WhiteyClay wrote:03 sedan. 3 days ago i was driving with the ac on and all of a sudden A/C went full blast and buttons wasnt working. I pulled over and reseted the ECU ( by disconnecting neg. and pos. and touching them for a sec.)It fixed the problem for a minute. then about one hour later same thing happened, so i just let it blast and after like 5 min i pressed the OFF button and everything went back to normal. I was driving yesterday all day and all was fine.Did anyone encountered this problem before and know a fox to it?
thanks
If this happens as a temporary fix you can smack your center console where the radio is on the side and it may make it work again for a brief time. I had to do this until I finally gave up and did a DD swap. Dealer wouldn't cover my unit since I had an aftermarket alarm system mounted in the dash.....
