and handling ($11.95 from infinitipartsusa.com) and they get to be pretty pricey parts you will never see (or need imo).
iPencil
2006 Infiniti M35x
Akron PA
7-27-2009
MCP,
Are these the ones that you had trouble with melting when used with the factory HID headlights, or do these work with the factory HID headlights?
Moslof
2006 M35X
Hartford CT
9-21-2009
infinitiandbeyond - Your post was very tempting, so I have begun the transformation. Thus far I have upgraded with the following from V-LEDS:
License Plate: 194_HP2_W
Front Doors: 921_9_W
Rear Doors: 921_9_W
City Lights: 194_X5_HP_W
Trunk: DIY_30_SMT_W
Very happy with results. Light output in the trunk is much better then old OEM's!! Only wish the city lights came in 5000K rather than 6000K. Feel the 5000K would be a smoother match with the existing low beams. The 6000K looks much bluer than they really are next to them.
Looking forward to taking on the interior (front and rear map lights and foot wells). I plan on using the suggestions that "About Tree Fiddy" defined for the front map lights. I'm also looking to swap out the existing fogs and installing a HID kit. I think I'll go with yellow bulbs for improved lighting and functionality in adverse weather.
Anyone with suggestions for HID fog kit?
Modified by Moslof at 8:03 PM 9/21/2009
 First  1 2 >  Last
» Return to M-Series Forum / Fuga Forum
