Broadfield
NICO Electronics Sponsor
Online
1992 240sx
Normal IL
9-5-2006
| « Re: Advice on wiring an Audio PC into G35 Head Unit (Sentientbydesign) | 8:08 AM 10/11/2008 |
Does your radio have satellite radio or at least the button for it? If so, I sell a AUX input adapter for the G35. It plugs in to the back of your radio and has RCA inputs on it.
Toby Broadfield B&B Sound and Speed JL Audio Spks ----- Alpine HU's <----On Sale Items Viper Alarm Systems-----Remote Starters Alpine Amplifiers FIBERGLASS HOW TO!! All sales or technical inquiries: Toby.Broadfield@comcast.net 309-261-4827 Paypal ID: Toby.Broadfield@comcast.net
Sentientbydesign
Articles Manager
05 G35 6MT coupe, 00 Celica GT 5MT
Riverside CA
2-2-2005
| « Re: Advice on wiring an Audio PC into G35 Head Unit (Broadfield) | 9:32 AM 10/11/2008 |
I think there is an SSV button which controls some sort of audio gain and one that says "DISP"
SteveTheTech
Articles Manager
Alexandria VA
8-16-2008
| « Re: Advice on wiring an Audio PC into G35 Head Unit (Sentientbydesign) | 1:08 PM 10/11/2008 |
The sat function is activated by the AM/FM button. If you have it keep pressing the button and it is activated. Does the adapter work for the ones without the button.
---------------------- ---- NICO DIY Articles----------- NICO Forums----------- Active Topics
Broadfield
Online
1992 240sx
Normal IL
9-5-2006
| « Re: Advice on wiring an Audio PC into G35 Head Unit (SteveTheTech) | 9:58 AM 10/13/2008 |
| Quote, originally posted by SteveTheTech » | | The sat function is activated by the AM/FM button. If you have it keep pressing the button and it is activated. Does the adapter work for the ones without the button. |
The radio has to have at least the option for satellite radio..... as the adapter uses that input for audio into the radio.
Sentientbydesign
Articles Manager
Riverside CA
2-2-2005
| « Re: Advice on wiring an Audio PC into G35 Head Unit (Broadfield) | 11:15 AM 10/13/2008 |
Hmmm. In that case, I'm not sure. I'll have to do some research.
SteveTheTech
Articles Manager
Alexandria VA
8-16-2008
| « Re: Advice on wiring an Audio PC into G35 Head Unit (Sentientbydesign) | 3:19 PM 10/13/2008 |
Nate, all 03+ Infiniti models have availability to add satellite service. They are already prewired with a bus connector in the trunk.
Sentientbydesign
Articles Manager
Riverside CA
2-2-2005
| « Re: Advice on wiring an Audio PC into G35 Head Unit (SteveTheTech) | 3:41 PM 10/13/2008 |
Gracias
villybhakta
2003 Infiniti G35
Houston TX
10-21-2008
I've doen the same thing. The computer install is awesome. Right now, my sounds comes thru a cassette adapter. One day I would like to us an AUX adapter.I do have a SAT button my head unit, but it doesn't do anything. So to use the aux adapter do I need to install a satellite radio tuner to get the button to become active and then install an auxiliary adapter?
Broadfield
Online
1992 240sx
Normal IL
9-5-2006
| « Re: (villybhakta) | 11:19 AM 10/21/2008 |
Nope, you only need to buy the adapter. It will plug into where the satellite tuner goes.Toby
villybhakta
2003 Infiniti G35
Houston TX
10-21-2008
I just picked up a PAC AAI-NIS2. I'll install it and let you guys know how it goes.
villybhakta
2003 Infiniti G35
Houston TX
10-21-2008
After installation, i'm still getting nothing. I push the SAT button and it doesn't do anything. The screen still doesn't say anything. Note, that all the other functions work as they normally would. What do you think could be the problem?
Broadfield
Online
1992 240sx
Normal IL
9-5-2006
| « Re: (villybhakta) | 3:06 PM 10/22/2008 |
I don't usually use PAC, so is there any dip switch settings you may have set incorrect? If not, call PAC tech support.Do you follow these instructions? Operation: G35 with SAT button. 1. Turn the factory radio on. Press and release the SAT button until SR2 is selected (in some cases, SR1 may have to be selected). Press Preset 1 to enter [Aux 1] or Preset 2 to select [Aux 2]. Preset 3 to 6 will select normal satellite presets. 2. Pressing the Mode button on the steering wheel will scroll through CD, Tape AM, FM1, FM2, SR1 and SR2. 3. Pressing CD, Tape, FM/AM will exit out of Aux mode, turning off the remote wire.
villybhakta
2003 Infiniti G35
Houston TX
10-21-2008
| « Re: (Broadfield) | 4:25 PM 10/22/2008 |
There are no DIP switches or jumpers or anything of that sort. On the actual unit there is only one switch: SAT or NO SAT. This switch is used if you have OEM sat tuner installed. I've contacted PAC and they said the problem probably has to do with your HU if I was sure I installed it correctly. I've been to the dealership, but they say that they can't do anything unless I allow( and pay for) them to install a sat tuner ( 900 bucks), then if they find a problem with the Headunit they'll go from there. I've searched alot of forums and most users that talk about satellite radio and g35s say that w/o the tuner they're headunits read " NO SAT" or "SAT NOT INSTALLED" when they try to push the SAT button. When I push it my headunit doesn't say anything. On the head unit I still can't get to SR-1, because the SAT button doesn't do anything.
Sentientbydesign
Articles Manager
Riverside CA
2-2-2005
| « Re: (villybhakta) | 11:17 AM 10/27/2008 |
Is it possible that the PAC adapter needs to be plugged into the SAT connector in the trunk?
