BippuBoss
Beverly Hills Ca
5-19-2008
| « Re: VQ35HR vs. VQ35DE (ChanceWarren) | 11:28 AM 5/20/2008 |
well yea ok i can clear some stuff up about your problem. When the VQ set up was introduced it was a sweet set up and something that nissan could call a sportscar. It had good HP and performed well. The HR engine means high revving. There were rumors about it having an oil problem. but nothing came out from nissan that it was true. I would say if you have an HR get your oil replaced with some good oil, maybe not Mobil1 I have been hearing a lot of problems with that particular one, as its not meant for track use. The HR is still a relatively new set up and development IS running behind. Greddy came out with a TT set up, HKS has their street legal supercharger coming out. Some stuff is coming out slowly. I would say brian crower is a good company for your stroker kit. Just be careful, putting a stroker kit may mean porting and polishing, and could run you some money. My wife has the '07 350Z base and it's running fine so far. She's hesitant on buying things for it, and doesn't want to be super ricey. Just a side note but some companies do R&D for newer models. Check that out.
ChanceWarren
'07 350Z Base
Rancho Santa Margarita CA
5-12-2008
| « Re: VQ35HR vs. VQ35DE (BippuBoss) | 5:11 PM 5/23/2008 |
Thanks for the input!I heard about the oil burning problem; supposedly they "fixed" that (whether it was true or not... I heard from a few '06 owners that had that problem) on the '07 model so I'm not terribly concerned..? Anyhow, a fellow from BrianCrower.com said that neither kit they have is compatible with the HR, but they will be releasing a kit that is within the next few months. We'll see what happens.
BippuBoss
Beverly Hills Ca
5-19-2008
| « Re: VQ35HR vs. VQ35DE (ChanceWarren) | 2:32 PM 5/27/2008 |
well there it is then, more aftermarket parts are coming out for the newer model Z, but it's still slow. My wife doesn't drive her car around a whole lot, just to work every now and then. She wants to cherish it i guess, haha.
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
HR and DE are completely different engines. About 80% of parts are NOT interchangeable.This goes from the throttle body placement (HR has 2) to the block. You can only swap the pistons. Even the rods won't fit.
1991 240SX Coupe all stock - Wrecked. 1991 240SX Coupe VQ30DE project - Sold. 1991 240SX Coupe Celica front seats - Sold. 2003 SE-R Spec V - Sold. 2004 RX8 Sport - Sold. Next pick - IS300 or G35
inteller
2008 EX35 Journey AWD
Tulsa OK
5-23-2008
| « Re: (Soravia) | 12:53 PM 6/6/2008 |
you sure? I thought the HR shared lots of parts with the FX 35DE.
sEXy's chauffeur
Jacko3
Fort Lauderdale FL
1-9-2008
| « Re: VQ35HR vs. VQ35DE (BippuBoss) | 1:32 PM 7/10/2008 |
I can't speak for the HR engine, but if her car was a DE engine 350 Z or G-35, not driving it often will cause more problems than it solves. There si something about the DE engine that requires continuous or spirited driving.
Jacko3
Fort Lauderdale FL
1-9-2008
| « Re: (Soravia) | 1:33 PM 7/10/2008 |
I agree completely. Drive a G-37 and a G-35, and if you are truly connected to both cars, you will agree that they are entirely different cars. The G-37 is not an upgrade of the G-35.
terrycs
La Palma CA
2-20-2007
| « HR vs DE block Comparison | 9:22 AM 9/2/2008 |
HR Block:
 DE Block:
 Much stronger bottom end on HR.
2007 5AT sedan w/ a few mods
 Intelligent Key Covers at: http://forums.nicoclub.com/zer...cover Nav Screen Protectors at: http://forums.nicoclub.com/zer...-film
terrycs
La Palma CA
2-20-2007
| « HR, VHR, DE Rod Comparison | 9:32 AM 9/2/2008 |
 From left to right: HR, VHR, and DE rods.
Exar-Kun
2005 350Z
Georgia
9-27-2002
| « Re: HR, VHR, DE Rod Comparison (terrycs) | 8:03 PM 9/7/2008 |
Interesting....Also I heard the piston design on the HR is signifigantly different so they cannot be swapped....they're not perfect circules from my understanding. Anyone know if you can use the revv-up bottom end on the standard VQ?
Course, I'll just be getting cosworth to build it along with HKS so whatever, just curious :p ...and only if I win the mega millions lotto.
-Chet
You can live in a car, you can't drive the house. "The essence of stupidity is doing the same thing and expecting different outcomes" -Albert Einstein "It is possible to store the mind with a million facts and still be entirely uneducated." Alec Bourne 2005 Daytona Blue 350Z 6 speed. NISMO Exhaust, NISMO Differential and PS cooler, JWT intake, B&M, Redline 10W30/MT90, Tomei 2 way LSD, DC headers, Comp Clutch flywheel and stage 2 setup, SPL Front upper arms, SPL rear toe link, TEIN Flex coilovers, Stoptech 355 F 328 R BBK, ARC rad panel, ARC catch can, Carbing STB, HKS DLII, ADVAN Super Racing V.2 18x9 F 18x10 R with ADVAN SPORT 255/40YR18 F 275/40YR18 R
XJared
06 Titan, 83 Z
Tallahassee FL
5-26-2008
I think maybe some people are confusing the VQ35DE rev up with the VQ35HR. And didn't see if anyone mentioned the bell housing and main journal size change that the HR now shares with VQ40.
AEM Factory Trained ASE Master Technician - L1 Nissan Master Technician GTR Certified Technician
Pharaohabq
92' Nissan 300ZX NA
ABQ NM
4-14-2008
| « Re: HR vs DE block Comparison (terrycs) | 4:41 PM 1/15/2009 |
Can you show the Tranny bolt pattern difference on those two blocks? I've been trying to verify its a different pattern on top of the clutch change. Thanks phar
Pharaohabq
92' Nissan 300ZX NA
ABQ NM
4-14-2008
| « Re: HR vs DE block Comparison (Pharaohabq) | 1:40 PM 5/20/2009 |
Yes there's a definite Bolt pattern difference between the HR and the DE trannies. There's differences in the wiring harnesses and ECU too (3 plugs vs 2 on the DE) . though the BCM and AC amp appear to be the same.
sir_vq
350z
philadelphia pa
4-1-2009
| « Re: VQ35HR vs. VQ35DE (BippuBoss) | 7:37 AM 5/24/2009 |
The HR engine means high revving. There were rumors about it having an oil problem. but nothing came out from nissan that it was true. I would say if you have an HR get your oil replaced with some good oil, maybe not Mobil1 I have been hearing a lot of problems with that particular one, as its not meant for track use. anybody with a 370z should be using nissan ester oil or a equal ester based oil such as motul or grex.... ester oil is thinner and in both positivly and neg. charged it will not glog oil passage like your higher viscosity oils and it clings do cyc. walls and cam lobes and prevents drystarts.... which is the prob with the 370z and 350z it expensive but well worth it.........think of it as 30% reg oil and 70%lucas oil stabilizer thats about the consistency try it it really good stuff i use it in my sr20 as well as my 350..........and PS i think mobil 1 is track worthy to say it aint is 'ludacris'
