| Quote, originally posted by Q45tech » |
A high flow low filtration air cleaner is not the best way to prove you are maintaining an engine to achieve longevity. The only way dirt and grit can get into and wear an engine [rings] is thru the non oem airfilter. |
So you're saying that the OEM air filter doesn't let anything but air into the engine? I'd like to see where you got that little ditty from.
