sajori
San Juan PR
9-5-2007
| « Re: She's picked up a filthy habit, smoking; such a dirty girl. (Clawhammer) | 11:08 AM 8/19/2008 |
rings
Driftnismo
93 240sx coupe Ka24de
Rockland maine
5-24-2008
| « Re: She's picked up a filthy habit, smoking; such a dirty girl. (Clawhammer) | 3:18 PM 8/19/2008 |
lmao, nice title, but ya I'm gonna go with rings, I have a bad third piston ring and it was smoking while driving, I've torn out my motor and tossed in my old KA24DE for the time being, just gonna rebuild my motor for fun
Clawhammer
Sir Rocksalot
RPS13
Gainesville/Clearwater FL
12-29-2006
Wouldn't it smoke all the time if it was the rings? Guess I'll have to find someone with a compression tester just to be sure.
crzykrackr
1991 240sx
Bowie Md
12-5-2006
| « Re: (Clawhammer) | 7:28 PM 8/19/2008 |
Mine did pretty much the same thing when my turbo was dying....
boro drift
'87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Lewiston Idaho
8-14-2008
| « Re: (Clawhammer) | 7:29 PM 8/19/2008 |
TURBO. I had the same problem. You get smoke at idle because the turbo is spinning so slowly, the oil has a chance to run out of the cartridge. When you rev it up, the seal will start working again,(turbo seals are like tiny piston rings). I put a new S15 turbo on my red top and it hasn't smoked since.
Clawhammer
Sir Rocksalot
RPS13
12-29-2006
I've been needing an extra kick in the *** to get an S15 turbo...
FlatBlackIan
NICO's Lumberjack
Flat Black S14 Zenki, Bright red Piggy.
Creepy cabin in the woods MN
12-23-2004
| « Re: (Clawhammer) | 8:20 PM 8/19/2008 |
I would put my money on a failed oil seal in the turbo. Whether you plan to rebuild your current turbo, or you plan to replace it, make sure to clean out the oil return line, the most common cause of blown turbo seals, is a restricted oil return.
Clawhammer
Sir Rocksalot
RPS13
12-29-2006
I guess my next question is, how long does she have?
FlatBlackIan
NICO's Lumberjack
12-23-2004
| « Re: (Clawhammer) | 9:31 PM 8/19/2008 |
| Quote, originally posted by Clawhammer » | | I guess my next question is, how long does she have? |
Keep an eye on your oil level, when my first turbo took a dump, I drove it for about 10,000 miles until I could afford a new one, it only smoked at idle, more when it was hot. Check your hot pipe, its likely the oil is only leaking into the exhaust, if thats the case, all you are going to do by driving it, is destroy you catalytic converter and oxygen sensor.
boro drift
Lewiston Idaho
8-14-2008
| « Re: (Clawhammer) | 9:37 PM 8/19/2008 |
FRsport.com sells the S15 turbo in a kit. It comes with everything you need to install it. The most important thing is the oil fitting on the turbo. It has a smaller orafice becauase a ball bearing turbo needs less oil than a journal bearing turbo. Also, once the cartridge of a turbo starts leaking oil out of either end, it's done. Turbo City told me this but I rebuilt the turbo on my Supra anyway. It slowed the consumption down but didn't stop it.
FlatBlackIan
NICO's Lumberjack
12-23-2004
| « Re: (boro drift) | 9:44 PM 8/19/2008 |
| Quote, originally posted by boro drift » | | Also, once the cartridge of a turbo starts leaking oil out of either end, it's done. Turbo City told me this but I rebuilt the turbo on my Supra anyway. It slowed the consumption down but didn't stop it. |
Thats not true at all. I rebuilt the T25 on my car now, it doesn't burn a drop of oil, and its been on the motor for 2 years and around 30,000 miles. Ive rebuilt more than a handful of turbos with great success. As long as you replace the seals, bearings and thrust plate, as well as clean everything properly, there is no reason a journal bearing turbo cannot be rebuilt.
boro drift
Lewiston Idaho
8-14-2008
| « Re: (FlatBlackIan) | 10:01 PM 8/19/2008 |
I stand corrected. Maybe my turbo was to far gone, or I damaged a seal.
91SilviaKs
1991 Nissan Silvia K's
Indy IN
2-13-2008
| « Re: (boro drift) | 10:18 PM 8/19/2008 |
not to threadjack, but I am having a similar problem. My car idles perfect runs like a stocker but everyonce and I while when Im grannying around, I get tons of smoke out of the exhaust at idle, as soon as I get moving, no more smoke. It is white smoke, but doesnt smell like coolant. I did get out in traffic to smell it afew days ago. Any ideas... **ENDING THREADJACK**
boro drift
Lewiston Idaho
8-14-2008
| « Re: (91SilviaKs) | 10:25 PM 8/19/2008 |
Exact same thing my car did. It still ran good, but would smoke at idle when comming to a stop. After I replaced my turbo it hasn't smoked since.
Clawhammer
Sir Rocksalot
RPS13
12-29-2006
Looks like we've all had or have the same problem. She runs and idles great just like you guys.I checked my hotpipe last week when I first noticed this and it's oil free. I don't have a cat and I'm suspicious my O2 doesn't work anyway. I actually first noticed this a few months ago. I got off the interstate and was sitting on the off ramp waiting for the light when a giant plume of smoke flew past my window. When I got to my destination I got out and waited for smoke, revved it a few times and got nothing. I just assumed it was a car behind me. Then nothing till last week when this started (again). Thanks guys.
91SilviaKs
Indy IN
2-13-2008
| « Re: (Clawhammer) | 10:51 PM 8/19/2008 |
yeah but the finny thing is mine only does it like once every couple of weeks or so, very sparingly....I think that for some reason mine loads up on fuel for some reason every once and a while...BTW I'm not running a cat either...Rich
FlatBlackIan
NICO's Lumberjack
12-23-2004
| « Re: (91SilviaKs) | 7:55 AM 8/20/2008 |
| Quote, originally posted by 91SilviaKs » | | yeah but the finny thing is mine only does it like once every couple of weeks or so, very sparingly....I think that for some reason mine loads up on fuel for some reason every once and a while...BTW I'm not running a cat either... Rich |
Sporadic oil leakage is a common symptom of a restricted oil drain.
