Paul Wall
Q45 Enthusiast
Online
1993 Infiniti Q45 133,000 Miles
Ipswich MA
12-22-2007
| « Re: Fuel pump assembly? (Q45denver) | 11:35 PM 11/24/2008 |
I recommend you remove the tank before installing the new pump because you don't want to do the same job twice do You?And yea you have to be careful with the sending unit, they break easily, I broke one my self because I was rushing it on the 1991 Q45 part car I had, Luckily the fuel pump survived. Remove and steam clean tank then reinstall.
My Youtube videos My items for sale on Ebay 1995 Q45 Partout - many parts cheap!!! 1990-1996 Q45 Parts for sale list-Will trade for computer parts! New Genuine OEM Nissan, Infiniti and Datsun parts cheap. Restore your active suspension and belt pulley bearings cheap.
Paul 1993 Q45 Green 11/92 Hybrid of 1990 and 1994 Q45, Soon to be Nissan President Mods done: 1994 auto dimming mirror, 1994 Q45 tweeters, 1994 Q45 trunk net, 1990 Q45 Seat controls and more to come.
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
| « Re: Fuel pump assembly? (Q45denver) | 11:46 PM 11/24/2008 |
Look in the Gallery under texasoilhttp://nissaninfiniticlub.net/photopost/
Brian 1995 Q45 & Q45t & 2000 Q45
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
| « Re: Fuel pump assembly? (maxnix) | 12:03 AM 11/25/2008 |
But here is texasoil Gallery: http://nissaninfiniticlub.net/...term=
goody90q45
Fly Me to the Moon
Online
90Q45
Orangevale CA
8-17-2005
| « Re: Fuel pump assembly? (Q45denver) | 6:28 AM 11/25/2008 |
| Quote, originally posted by Q45denver » | | Anyone know where I can get a closeup picture or diagram of the fuel pump assembly for a 1995 Q45? I'm having some difficulty getting the fuel float/gauge to work after replacing the pump. Looks like part of the plastic that holds the float onto the pump assembly may be missing. |
Here's a closeup of the plastic piece with the float arm removed for clarity.
Mike "Goody" Goodwin 90 Q45 Base 246,000 miles
Q45denver
1995 Q45t 1990 Q45 1998 Nissan Frontier
Denver CO
7-25-2002
| « Re: Fuel pump assembly? (goody94q45) | 11:20 AM 11/25/2008 |
Thanks for the pic. The plastic clip holding on the float rod came off as suspected. Can't see anything inside the tank other than the surface coating of rust. Hopefully I can get a new one from IOS and won't need to pull the tank. I'll have to coat the inside with some epoxy when the weather warms up I guess.
Q45denver
Denver CO
7-25-2002
| « Re: Fuel pump assembly? (Q45denver) | 6:30 PM 11/26/2008 |
Well I wired the float arm back on and everything seems to be working ok. Can't emphasis enough the need to be carefully when pulling the assembly out of the tank. Also installed new fuel filter full of about half a can of BG FI cleaner for a quick and cheap FI cleaning service. Filter was full of rust and really needed changing.
Modified by Q45denver at 7:44 PM 11/26/2008
96Qowner
Supporting Member
1996 Q45
Fargo ND
9-7-2004
| « Re: Fuel pump assembly? (Q45denver) | 10:03 AM 11/28/2008 |
1996 Q45 -217,000 miles 1990 Accord - 398,000 1966 Thunderbird Q code - 87,000
Q45tech
Q45 Guru
1990 Q45 323,000 miles 19.5 years ownership
Marietta , Georgia
4-30-2002
| « Re: Fuel pump assembly? (96Qowner) | 10:10 AM 11/28/2008 |
Always good to reverse blow out fuel filter with air onto a paper towel to view the trash in the tank that was stopped by filter.I change fuel filters every 6 months now and am amazed at the amount of dirt in so called premium gasoline. Rust in tank means you purchased water and caused many problems with injectors and fuel pump.
Copyright 2009. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed. http://www.t3atlanta.com/
david65308
91 Q45
Cabin John Md
12-11-2008
| « Parts for car? (ppastos) | 8:38 PM 12/11/2008 |
Hey Iwould like your fuel pump and the FPCU..if you still have them David david_clvr@yahoo.com757 274 1911 hood if black..THANKS
teppy
Hamilton City CA
7-31-2009
| « Re: Fuel pump assembly? (Paul Wall) | 8:45 PM 7/31/2009 |
I was having a hard time removing the pump because the ring is very tight. I just can't dislodge it. I'd already visited several threads discussing like this one, replacing fuel pump assembly. But still I can't remove the ring.
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
| « Re: Fuel pump assembly? (teppy) | 9:16 PM 7/31/2009 |
You can't remove the fuel sending unit because of the O-ring?Thats imposible are you sure you have a Q45? Was the OEM O-ring used?
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: Fuel pump assembly? (teppy) | 8:42 AM 8/1/2009 |
Wrong thread!You want this one! http://forums.nicoclub.com/zer...age=2
goody90q45
Fly Me to the Moon
Online
90Q45
Orangevale CA
8-17-2005
| « Re: Fuel pump assembly? (teppy) | 9:05 AM 8/1/2009 |
| Quote, originally posted by teppy » | | ...I was having a hard time removing the pump because the ring is very tight. I just can't dislodge it...... |
Sounds like a PO may have used RTV adhesive in the o-ring mating surface to seal a leak? (Which is great if you're going to the moon but not so good if it ever has to come apart again)
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: Fuel pump assembly? (goody94q45) | 9:19 AM 8/1/2009 |
RTV would be easy to remove. A super adhesive would not.Still don't know what kind of car Teppy has, but it must not be a Nissan if he is using that website.
american v8
1991 q45
lotus ca
11-18-2009
live life like the theres no tomorrow. so in other words, the fast lane all day long!
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
| « Re: (american v8) | 3:36 PM 11/18/2009 |
What a fantastic first post to introduce your superior mental processes to Q45 owners!
RandBdude
q45 infiniti
Jacksonville fl
11-19-2009
| « Re: Fuel pump assembly? (Paul Wall) | 9:39 PM 11/19/2009 |
Do you have a diagram of where the fuel pump is located
MinisterofDOOM
Admin of DOOM
Online
Layton UT
5-19-2004
| « Re: Fuel pump assembly? (RandBdude) | 1:33 AM 11/20/2009 |
| Quote, originally posted by RandBdude » | | Do you have a diagram of where the fuel pump is located |
In the fuel tank in the trunk. Just pull out the forward trunk carpeting bulkhead and it's all right there. If you remove the parcel compartment and the big black bracket that supports the keyless entry module (along with the reciever) you get a lot more room to move. I had no trouble removing and replacing the pump assembly without damaging the float/arm with those things removed even with the tank still in the car.
-The MinisterofDOOM  |The Q of DOOM| - |The Maxima| - | Hear my Q!| 4.08 VLSD, NICO 8-way ECU, full exhaust with custom headers, Tokico Blues with Eibach springs, Stillen FSTB, 20mm RSB
