 Door switch wiring help!!
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
I thought it was going to be easy to figure out, but failed. Maybe biggie or hijacker can help me. What I'm trying to achive is... I want to hook up something to this door switch, so it'll turn on and off just like interior lights. It turns off if you close the door and turns on if you open the door. There are 3 wires as you can see in the pics. Black, red/white and blue/white. What should I do? Please help! Thanks!
Eikon
Super Moderator
Online
'92 240sx 'vert with RB20
hidden
4-24-2004
 « Re: Door switch wiring help!! (94_240sx)
Black is ground obviously.
One of the two sends a signal when open and the other sends a signal when closed.
Get a multimeter and check for voltage through the wires when the switch is depressed and then not depressed.
Then splice the wire that gives you current when the switch is not depressed.. meaning the door is open. I'm not an electrical expert, but you should probably stick a fuse in line between your splice and your new electrical component just to be safe.
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
Hijacker
240SX Moderator
'92 240sx Convertible
Roanoke VA
8-13-2003
The door switch is supposed to be a one wire ordeal. Only a power wire goes in, and then it grounds out on the mounting screw. I have no clue what the other wires do, if anything on the verts. If you use the switch on the passenger side, it'll be a standard door switch.
EDIT: Finally found out what the other two wires do in the fold out. They're tied to the Timing Control Unit. My guess is that it tells the TCU to flash the seatbelt light if the door is opened when the car is on as it completes a circuit coming from the TCU. The red/white is the standard dome light wire, the blue/white must be the signal from the TCU and the black is obviously ground.
-Bart
Quote »
Hey wait. My balls don't hang too low yet
Stacey L. Childs, NICO Mom
biggie
Versa/240 Moderator
(2)93s SE coupe/LE vert / '07 Versa SL 6MT
Clemmons NC
7-24-2002
^ Should be it.
Depending on the device could run it to the dome light wiring as well.
'93 S13 Coupe SE - Needs work, KA-T one day
'93 S13 Vert LE - Project #2?
'07 Versa SL 6MT - commuter
Totalled '92 Coupe SE
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
 « Re: (biggie)
Thank you guys. I have a multi meter and test light, so I tried them all, but couldn't find. I think I've tried every possible combination. I'll try again tonight.
Quote, originally posted by biggie »
Is it hard to get to dome light wiring? Where's the easy access?
Hijacker
240SX Moderator
Roanoke VA
8-13-2003
All of the interior lights are chained together. You can use the kick panel lights if you feel like it.
The switch HAS to be screwed to the chassis to ground or else it doesn't complete the circuit. When I'm doing work that requires me to have the doors open for long periods and I don't feel like burning up the battery, I unscrew the switch a few turns.
Also, and this is my experience, when I try to manually ground the r/w wire to activate the circuit, I can never seem to get a strong enough ground to turn the lights on except past a very dim amount. I was checking which wires would be best to hook my keyless up to get dome light supervision, and I thought my lights had gone out because my test light was barely turning on when I grounded the r/w wire out at the passenger kick panel. My test light had an amazingly good ground, so my only guess is that without the switch doing the grounding, the system is bogged down from trying to run too many lights on a small ground via a test light or multimeter.
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
 « Re: (Hijacker)
Nope! I tried everything, but it didn't work. I ended up using dome light wiring on passenger side kick panel and it worked just fine. Thanks for all your help.
krash
1993 Nissan 240sx Convertible (W.I.P.)
Silver Spring MD
4-11-2005
 « Re: (94_240sx)
alright you got your answer, now spill it, What is this "device"?
Bored? check out my DevArt: krash51491.deviantart.com/
wmdavis007
1992 240SX Convertible
Rockingham NC
1-3-2006
Are you wiring in a switch so you can turn on your interior lights with the doors closed? If so please let me know...it's the one thing I don't like about my vert...no interior lights without opening the door. I hate not being able to find stuff at night going down the road.
http://www.cardomain.com/ride/3121382
DeXteR
Picture Police
93 sil40 vert- RIP 93 240sx vert- 94 pathfinder se v-6 4x4
Hemlock MI
9-26-2005
 « Re: Door switch wiring help!! (wmdavis007)
You do know that there are map lights in the rear view mirror, right?
Come vote for the 2009 Nico 240sxCONVERTIBLE.com calendar!
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
 « Re: Door switch wiring help!! (DeXteR)
Quote, originally posted by DeXteR »
Yes, bottom of rear view mirror, but not all verts have this. Mine has it though.
wmdavis007,
No, that's not it since I already have built in map lights in the rear view mirror. My interior is messy at the moment, but I'm almost there. I'll try to install everything back this weekend and post some pics sometime next week. You won't be disappointed.
Hijacker
240SX Moderator
Roanoke VA
8-13-2003
I had to order that mirror and wire it in myself. My car didn't even have the wiring for it. Way to go ASC!
Eikon
Super Moderator
Online
hidden
4-24-2004
 « Re: Door switch wiring help!! (Hijacker)
I don't have maplights in my mirror. I just use the moonlight to see what I need to see.
biggie
Versa/240 Moderator
Clemmons NC
7-24-2002
The dome light was pretty easy to get to, I pulled off one of the A pillars and then took off the strip that covered the dome light area.
Some pics when I did the install:
http://forums.nicoclub.com/zerothread?id=221045
We still never figured out which models got the map lights either.
That was one of the first additions I had to do. When doing my audio stuff we accedientally blew the TCS and I had no dash lights on a 5+hr drive back home in the dark, had to use a flashlight occasionally to see how fast I was going (since my cruise hasn't ever worked).
Hijacker
240SX Moderator
Roanoke VA
8-13-2003
I ran a power and ground down to a constant under the dash cluster for my map lights. It would have been easier if I had used the hot circuit off the interior lights circuit and just grounded the map lights to the top of the frame. Oh well, it's a good thing I like soldering.
I really want to find someone who can make a-pillar guage pods that replace the whole a-pillar piece. That would be freaking fantastic and I wouldn't have this mismtached guage pod staring me in the face. And I could hide the wires coming off of them easier.
» Return to 240SX Convertible Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
