grenade180sx
180sx
socal ca
8-20-2007
| « Re: Start of my 1jz build (ngibson) | 4:02 PM 11/5/2008 |
good stuff dude keep this updated frequentlyim currently doing the same into my car as well!
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (grenade180sx) | 7:15 PM 11/8/2008 |
| Quote, originally posted by grenade180sx » | | good stuff dude keep this updated frequently im currently doing the same into my car as well! |
Nice, what kind of setup do you have planned? Got another update for ya: Got a lot of work done today. My roommate working on takin' manifold off
Tools
 Engine puller / forklift
 Here she comes
Dirty damn engine bay
 After some scrubbing bubbles - that's me with the hose
Sanded ready to paint. I ended up using epoxy appliance paint. It's reallly tough stuff, ever tried scratching the finish on a refrigerator? I tried chipping some of this paint on a test piece earlier in the day, it takes some force to even scratch it a little.
Here she sits at the end of the day
1991ls13
s13 ls1 hatch
SacramentoISH ca
8-6-2008
| « Re: Start of my 1jz build (ngibson) | 7:11 PM 11/14/2008 |
dang, good stuff so far, thanks for your help on my thread, but im thinking if ill be spending pretty much 5k i`m leaning towards the ls1 even though with the 1jz you can just turn up some boost and minor stuff and you got yourself a rocket
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (1991ls13) | 3:51 PM 12/6/2008 |
Update from few weeks ago, never got around to posting the pictures.Best thing for cleaning engines:
This is what happens when your car sits at ter-tech for a year:
1JZ, bitches.
 Junkyard carpet
 Here's a quick preview of my gauges
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 3:51 PM 12/6/2008 |
Evo rotors showed up, they're huge!
Blitz boost contoller
 Injectors came back from Deatschwerks
 550cc's
Kalypso
Gorilla Monsoon
sohc hatch
Flushing, Queens NY
7-24-2007
| « Re: Start of my 1jz build (ngibson) | 8:17 PM 12/6/2008 |
OH MY GOD... well done! does the 1j have forged internals like the 2J? besodes displacement, whats makes the two motors different? you're doing great, and I'm learning.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (Kalypso123) | 6:06 AM 12/7/2008 |
| Quote, originally posted by Kalypso123 » | | OH MY GOD... well done! does the 1j have forged internals like the 2J? besodes displacement, whats makes the two motors different? you're doing great, and I'm learning.
Thanks for the compliments. I'm not sure about the forged internals. I'll have to check that out. Other than displacement, there isn't much difference. A lot of the parts are interchangeable: rod and main bearings, valves, seals, injectors, head gasket, pistons, water pump etc. The heads are completely interchangeable as well. Here's a good list of 1j / 2j parts FAQs http://www.supraforums.com/for...92754
Kalypso
Gorilla Monsoon
sohc hatch
Flushing, Queens NY
7-24-2007
| « Re: Start of my 1jz build (ngibson) | 5:11 PM 12/7/2008 |
thats plenty, thank you.
RCA
1995 Nissan 240sx
NJ
1-22-2007
| « Re: Start of my 1jz build (Kalypso123) | 7:07 AM 12/8/2008 |
| Quote, originally posted by ngibson » | | Update from few weeks ago, never got around to posting the pictures. Best thing for cleaning engines: Scrubbing bubbles Ngibson's Gauges | What process did you use when useing the Scrubbing bubbles? Did you just follow the directions on the can or a special technique??I like the way your gauge pod came out. But no radio? Also I don't have proof but I have heard the "rumors" about stock JZ forged parts but from what I read on the JZ and Toyota forums those rumors are false.
1995 S14 / FSMs / XboxGT & PSNID: cabrita309
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (rcabrita) | 12:06 PM 12/8/2008 |
| Quote, originally posted by rcabrita » | What process did you use when useing the Scrubbing bubbles? Did you just follow the directions on the can or a special technique??I like the way your gauge pod came out. But no radio? Also I don't have proof but I have heard the "rumors" about stock JZ forged parts but from what I read on the JZ and Toyota forums those rumors are false. |
Just spray it on, it usually lifts most everything off but on thicker grease I use an old toothbrush. Then hose it down. The radio will be mounted in the glove box, I always use my mp3 player in my car. Can't stand regular radio so no real need to see it all the time. Now I'm going back and forth on rebuilding my gt40, or going with gt28 twins.
RCA
1995 Nissan 240sx
NJ
1-22-2007
| « Re: Start of my 1jz build (ngibson) | 9:27 AM 12/14/2008 |
| Quote, originally posted by ngibson » | Just spray it on, it usually lifts most everything off but on thicker grease I use an old toothbrush. Then hose it down. The radio will be mounted in the glove box, I always use my mp3 player in my car. Can't stand regular radio so no real need to see it all the time. Now I'm going back and forth on rebuilding my gt40, or going with gt28 twins.
| Wow that is easy! But going twin GT28s is serious money! What is your power goals with this project?
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (rcabrita) | 6:33 PM 12/14/2008 |
| Quote, originally posted by rcabrita » | | Wow that is easy! But going twin GT28s is serious money! What is your power goals with this project? |
For stuff that is caked or burned on, you need a heavier duty degreaser though. I use scrubbing bubbles on engine bays, a lot of the heavier degreasers can fog up clear coats and paints. Depends on the paint though. But twin gt28's would be so baller, with 500+ rwhp at lowww rpms. If I get mid 500's I'll be perfectly happy with the setup. I'll probably be on around 18 pounds for daily, 22 when I wanna kick some *** on the high way haha.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:32 PM 1/3/2009 |
Got a bunch of work done today.My dad build this box over our toolbox a few weeks back. Just got this light installed, made a huge difference
Painted the block - semigloss black
This is the best thing you can do for yourself when working on any project, buy a box of ziplocks and a few sharpies.
My diagram for removing headbolts / camshafts
Not too dirty, nothing worse than can be expected from a 10+ year old engine
I had almost **** myself when I saw this
Then I realized it was from me not taping the intake ports off well enough, and was just water from me hosing it down. Six cylinders bitches!
New headgasket installed
Time for a Dew break
My drawing was less detailed than needed, so I printed out portions of the fsm.
Dropped the oil pan. The lower portion has a bigg dent in it. And I felt the need to reseal it all, and paint bomb it.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:33 PM 1/3/2009 |
Painted
New 2jz water pump and thermostat
Here she sits at the end of the day:
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 3:34 PM 1/11/2009 |
Update!Got a bunch of work done today: ARP Head installed
Less dented oil pan arrived
2jz water pump pulley from OHRLY
When I was removing the head bolts I broke an extension in the tool, after fighting with it to remove the broken piece I just bought another one.
Headstuds in and cams reinstalled
Painted timing cover
Cleaned and painted fuel rail
Installed 2jz injectors
Removed timing gear to install new front main seal
New front seal, painted lower cover, timing belt installed
sandblasted and painted oil cooler tubing
Dirty alternator
All cleaned and installed
Here it is at the end of today
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 4:54 PM 1/24/2009 |
Clear timing cover
 New cam gears
 Installed
 Cover reinstalled
 Blitz!
 Drew out my mounting template
 Do work!
 Cut out
 The mounting hardware
 Clamp it up to bend, used a rubber hammer to bend it over nice and flat
This is where it's going to be mounted
 I had to bend it some more to get the angle I wanted, here it is bolted in, and this crazy strong double sided tape to hold it on
ngibson
90 s13
South Florida FL
5-4-2008
Time for the turbo timer
 The material for the mounting bracket
Damnit! I needed to paint all that ****!
Before
 After - the button emblems were taped over
0range_Kouki24O
T60-1 EK9 sold,MK3 Jetta VR6 sold,B16 EG hatch sold,S13 coupe sold,JZA250SX current DD & Race Car
New Jersey
7-24-2008
| « Re: Start of my 1jz build (ngibson) | 1:19 AM 1/29/2009 |
one of my friends is a noob at the 1j's and as for myself i know only a little bit but not much. he cant find any websites that has ARP head bolts for a 1j. question is..if he ordered head bolts for a 2j would it work on a 1j
1JZGTE powered s14
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (0range_Kouki24O) | 4:44 AM 1/29/2009 |
| Quote, originally posted by 0range_Kouki24O » | | one of my friends is a noob at the 1j's and as for myself i know only a little bit but not much. he cant find any websites that has ARP head bolts for a 1j. question is..if he ordered head bolts for a 2j would it work on a 1j |
They sure will. About 90% of the parts are interchangeable, he can use 2j bearings, rods, pistons, wrist pins, oil pan, waterpump etc. Cams however are not interchangeable. Look at this thread, you might have to registered to look though http://www.supraforums.com/for...92754
1jz240sx
south orange Ma
2-10-2008
| « Re: Start of my 1jz build (ngibson) | 6:09 PM 2/3/2009 |
who did your wiring for you.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (1jz240sx) | 6:18 PM 2/5/2009 |
| Quote, originally posted by 1jz240sx » | | who did your wiring for you. |
2jzswap.com. You mail in your ka harnesses and the jz harness. They match em up, connect all the necessary wires and leave the ones tagged that you need to hook up to the chassis. Very clean job, they recover and retape the whole harness too.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:05 PM 2/7/2009 |
Got a **** ton of work done today.The parts donor!
Hooray blown suspension! Fell out when I put it up on jackstands.
Do work son!
Parts parts parts
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:07 PM 2/7/2009 |
My roommate helpin out
My roommate being... special
That's where I left off today. Tomorrow, I'll be swapping brake lines over. Installing the front suspension, mounting the Evo brakes, installing exhaust and swapping interior over.
jrivera
Approved Fabricator
91 240sx
Palm Beach FL
9-9-2005
| « Re: Start of my 1jz build (ngibson) | 11:59 AM 2/10/2009 |
Keep it up Nate. Surprised there is little interest in this thread. Oh well.
"All I have in this world is my balls and my word, and I don't break 'em for no one..."
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (jrivera) | 5:09 PM 2/13/2009 |
Package showed up today
 From these guys:
 My shifter extension! Been waiting so long for this to come in. Now the engine can go back in.
Speedo interface box. The Tach one is backordered.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 4:58 PM 2/15/2009 |
Got another good days work in. Mounted all my electronics, ran bunch of wiring, and fixed little things like the gauge pod sitting flush.Removed the uncracked dash
 Sparco wheel
 Dash reinstalled
 Removed these ugly bastards
 Plate to mount my TT and Boost controller
 Extended the TT wires into the harness
Went and picked these up for power distribution, top for power and bottom for ground.
My roommate came up with a good idea for once
Break time with brown people haha
Me doing some wiring
 Messing with some more wires
 Final coat of clear on the cluster
You can see us in the gauge
Stock speaker covers installed
Kalypso
Gorilla Monsoon
sohc hatch
Flushing, Queens NY
7-24-2007
| « Re: Start of my 1jz build (ngibson) | 11:21 AM 2/16/2009 |
looks great... I love everythingthe 3 pod gauge setup looks awkward...but its not a big deal.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (Kalypso123) | 8:03 AM 2/17/2009 |
Why do you think it looks awkward, if you don't mind me asking.I like it, saw one on another s13 at one point - wasn't as nice as mine, but I liked the idea a lot. I was going to put them on the A-pillar but I didn't want to worry about getting them stolen.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 6:08 PM 2/21/2009 |
I didn't do much today, I'm still waiting on a lot of parts to come in.Installed the shifter extension
Mounted intercooler
The holes for the piping has been bothering the hell out of me, so I fixed it.
Cut cardboard template
The material
Bend it down with a big #$^&ing hammer
Riveted in place. I forgot to take pics of the other side. I also treated that rust, rubber undercoated the bottom and spray painted the top.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 1:46 AM 3/2/2009 |
Got a BIG update here. Got my new rims
Glued the door panel fabric back on
Loosening flywheel to install rear main and ARP flywheel bolts
New rear main installed and pilot bearing
 The bracket for my Evo brembos was too thick, the backside of the caliper was rubbing the rotor, so I machined it down.
Tires mounted
Brakes installed
Time for 50mm over fenders
ngibson
90 s13
South Florida FL
5-4-2008
Rolling and ready for the engine!
Transmission on
 Lifted - notice my fancy shifter hole cover.
It was definitely a tight fit, hard to clear the firewall and the rad support while going down
And it started hitting the Suspension Techniques sway bar. Had to drop it down.
And she's in!
ngibson
90 s13
South Florida FL
5-4-2008
Notice how the engine looks a little tilted? It was, and the drive shaft wasn't straight along with the shifter, after a quick adjustment it all looked good.Before
 After
 Firewall clearance
Needed to make a spacer for the sway bar
I didn't take pics of the bracket after - I need to take them back out and adjust the size of the holes a little bit before the sway bar can be bolted back up perfectly. Sway bar clearance
1991ls13
s13 ls1 hatch
SacramentoISH ca
8-6-2008
| « Re: Start of my 1jz build (ngibson) | 3:24 PM 3/2/2009 |
dude, amazing work!! i love clean work like this. nice wheels, brakes, everthing. wish i had the hook ups like you do, fork lift etc. was going to go 1jz but i got the ls1 instead. i like your doing it right and not rushing
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (1991ls13) | 5:32 PM 3/2/2009 |
Thanks! Wait til you see a few other things I've got going in! I'll have another good update tomorrow.
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:40 AM 3/4/2009 |
Got a lot done yesterday. Spent the first half of the day repolishing the valve covers and intake mani. Made a lot of little brackets to mount everything.Group shot
 Here you can see the condition of the polishing
After a little touch up on runner number one
Sanded down the valve covers before polishing, went from 120 for the bigger scratches all the way up to 1500 in about 8 stages of grit before polish
After 1500 grit paper. Started to polish it
Wiring and intake mani installed
I painted just about every bolt before installing the parts
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 5:41 AM 3/4/2009 |
Ecu mounted
Bracket for the resistor pack
Installed my Koyo
$#%@#$ Fans don't clear. So I ordered pusher blade kit for them, just mount them on the other side of the rad
Boost Gauge sensor
fpr mounted
ngibson
90 s13
South Florida FL
5-4-2008
| « Re: Start of my 1jz build (ngibson) | 11:50 AM 3/15/2009 |
Small update - I'm really waiting on more parts, the sway bar spacers from Tech 2 and heater hoses. The turbo and over fenders will be here on Monday.Got my axles back from being rebuilt
 Mounted fuse box - all that wiring is going to be cleaned up more after I finish the little wiring I need to do still
Bought some of these clamps to clean up all my wiring, hoses, lines
Pusher fans and 240 auto to manual conversion line, this bolts straight up into the r154 slave cylinder. I did't wanna reuse the stock hardline, this looks much cleaner
More parts
 Dyed the door panels
And my downpipe:
Kalypso
Gorilla Monsoon
sohc hatch
Flushing, Queens NY
7-24-2007
| « Re: Start of my 1jz build (ngibson) | 1:28 AM 3/21/2009 |
dope!
Kalypso
Gorilla Monsoon
sohc hatch
Flushing, Queens NY
7-24-2007
| « Re: Start of my 1jz build (ngibson) | 1:54 AM 3/26/2009 |
| Quote, originally posted by ngibson » | | Why do you think it looks awkward, if you don't mind me asking. |
I never answered your question pardon: Its the way they're layoud out, instead of being in a straigt line, or a gride with 4 - 2 up 2 down. the triangle to me looks unbalanced I agree that the A pillar is wack, those always suck. doesnt matter much tho, go with what you've got
| First 1 2 > Last |
