vg30 turbo set up?
RB20drift240
Car: 92 240sx hb
where can i find a single turbo setup for my 1988 s12???
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
There aren't any kits that I know of.
The engine bay of the S12 is supposed to very tight making a turbo difficult to do. I have seen someone do a sort of rear mount setup on one in the past though. May also look into putting it in front of the engine if there's enough room with an e-fan setup. I've not got to see one personally so don't know how to best pull it off. Either way, it will definitely be a custom job.
RB20drift240
Car: 92 240sx hb
i already have a e fan on, i was thinking pulling the turbo manifolds off a 1st gen 300zx cuz they got the same engine
mtcookson
1992 Iinfiniti Q45
and much much more
The turbo manifold will definitely bolt to the engine, you'll just need to make sure you have the proper clearance. There is a crossover pipe that goes behind the engine, you'll need to make sure you have clearance between the engine and firewall for that. Also, you need to check for any possible clearance issues with the steering rack and/or motor mount where the turbo will sit.
RB20drift240
Car: 92 240sx hb
alright, do u know how big the stock turbo is on the 300zx
mtcookson
1992 Iinfiniti Q45
and much much more
Its only a T3 style so its rather small. I'd say its probably no bigger than 8 inches at its longest point... maybe closer to 6 inches. I have one in the garage, I'll try to get out there and measure it for you.
RB20drift240
Car: 92 240sx hb
alright thanks, do u have any idea of the biggest dimensions of a fmic i can fit on the s12?
mtcookson
1992 Iinfiniti Q45
and much much more
I'm not sure off hand... though you don't necessarily want to get the biggest one in there you can. You simply want the one that flows good and will handle the power you want. Too big and you can have slower spooling and potentially higher pressure losses. I like the units that http://www.treadstoneperformance.com sells, specifically the TRV series. That particular style is said to be the best aftercooler you can get as far as flow and efficiency go.
RB20drift240
Car: 92 240sx hb
i was thinking of an intercooler dimension of 27x7x2.5 and im gonna use a T3/T4 hybrid turbo
mtcookson
1992 Iinfiniti Q45
and much much more
You may punch those numbers in at eBay and see what you come up with. I've come up with some odd sized aftercoolers by doing that so that will probably be your best bet.
Return to “VG30 / VE30 Forum”
