please help with L20B question (picture)
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
NeedMoreBoost
Car: 98 VW jetta VR6
im looking for a 510 and i found one of interest. i dont really understand the engine though. its a rebuilt L20 with L28 Flat Top pistons.Bored @86mm and L16 heads for high compression. can someone explain that setup? the L28 is the 280z i think but what is the L16
all info is greatly appreciated, thanksheres a picture of the engine (if that helps at all)
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Wow, What an engine in that thing!
Back then the L-series had interchangable parts. Timing gear part would swap over from engine to engine eith ease, cut down on production costs and frankly I thought it was genius. L28 pictons can be made to run in an L20 if the bore and stroke are set. I don't have my Datsun modifier handbook on me but I can look into this more if you'd like. An L16 is what the base 510 came with. There was also a SSS version which came with a racing head. The L20 was found in models like the 610, second-gen 510, 710, 620 and first year 720.
NeedMoreBoost
so do you know the original size of the L20? should i be woried about blowing head gaskets in the higher rpm's, because of the bigger bore?
thanks for the help
codyisbad
Car: '71 510 '90 300zx
Stock Bore is 85mm. A lot of different stock pistons will fit in there and there are a few different heads that will also work. How do you see how to drive that thing? I would put the carbs back under the hood.
Return to “Datsun 510 / Bluebird”
