 Did someone say "Baller" lol.....First  1 2 3 4 5 6 >  Last
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
  CA18DET Build...
Seeing as though there are a number of build threads on here and mine is now at about 75% completion, it may be time to let it out so to speak... I chose this forum as I believe it won't be wasted, I would like to encourage some decent conversation about it, and constructive critiscm is always listened too (maybe something I have missed)...
I had a thread earlier with a pic of the headwork performed thus far, unfortunately the goal posts were moved with the valvetrain and I have no more new photos, but rest assured my garage is filled with gear to assemble, apart from the motor which is still being engineered...
Only a selected few have known about this build for several months, I have had a lot of help from a mate who has been fantastic to bounce ideas off, to provide technical advice and even source some crucial parts from Japan, lots of kudos his way
I know the calculated hp but only based on ca valves (no-one would believe me if I post it), I also know the current head flow rating (again on the ca valves) but I should have it on the rollers in the next 5-6 weeks for the real "down to business" end of the scale..
I am not after kudos, I just want to share what I have accomplished so far, I will provide more pictures as I am assembling it all together...
Engine+supporting modifications:
1.75:1 Rising Rate Fuel Regulator
2L Surge Tank
3" Xforce Catback
3/8" Aluminium Fuel Lines - Dual Feed and Return + Supported Fittings and Braided Lines
ACL Race Bearings - Tri Metal Technology
Ajusa Complete Gasket Kit
Aftermarket Plenum - PNT_Performance Port Matched
Apexi Power Intake Pod Filter
Arias 40 Thou Forged Pistons
ARP Flywheel Bolts
ARP Head Studs
ARP Main Studs
ARP 2000 Rod Bolts
ASI Aluminium 52mm Radiator + Apexi Cap + 16" Thermo
Block Precision Prepped and Grout Filled
Cometic Exhaust Gaskets
Cometic Metal Head Gasket
Conversion to 90% clampless water lines (all dash fittings, bungs welded where required)
Crankshaft Cryogenically Treated and Nitrided
Custom Dump Pipe with Routed External Gate
Custom Top Mount Steampipe Exhuast Manifold
Dean Tighe Customised Solid Profile Billet Camshafts
Dual billet fuel filters
Dual bosch 044 external fuel pumps
Exhaust Manifold Ported and Matched
OS Giken Twin Plate (For now)
Extreme Billet Lightened Flywheel
Full Engine Balance
Genuine HKS External Wastegate
Genuine Hybrid Front Mount Intercooler
Genuine Nissan Oil Pump
Genuine Nissan Timing Tensioner and Idler
Genuine Nissan Valve Collets
Genuine Nissan Valve Guides
Greddy T67 - 25G Turbo - 10cm2 Housing
Greddy Timing Belt
Extensive Head Engineering - Custom Flow Ported and Flowbench Tested + Multi Angle Seats
Holley Dual outlet NOS purge
Holley NOS Single Fogger Wet System (shot not defined yet)
MrTurbo Billet Fuel Rail
Pro Comp Coilpacks
Microtech X4 Ignitor
New Water Pump
Niscort performance oil scraper
Nismo Clutch Pivot
Nismo Engine Mounts
Nismo Gearbox Mount
Nistune ECU to be mapped by DrDrift
Omori Oil Relocator
Ported and flowed secondary runners
SARD 1000cc Injectors (moved to runners on underside of plenum)
Secondary pick up billet fuel filter
Spool Forged Rods
Supertech RB25 14.5mm Lift Dual Valve Springs
Supertech RB25 Iconel Exhaust Valves
Supertech RB25 Solid Lifters + Shims
Supertech RB25 Nitrided Inlet Valves
Supertech Titanium Retainers
Tomei Adjustable Cam Gears
Tomei Z32 AFM Plug
Total Seal Gapless First (Compression) and Second (Scraper) Rings - ACL Oil Ring
Walbro 255L Fuel Pickup
XF Falcon Throttlebody (You guys in the states probaly wont know this but size is 68mm)
Z32 AFM (May change to ford lightning as Z32 may max out based on calculated output)
There are also a lot of cosmetic and interior modifications already performed that I will update with at a later stage....
Please enjoy the pics, the head requires more machining for the RB valves..
Cheers
Modified by meminto at 4:17 PM 8/27/2008
Modified by meminto at 3:58 AM 9/15/2008
Project "Baller"
http://forums.nicoclub.com/zer...r-lol
Supported by:
Wes Engines - Lismore Australia
Ca_Silvia
Calgary
11-18-2005
Sick start man i can't wait to see it all wrapped up. I need more info on the following:
I'm not to familar with what these processes are can you shed some light on them. Also you said you moved your injectors to the underside of the plenum. Do you have pics of there placement and what you did to the stock injector locations?
Cheers
EDIT: What are the specs on the cams you are running?
Aaron
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Sorry mate all specs on cam profiling, flow rates are pretty well under wraps until its all completed...
Block has been thouroughly prepared, grout filling is to stop bore flex (strengthening the block)..
No pics of anything else so far, I cannot take full credit for the clampless fittings process as I had help, however I am also keeping that process under wraps.. until its all completed..
I am happy to provide more info once everything is complete to help the broader CA community, but I also need to be a little selfish first
Cheers
ca18detgabby
92 s13 ca18det, 03 G35
lake mary fl
2-10-2007
 « Re: (meminto)
sounds amazing
tease........ you know you can share more
way to show it up for the ca family ....... kinda anyways
Quote, originally posted by r34 gtr »
Who gets rid of their CA's? People who suck, thats who.
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
More will come in time, no bowing down though, just happy to share the creation
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
 « More Pics
Some more gear arrived today, all the valvetrain arrived...
Dual valve spring..
RB25 exhaust valve is on the left.. (CA on right)
On the inlet its not very clear, RB on left is +1mm..
Solid Lifter..
Titanium Retainer (Although I think its a little bling more than anything)..
All up the entire valve train will only weigh 2168 grams (not inlcuding valve guides, cams or shims) I will need to weigh the stock setup..
Cheers
Ca_Silvia
Calgary
11-18-2005
Ya man "baller" is the right word
r34 gtr
ugly black 89 240sx hatchback
Huntsvegas AL
12-29-2002
Daaaaaaamn!
I'm like the Gangstalicious of NICO.
Quote, originally posted by Jesda »
Side note: People in the mortgage industry do a lot of cocaine.
Quote, originally posted by float6969 »
It's not that I think he's retarded. It's that I was the one that gave him his gold medal at the special olympics. I KNOW tim is retarded. I hope I never meet him in real life actually. I'm like 6'2" 185lbs. Tim is prob like 6'7" 300lbs and eats live baby sheep for snacks during the day.
tom@ica
89 240sx
Palmdale CA
9-9-2007
 « Re: CA18DET Build... (meminto)
Wow nice build! Puts mine to shame! http://forums.nicoclub.com/zerothread?id=314311&postid=3859900
What size AN are these?
MeanGreenS13
1993 Nissan 240sx
Vero Beach FL
8-20-2005
 « Re: CA18DET Build... (tom@ica)
if i had to guess personally, id say -8. ive got -8 on mine right now
1993 Nissan 240sx - CA18DET - SC61 60 Trim, 750cc Injectors, 44mm Gate
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Correct they are dash 8 fittings...
The build consists of multiple dash fittings from dash 3 right up to dash 12 for a variety of cooling, brake, powersteering, fuel and oil lines..
heheh and baller was a humourous spin on the build itself
Modified by meminto at 6:58 PM 8/26/2008
ks13
89 Silvia K's
Southern NH
9-3-2006
 « Re: (meminto)
daaang building engines like that looks like Dee's got some competition now!
DALAZ_68
240sx
Los Angeles CA
4-9-2007
 « Re: More Pics (meminto)
Quote, originally posted by meminto »
Dual valve spring..
Solid Lifter..
Cheers
dare i ask....how are u gonna use the RB valve....boring?
what was cost... cuz im getting close to my 5k goal for my rebuild
but i dont know if i should wait till the motor blows
1990 240sx
CA18DET 32k miles
Greddy FMIC
R32 VLSD
NiSmO tranny and engine mounts
NiSmO CA strut bar
SoOn tO cOmE : honestly, i just dont know anymore
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
The RB valve was chosen for its stem length (still needs to be machined to suit the lift), plusses are the extra sufrace areas of the valve heads..
The extra surface area of the exhaust valve head interested me the most as it will increase the efficiency of the exhaust flow (with ca valves it was 83% efficiency at peak flow)... but yeah boring will be required...
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
 « Another Pic...
These arrived today, last pic for a while going to be three or so weeks to finish off the engineering, then I will assemble the motor..
I didn't grasp the size of the MSD Coils until they arrived, they are insanely big...
NUT-CSE
1988 Nissan Exa
Sydney
3-11-2007
This is porn!!!!
Im collecting parts myself at the moment but nothing compared to you.
Keep the pics coming!
Nunook
nowhere NY
9-16-2004
props for the build so far.
The only thing i see to watch out for is the ajusa gaskets. I just did a valve job on mine with the ajusa gaskets and fitment wasnt that good on the intake gaskets for example. I should've gone with felpro.
Rin5
180sx at heart with a CA18DET core.
Dover DE
4-10-2008
 « Re: (NUT-CSE)
Quote, originally posted by NUT-CSE »
This is porn!!!!
Pass the lube!!
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
 « Re: (Rin5)
Cheers for that, will keep an eye on it..
I actually bought a gen nissan intake mani gasket, but its going to need modification...
ks13
89 Silvia K's
Southern NH
9-3-2006
 « Re: (meminto)
are those aligning pins on the head something you added for the intake mani, or is that nissan standard for the 4 port head?
Greg
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
 « Re: (ks13)
Hi Greg,
The dowels have been added by my engineer to ensure the correct alignment, they are not from factory..
It is also an eight port head, not a four port... its just had a lot of material removed..
Cheers
boost_boy
1990 sentra w/ CA18DET
Miami Fl
11-14-2002
 « Re: (ks13)
Quote, originally posted by ks13 »
So do you, my friend. Don't think I don't know what you're sitting on . But anyways, nice stash "meminto" and I can't wait till you get yours on the rollers as well. This ought to be interesting when everyone get their bling-bling CAs out of their garages. I'm on a HP chase and so is Overboosted180 who's project is again in my hands and pack some of the same goodies as us bling-kings(per say). Keep 'em coming guys...........
Dee
Who's selling their CA18 next ?
Forged pistons are no insurance for ignorance .
Spending money foolishly doesn't equate to a high hp car .
Being cheap all the time equates to a waste of time
And lastly, I'm not done; for I've only just begun, so stay tuned
Dee
ks13
89 Silvia K's
Southern NH
9-3-2006
 « Re: (boost_boy)
r34 gtr
Huntsvegas AL
12-29-2002
Yeah, I have pictures of that beast in Greg's garage. Its one nasty looking four banger.
MeanGreenS13
1993 Nissan 240sx
Vero Beach FL
8-20-2005
 « Re: CA18DET Build... (MeanGreenS13)
wish mine was so extravagent haha ill stick to my 750s and SC61 for now haha
ks13
89 Silvia K's
Southern NH
9-3-2006
hello phil.
remember that solid lifter head you were sposed to score.........lol
LOL
AAAHAHAHAHAHA!
aah sorry bout that mate, had to get that outta my system.
boost_boy
Miami Fl
11-14-2002
 « Re: CA18DET Build... (ks13)
hello phil.
LOL
AAAHAHAHAHAHA!
You're an @ss for rubbing that in like that . But it is what is and what a score you got as well .
Dee
MeanGreenS13
1993 Nissan 240sx
Vero Beach FL
8-20-2005
hey greg, choke on a dick and die. Love ya! MUAH!
ks13
89 Silvia K's
Southern NH
9-3-2006
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Not much else has happened...
The motor should be ready to assemble within 2 weeks, the cams should be with my engineer next week..
The duration is not as agressive as first thought, however the lift is a little more agressive...
I am awaiting the last of my items and there will be some adhoc bits n pieces that will need ordering I am sure... mostly the odd dash fitting that I havent taken into account, considering I now have well over 100 fittings lol
OS Giken twin plate clutch has been sourced, the extreme setup I had would have been ripped to shreds..
I will run the manual box until it fails (I am hoping to get at least a couple of runs out of it) then I will modify a decent auto to suit...
Cheers..
ca18detgabby
lake mary fl
2-10-2007
 « Re: (meminto)
why now z32 trans?
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Nah I havent decided yet, I am looking at options from local V8 items... Not from a japanese car as such...
NUT-CSE
1988 Nissan Exa
Sydney
3-11-2007
So what power are you expecting?
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
It has been calculated, but its only a figure on paper...
D_Stirls
Nissan 180sx 1990 Ca18det
Adelaide SA
9-1-2008
As for a box you should look at a T56. "Corporal" Cristian Pickering was running one in the CTS Drift car for years and i believe the same trans is used in Vipers so it should be able to handle to torque you'll be putting out.
CA18DET + GT2871R Goodness = 216rwKW @16psi
Click For My Built Thread
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Cheers dale, but I want to go back to an auto eventually...
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
 « pics
Some more pics of gear..
Although pulled apart for checking the OS Giken twin plate...
Thirsty buggers these - 1000cc Sards...
To give an idea of the scope of some of the relibility factors I have taken into consideration
This is all fuel delivery hardware..
This is the cooling hardware + pcv and catch tank hardware..
Although it doesnt look like a great deal, I have no need for 1/2 of the turbo water lines, I have redesigned the system to suit..
These are the various sized braided hose...
These are the 3/8" alum lines and another braided hose size...
This is the powersteering and brake lines + fittings (except the two das 12 tee flares, thats for the cooling)...
And this is our dog... no real modification necessary, although it would be better if he didnt snore..
Countdown is two weeks until assembly...
ca18detgabby
lake mary fl
2-10-2007
 « Re: pics (meminto)
build looks more amazing everytime I open this thread
and OMG!your puppy is so cute!
ca18detgabby
lake mary fl
2-10-2007
 « Re: pics (ca18detgabby)
jw? is the 255 walbro good enough to feed those 1000CC injectors?
Zero260
91 240sx coupe
Madison WI
11-6-2005
if what i'm seeing in those pictures is correct. it looks like 2 walbro pumps will be suppling the fuel.
this build looks sick, what are you aiming for numbers?
Zero260 --- can never be fast enough
» Return to CA18DE / CA18DET Forum
