Thamm
1989 240sx slushbox
334 AL
12-26-2007
| « Re: question about gas mileage (ahawley22) | 12:58 PM 9/4/2008 |
You are probably getting around 14-15 mpg if you are getting 226 on a full tank. I seen some that get low to mid 20s. Depends how you drive and if you get it tuned regularly.
The Alabama single slamma! Project Red XIII-Summer 2009 hopefully.......
ahawley22
1991 Nissan 240sx
Northville New York
6-14-2008
| « Re: question about gas mileage (Thamm) | 1:02 PM 9/4/2008 |
noo i didnt run out at 226 i wanna know what i can run it until it runs out i just stopped at 226
Thamm
1989 240sx slushbox
334 AL
12-26-2007
| « Re: question about gas mileage (ahawley22) | 1:10 PM 9/4/2008 |
Oh then I'm not sure then. With the 6 gallons you fill up you can probably get between 250-280.
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
i can get 300 before my gauge is just a little above the Empty. does that little gas light work?
 HorsePower = rpm x Torque ...................5252(constant)
ahawley22
1991 Nissan 240sx
Northville New York
6-14-2008
| « Re: (-RJ-) | 3:23 PM 9/4/2008 |
i have no idea...i havnet gotten it down low enough yet...and im not sure how many miles ive got left once it comes on
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
have you tried fixing your problem? there is a cylinder inside the gas tank that tells how much gas you have.
Still NA
winnetka Ca
8-26-2007
| « Re: (-RJ-) | 5:44 PM 9/8/2008 |
My gas light has only come on once and i've never seen it again. Even when it was empty.
monkeyman9630
Findlay Oh
8-22-2008
I get between 280 and 330, dependin on my drivin style and if its mostly highway or city
Ajax
1991 240sx SE
Minneapolis MN
3-12-2003
Keep track of what your gas mileage is- the real way. Keep track of how many miles you've driven, then fill up the tank and find out how many gallons you've used. Divide, then conquer. Then just reset your odometer and you should be able to figure out how far you can go. Your 91's gas tank will hold 15.9 gallons.
1991 240sx SE hatch w/ VLSD
drifter92
1995 Nissan 240sx KA24DE
Victoria Texas
2-11-2008
I have a 95 s14 with 85000miles and i get about 19 miles per gallon. i go about 285 miles each time between fill ups. My exhaust smells like gas bad and my car backfires at 2900 RPMS consistently on deceleration. My transmission is automatic. Any tips anyone?
240tyler
93 nissan 240sx
columbia sc
9-14-2008
my 240 holds 13-14 gallon tank. i get around 20-22 mpg. driven good or gettin on it. i usually get round 280-300 on a tank. a can break over 300 and the gas light will come on
BMAR240SX
1993 240sx Coupe
QUEENS NY
8-21-2006
| « Re: (240tyler) | 8:14 PM 9/14/2008 |
I got 100 for some reason i or maybe less i don't know what is going on I need to do a tune on seriously
Ajax
1991 240sx SE
Minneapolis MN
3-12-2003
| « Re: (240tyler) | 8:31 AM 9/15/2008 |
| Quote, originally posted by 240tyler » | | my 240 holds 13-14 gallon tank. i get around 20-22 mpg. driven good or gettin on it. i usually get round 280-300 on a tank. a can break over 300 and the gas light will come on |
Your '93 s13 gas tank holds 15.9 gallons. The low fuel light should come on with about 2 gallons left, although the sensors for this light are not always accurate (also dependant on how fuel is sloshing around in the tank, and whether the car is level, etc). 20-22 does seem a little low, but it depends on how you're driving it. Is it short distances on city streets? Is it more than 10 minutes at a time at higher speeds? All these factors come into play as well.
drifter92
Victoria Texas
2-11-2008
i am getting around 17mpg now, i replaced my spark plugs and today i put some Gumout Fuel System Cleaner in it...it bogs on takeoff and the exhaust smells like a tank of gas, anyone know what the deal is?
janda240sx
1995 240sx se
Statesboro ga
9-30-2007
| « Re: (drifter92) | 10:52 PM 11/18/2008 |
I get anywhere b/w 25-30 mpg mixed city/hgwy driving and thats with no rear O2 sensor at all. If I replaced that sensor it might get even better. I usually go about 350 miles before i fill up.
  WTB: Navan Front Bumper!!!!
