pabs324 wrote:Are those symptoms of leaky injectors the rough idling and smoke out of the exhaust smelling like gas.
You have all the symptoms- rough idle (suprised it stay running), all cylinders filling up with fuel, billowing white smoke out of the exhaust, raw fuel pouring out the exhaust pipe or muffler, and eventually hydrolock if the leak gets too bad. Don't drive too far.
Are you using new o-rings on the injectors? Are the mating surfaces on the fuel rail cups free of residue or nicks? At 45 psi, a nick in an o-ring or a fuel rail raised surface doesn't have to be very big to cause major leaks. A nick that small may not even be visible to the naked eye. My employer has lost hundreds of millions of $$ on test stands and launch pads over the years due to under-inspected o-rings.
Take a chance and start over with #1 injector. It's the easiest to get to and you've got a 1 out of 4 chance it's the problem o-ring. Clean the rail cup with a good penetrant (PB Blaster) and a rag, install and lube up new o-rings, and try again. Good luck.
