Okay, I have read all of the posts when I searched this forum.The comments that the whole CD will record in 10 minutes (4 songs) is not holding true for me.
I found these comments on another website. I DO NOT see a progress in the lower corner. My little record "red dot" stays on the entire cd. What have I not set? I thought I turned on the auto record function
Quote from 1st post:
Remember that it rips the CD to the Music Box in under 10 minutes, so pretty well as fast as you burn them you can RIP them to the G35. The easiest way is to set the Music box to AUTO-RIP when inserted. After you insert the record indictor will light and you will see the progress 10/18..11/18..12/18 etc. when the record light stop. Pop that plate and move on.
Quote from 2nd post:
Also, if you are listening to the CD as it is being ripped, you will notice in the lower left corner a progress indicator; it will save 1/10 (if the CD has 10 tracks, for example), then 2/10, 3/10, etc. Once that completes you are free to change tracks, etc. Like adamr001 said, it usually finishes for me around the 3rd song, maybe the 4th if it's a full CD.
