 TRUE DIFFERENCES VG30 vs VG33
bimrtech
Several
Richmond
6-21-2004
Just wanted to put this information all in one spot.
Big Thanks to mtcookson for letting me know before hand some of the differences. I would not have performed this swap without his advice!
I just performed this swap and found a few more. I just want to clarify a few things for others interested in this swap.
From the bottom up.
The VG30 oil pan will bolt to the VG33 block
The a VG30 oil pump will bolt on the vg33 block and is needed if running the vg30’s oil pan as the pick up tube is in a different location from the vg33 pump unless you want to fab. the pickup tube.
The VG30 crank will work in the VG33
The VG30 crank will only work with the VG30 Oil Pump
The VG33 Crank will only work with the VG33 Oil Pump
If you plan on running the VG33 crank in your swap you will have to modify the pickup tube as read above again. The VG30 pick up tube will bolt to the vg33 pump but it will be in the incorrect place. I modified the VG30 tube to work in the vg30 pan with a vg33 pump. I also had to cut some baffling in the pan to make it work.
If running a vg33 oil pump the filter is attached to a extension bolted to the pump. This was in the way on my car. I was able to tap the oil pump with ¼ NPT tap and run fittings to a remote filter housing. If you are stuck with the vg33 crank as I am, this must be done if the filter housing is in the way. You can not run the filter on the side of the block if using this oil pump. I suppose you could if you fabed a loop for the two holes in the side of the oil pump, but if you are going to do this, you might as well run a remote oil filter.
Crank pulleys are not interchangeable.
Water pump is a bit different. VG30 was shorter than the vg33.
I ran the water pump that went with the crank so the belts would line up.
The t-stat housing on the VG30 will not bolt to the vg33 block as there is casting material in the way of the housing. You may be able to grind, I did not try.
The vg33 t-stat housing outlet puts the lower hose connection at an angle, not straight out as the vg30 housing did. This forced me to fab up some creative lower hose connections.
T belts/cam gears/crank gears must be for the crank you are running.
If VG30 crank sprocket you must use vg30 cam gears/ t-belt
If vg33 crank sprocket you must use vg33 cam gears.
The cam gears are interchangeable with the cam
VG33 gears will work on a vg30 cam.
The intakes are interchangeable.
The flywheel from a vg30 will bolt to a vg33 crank.
The cams from a vg30 will work in a vg33 head.
The valve springs from a vg30 will work in a vg33 head.
The transmission from a vg30 will work on a vg33 block.
Mounts are the same also.
The vg30 distributor required some time on the grinder. An angle must be made at the base of the distributor as the clamping bolt did not go straight down as on vg30 heads. On Vg33 heads this bolt enters at an angle.
mtcookson added "On the distributor, there should be plate that bolts to the head. The distributor bolts to that plate. You should be able to remove the plate from one head and put it on the other to go with the distributor you're using. "
Joe
Modified by bimrtech at 4:23 PM 5/18/2008
Joelamite ASE Master Tech
Caretaker of
97 Subaru Outback S/W Blue 2 tone with fake silver bottom trim. This is my fav. car of all time.
99 Dodge Durango 5.9L Drinks more than I do.
1975 Porsche 911S
1962 Chevy C10 in a bizzilion pieces scattered over my garage.
1964 Volvo 544 thats right bitches!
1952 Pontiac 2 door. To legally take the kids to the park without seat belts. Take that Nader! Oh ya I don't have rev. lights or tag lights either!
1999 Monte Carlo ZX Race Car (2008 NASA Mid Atlantic Sports Racer Champ!) 4SALE!!!!
mtcookson
Supporting Member
Howard KS
11-21-2002
Great info Joe!
On the distributor, there should be plate that bolts to the head. The distributor bolts to that plate. You should be able to remove the plate from one head and put it on the other to go with the distributor you're using. They actually use the two different types even between VG30's in different vehicles as well (angled and flat). I totally forgot about that one, sorry about that.
Aaarrrrrrrr... Aye approve of this message
Dattebayo
Big Meanie
S12 w/ VG30E
DC Metro Area
8-25-2002
So what exactly did you do about the water pump differences? You say the VG30 water pump does not work?
Quote, originally posted by Eikon »
The rate of teenage pregnancy declines rapidly after age 19.
bimrtech
Several
Richmond
6-21-2004
 « Re: (Dattebayo)
It will if you run a vg30 crank/pulley
VG33 pump is a bit longer than the vg30 I used.
mtcookson, I was so tired by the time I got to the dizzy, I did not even see that. Good point!
speedfoos
1990 D21
Fayetteville NC
10-5-2008
As much as folks hate bumping old threads, I'm going to anyway. I got it that VG30 cams fit a VG33E (which is what I have) and the fact that you pick up a little power as result of the higher lift and longer duration.
However, will the stock ECU be able to take advantage of the slightly more aggressive cam profile?
From what I understand, there aren't any plug and play engine management systems for this ECU (the stock VG33E) and any extensive mods would require the use of Megasquirt or another piggyback.
1966 Volvo Amazon - 383 Stroker project!
1990 Nissan Hardbody - de-minification in process!
2003 Honda Civic EX - 261.8whp/219.9tq @8.5psi - Parted out and gone.
2008 Lexus IS250 - 204bhp/185tq bone stock (Bought not Built!)
mbmbmb23
Charlotte NC
8-19-2004
 « Re: (speedfoos)
Quote, originally posted by speedfoos »
http://www.nistune.com ?
trev0006
2-25-2004
 « Re: TRUE DIFFERENCES VG30 vs VG33 (bimrtech)
Great info, was looking for this a while back.
Quote, originally posted by bimrtech »
From the bottom up.
The vg30 distributor required some time on the grinder. An angle must be made at the base of the distributor as the clamping bolt did not go straight down as on vg30 heads. On Vg33 heads this bolt enters tires sport cars at an angle.
Joe
Nissan video collection
madroxx
1993 nissan d21 bagged
Laramie Ms
12-14-2009
so the heads will work?
lalo
1989 240sx and 1988 300zx turbo
winston salem nc
12-26-2007
 « Re: TRUE DIFFERENCES VG30 vs VG33 (madroxx)
no
» Return to VG30 / VE30 Forum
