 Idle at 1500rpm,very bad throttle responce, very rough, stuttering. I SEARCHED!!
redsx13
93 240sx
LA CA
8-3-2007
Hi, I recently swapped in a red top SR. Upon start up it was found to have some trouble running. Like the post says, i did SEARCH, but i was unable to come up with any answers for the unique problems i am having.
to the best of my abilities i will give you guys a brief rundown of the issues the car is having.
1.fluctuating idle- starts out around 2000 rpm's and then drops down to about 600 rpm's during normal running temp. but sometimes the rpm's will just stay at 1500 and not drop down at all. The idle speed has a mind of its own
2. very rough- when the motor is at lower rpms (500-1000 rpm's) it shakes quite a bit, it even feels like it may die. airflow out of the tail pipe is also inconsistent.
here is the weird part-
3. Strange throttle response- when the throttle is momentarily depressed (to about 1/4 of the way down) car will bog, rpm's will go down for a second, but then it will rev up just fine. (car will rev all the way to red line.)
4. After the car is revved up, the idle will bounce around for a bit, idle will go down 400, come back to 1500, go down to 500, back up to 1000 and so forth. before finally leveling off.
5.The car smells strongly of fumes- so much so that it makes it undriveable, im not kidding! (may just be an exhaust leak, or culd be running rich)
6. very low boost- reading about 1-2 psi of boost. (may be an exhaust leak/ mis-adjusted bov)
here are a list of parts that came in the clip, and installed on the motor when i got it.
-maf (i think it is from an older skyline)
-larger injectors (unsure of cc or brand)
-s14 turbo
-ecu retune (new PROM chip)
here is a list of what i have installed that may affect motor
-NGK plugs (checked gap)
-greddy fmic (type RS)
-greddy hot pipe and RS BOV (i need help to tune bov)
As for the vacuum lines,
Please help me!
i just need some ideas and how to check them
-TPS?
-Timing?
-vacuum lines?
-Maf?
-running lean/ rich?
-IACV?
Modified by redsx13 at 12:08 AM 8/23/2008
Quote, originally posted by wesley9k2 »
i have kids in my home and they pour some water on carpet its an expensive carpet so i cannot take risk by restoring it with anyone with little experience so plz let me know if anyone of you know the experienced one
Quote, originally posted by ldstang50 »
Are you serious? You need to know how to get water off your carpet????
blinker_fluid
1991 240sx fastback, 2000 maxima se
toms river nj
2-19-2007
 « Re: Idle at 1500rpm,very bad throttle responce, very rough, stutte ... (redsx13)
possible problems...
1. Maf not wired correctly
2. ecu not tuned for maf and/or injectors
3. vaccum leak
i would check these first along with the other things you've listed. Try pulling the codes from the ecu to see if anything pops up. Make sure all spark plugs are firing along with the injectors.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: Idle at 1500rpm,very bad throttle responce ... (blinker_fluid)
Quote, originally posted by blinker_fluid »
Possible, but i wired it up exactly the way it was on the clip. and when you pull the plug off the maf, you can really feel the difference. (how can i check wiring?)
Also possible, but would it really car to idle that high? and thats the way the clip came. and i highly doubt someone did a upgraded injector swap after the car was chopped in half.
vaccum leak
i have triple checked all hoses that i know of (there are not that many)
all injectors are firing, not sure about plugs yet, I feel so bad starting this engine, it sounds like its hateing life!
i diddnt know it was possable to check codes on an SR for some reason(i know the ecu can, but i thought the swap rendered that feature useless)
i will check codes and let you know
redsx13
93 240sx
LA CA
8-3-2007
just checked codes....
only one i got was a 13- coolent temp sensor
i cleared the codes and started the car again, now all i am gitting is a 55(all ok)
Modified by redsx13 at 8:31 PM 8/17/2008
duffman1278
Moe Man
89 240sx Hatch, the wildcats!
The Mutha Land ca
4-1-2007
Sounds like a boost leak to me, run a DIY boost leak tester, its very simple and will save you a bunch of headaches.
Also, it could be that the ECU isn't tuned for it. To check that, you'd have to have a shop with a dyno test that out. I had the same problem. This shop told me in order for them to check what was on the ECU, they'd have to check it on the dyno.
http://forums.nicoclub.com/zerothread?id=340137 For Sale!! Rotors, Shocks, Hubs!
jr_ss
Cruis'n for a Bruis'n
95' S14
Venice Fl
11-26-2005
Sounds like a bad MAF to me. You said you unplugged it and it ran better? Did the idling smooth out?
You need to get a FSM... Heavythrottle sells them, or I might be able to transfer the files from my disc to the comp then send them to you if you want...
l 95' S14 l S14 Sr20 l Whiteline l Cusco l Z32 brakes l 350z Rays l
l Jdm Aero l SPL l Fujitsubo l RPS l Apexi l DSS l Defi l Tomei l
OG ZMFL member #1
heavythrottle
1993 240SX Convertible
Mid Hudson Region NY
8-13-2008
 « Re: (jr_ss)
Check the throttle stop screw - make sure it is closing 100%.
Also check for spark in all 4 cyls - SR runs surprisingly well on 3 cyls.
_____________________
Jeff H
http://www.heavythrottle.com
93 Convertible SR
blinker_fluid
toms river nj
2-19-2007
Quote, originally posted by redsx13 »
only one i got was a 13- collent temp sensor
The cts can cause the high idle problem, as for the maf you should try cleaning it with CRC maf spray and check the wiring against heavythrottle's diagram http://www.srownersclub.com/faq/faq_mafs.asp. While your looking at the harness get a multi-meter and check the wires, black=ground, black/white=12v with the ignition on, white= somewhere around 1v with the engine running at a normal idle higher rpms gives higher voltage.
91SilviaKs
1991 Nissan Silvia K's
Indy IN
2-13-2008
+1
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (jr_ss)
Quote, originally posted by jr_ss »
no, it ran worse. but still had all the same problems it did with the maf plugged in.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (heavythrottle)
Quote, originally posted by heavythrottle »
like the diagram above shows, the throttle is closing 100%.
it is running on all 4 cyls.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (duffman1278)
Quote, originally posted by duffman1278 »
how do i check for a boost leak? let me know how, and i can make a boost leak tester. Btw, the car is very bare (no front bumper, relocated fuse boxes, no a/c, repainted bay)only the necessary stuff to get it started. so i can see all the fmic piping and connections; they all look fine.
I am also worried that the ECU may not be tuned to the car, but thats the ECU the car came with.(i opened the ecu up and it has a chip), shouldn't it run correctly??? In this condition, the car isnt even drivable, so how was it driving in Japan??
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (redsx13)
********UPDATE********
While testing some of the ideas mentioned above, I left the car running for awhile, and idle did drop down to around 600-700 rpms. at this point the car sunded like it was going to die, but miracuously i diddnt. it was stuttering very badly. This may no longer be an idle issue.
i will keep checking the rest of your guys ideas, and update you on my findings frequently.but for the mean time keep thoes ideas coming! you guys are very helpful. thankyou!
redsx13
93 240sx
LA CA
8-3-2007
while trying to fallow the diagram i noticed that my maf is not like the one from a z32 like the one pictured.
here is a pic of my maf (it used to have a connection piece with four holes that connected it to air box/filter, but that piece has been removed.
sorry for the cell phone pic
Modified by redsx13 at 11:17 PM 8/17/2008
redsx13
93 240sx
LA CA
8-3-2007
 « Re: Idle at 1500rpm,very bad throttle responce ... (redsx13)
come on, someone knows what kind of maf this is.
blinker_fluid
toms river nj
2-19-2007
need a better pic of the sticker
redsx13
93 240sx
LA CA
8-3-2007
Just found out that the motor was an automatic, tharefor it has a different tps than the manual. Does it sound like a TPS could cause this problem? Is there any wiring involved to adapt the auto tps to a manual? If so, whoever did the 5 speed swap may have screwed it up and that may be my problem.
Modified by redsx13 at 11:34 PM 8/20/2008
SpeedRacer1
1990 240SX, G35
Alexandria VA
7-26-2002
No thats not the issue. I have run an auto harness on my car for 6 years now.
That MAFS is NOT a Z32 MAFS, off the top of my head I want to say its early 90's Skyline Non-GTR or Maxima but I cant remember for sure. It sounds like your main problem is the ECU tuning for the MAFS, MAFS wiring, or MAFS itself.
nzmoman
240sx 2 of em' and always lookin for more
Atlanta GA
5-22-2006
 « Re: (SpeedRacer1)
what are the last three numbers on the code for that MAF?...
also make sure of a few things...
maf is flowing the correct direction,
there is no open port blowing air near your throttle or your IC piping. There is usually a large port on the cold pipe of FMIC kits that needs to be capped off.
and make sure that the vacuum line for your idle air system is connected somewhere before the throttle, but after the MAF. (usually a port on the FMIC also for this.)
if you can provide an overall picture of your engine bay. there are guys on here who can find a needle in a haystack, but a picture of a throttle won't do. Show us the actual throttle with all the lines connected before you go running to buy a new MAF or ECU. I think it sounds more like a boost because at idle MAF's are not working that hard and you did not say you were blowing smoke, (everytime I have seen the wrong MAF I have seen black smoke and stuttering)
current build: Copycat- Project Kouki:
SpeedRacer1
1990 240SX, G35
Alexandria VA
7-26-2002
The green tag should be 22680-02U00, its a skyline MAFS not proper for your setup. If the ECU was retuned for a Z32 MAFS then get a Z32 MAFS. Part number 22680-30P00, orangish sticker. If it was tuned for stock get a stock MAFS.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (nzmoman)
Quote, originally posted by nzmoman »
Im really starting to think that its the maf. As for the type of maf, the shop i bought it from says it is from a skyline.
maf is flowing in the proper direction, hole for stock bov on fmic is pluged,idle air hose is connected, i can get some pics of the engine bay tomarrow, but better yet, i will get you guys a video.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (redsx13)
*****update*****
I have just updated the my main description of the problem. I also added some helpful info.
Hijacker
240SX Moderator
'92 240sx Convertible
Olney IL
8-13-2003
After all this, you haven't verified if the ECU was tuned for that MAF or for a Z MAF. I'm in agreeance with Speed that your MAF is the culprit.
-Bart
Quote »
Hey wait. My balls don't hang too low yet
Stacey L. Childs, NICO Mom
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (Hijacker)
Quote, originally posted by Hijacker »
O, sry . i thought it was implied... Just to clairfy, I have not changed out any parts that would effect engine preformance. the only exeptions are the spark plugs, fmic, bov, and clutch. *I assume* that the ecu has been tuned for the skyline maf, larger injectors,and s14 turbo. because those parts came installed on the car.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (redsx13)
As for the roughness, no pinging, no exessive smoke, but it will bogg for a second when you give it some gas. other than that, it runs fine in the high rpms. If i had to describe the roughness at idle, it feels just like a sparkplug wire or injector is unplugged. but all the cylinders are firing.
Here are some things i have tried recently.
I was thinking it was timing, so i loosened the CAS and turned it w/o removing it. only thing that did was raise the idle up and down, but it still had the same roughness. then I was thinking TPS, so i unplugged it nothing happend, the car didnt run any different, even when the motor is revved up. (is that correct??) Then i was thinking 02 sensor, so i unplugged that and again, nothing happened (is that also correct??) this may be an unrelated problem, but i also have really really low boost (around 1-2 psi) and it smells like its running rich.
Someone back me up and tell me that it's true that unpluggng both the o2 sensor and tps should cause a noticable change in running condition!!!!
I am desperate!!! Tetsudatte kudasai!!!
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (redsx13)
***Update***
I just ended up bringing it to a shop. 2 days later the shop calls me to tell me the car is fixed and to pick it up. When i go to pick it up that afternoon, I dont recignize my own 240, why?, because my whole roof and hood are smashed in!!!!!!!!!!!! What do they say..... It looked like this when you brought it to us. WWWWTTTTTFFFFF!!!! After a closeer inspection, the damage resulted because SOMEONE forgot to put the hood pins back on when they took it for a test drive.
O... and you know how they said that they fixed the idle problem. thay diddnt!!!!!
They had an inshurance agent come out to look at the damage, and the agent tells them that the hood had been like that for a while because there was rust on the hood whare the paint had come off. I diddnt see the rust he was talking about, but that guy is wrong!!! that insurance agent should be fired!!!
What do i do??
Tulsa_S-13
1991 240sx
Stillwater Ok
6-19-2005
 « Re: (redsx13)
Oh bummer, that's a crappy situation.
Sounds like whatever shop you took it to is completely incompetent. It also sounds like they probably tuned it for a Z32 MAF as mentioned before.
Get your car out of there as soon as possible. I'm sure someone on here can point you to a shop thats local to that area.
Your best defense against a grizzly is to be with someone who runs slower than you.
Hijacker
240SX Moderator
Olney IL
8-13-2003
 « Re: (redsx13)
Your options are to either
a) threaten them with legal action. People tend to fold pretty quick when the words "my lawyer will be in touch soon" get thrown around.
b) get a lawyer involved. You won't come out ahead as legal fees are likely to eat up anything you could actually make. At least you'd have satisfaction for sticking it to an @sshole.
c) have your insurance pay for the damage. If you call it in to your insurance agency, and explain to your agent or claims adjuster that you didn't do this damage, and that the shop that did it is trying to pin it on you, they will likely talk to the shop's insurance agency and hopefully force them to pay for it.
Either or, get someone official involved quick. After so long, it becomes harder and harder to pin the blame on the real culprit. Also, take pictures. Lots of them. Make sure you get good shots of the exposed metal before it rusts. That's your real proof that you didn't do the damage. Surface rust starts to form pretty quickly depending on your area, and the condition of the metal, but deep seated rust is the real proof. If it's there, then they can claim you did it. If it isn't, then it's pretty obvious that damage wasn't done by you.
nzmoman
Atlanta GA
5-22-2006
 « Re: (Hijacker)
Call an attorney and do not pass go. Most shops can't afford legal battles and a good attorney will be able to get you enough to cover more than your car and get enough to be able to pad his own pockets, while keeping the shop accountable.
boro drift
'87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Lewiston Idaho
8-14-2008
 « Re: (nzmoman)
Yeah, don't drag your heels bro, take legal action immediatly. Sorry to hear about your car, I would have went berzerk.
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (boro drift)
Quote, originally posted by boro drift »
o, i did.
i got the car outa there, but im not sure if i want to go through the hassle of getting an attorney involved. its easy to say, but not as simple as you would think. the shop agreed to give me 200 bucks, but thats it. Plus, when you have a car that anything but stock, average people like insurance agents dont know that to think of it.
moulton712
ton of coupes, one hatch, all s13s
brunswick
9-9-2007
 « Re: (redsx13)
legal work is way easier than you think. i own a car audio shop and sometimes people try to stiff us. talk to the police and make them work for you. tell them you want to take them to small claims court. most of the time you pay nothing. represent yourself.
make the laws work for you. we all pay for this in our taxes, so use it.
btw, why haven't you disclosed the shop's name?
**** happens, did they make you sign any papers before you left your car?
like i make people sign a form before i accept a car, one part is saying any legal cost are to the customer, and we assume no responsibility. you'd be surprised how many people say we scratched their cars when it looks like they got into a fender bender. fuggin people
redsx13
93 240sx
LA CA
8-3-2007
 « Re: (moulton712)
the shops name is the Japaneese Auto Center in canoga park, california
» Return to SR20DET Forum (rear-drive)
Copyright © 2000-2008 by NICO
