m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: m tr4nch's restoration/build thread !! (m tr4nch) | 3:11 AM 4/16/2008 |
begin spring '06, out of hibernation
interior completely gutted, dry ice is awesome.. also stripping the excess seam sealer off everything
 stripped engine bay. rusty and dirty as hell
 rusty seams in front wheel wells
 bottom of passenger side quarter panel
inside..
 driver's side not nearly as bad..
 burning the bushings out of the subframe
 and so the rust attacking commences... started grinding those front shock tower plates
 this crap was way too deep and i could see stuff hiding under there still, so i decided to just drill it (both sides) off, good thing i did
 sandblasted clean
 one coat of rust bullet sprayed on
 upper radiator support next.. there's a LOT of rust hiding sandwiched between here
 got to sandblasting a little bit. here is my sandblasting outfit
 after spraying with rust bullet..
 new shock tower plates cut out and painted
 front wheel wells and battery tray are next...
yes i know this cut-out is horrible, i drilled 4 holes and used my dad's sawzall with a POS blade and it came out like crap
 battery tray patch cut out and welded up (i was a n00b at welding back then )
 wire-wheeled all the rubber/grime out of the wheel wells
stopped for a couple months for winter picked up again spring '07.. i gave up on my radiator supports and decided to just get new ones and replace mine
 got the upper support off, test fitting the new one
 got the bottom one off, man this thing was rusty as hell on the inside..
 engine bay sanded down and rusty spots getting grinded down before sandblasting
 decided to cut a few pieces out, i hate rusty seams!!
other side
 after blasting and spraying rust bullet
then i welded on the new radiator supports and shock tower plates
then i found another surprise
tried doing a little bit of cutting and gave up, saving it for later..
 blasted the front wheel wells next, and coated with rust bullet
xenon lip came woohoo!
summer '07.. someone tell me if i'm crazy
starting on the journey through hell..
after countless hours and days later, working like this.. (yes i know the die grinder is on my balls/crotch)
 (this is only 1 day's worth of crap, i was out there for like 5 or 6 days..)
 the end result...
man, i don't think i want to ever do that again... being out in the 80 degree+ humid NJ summer weather wearing coveralls/ski mask/etc on my back for a few days.. holy SH*T is all i have to say.. after that i figured it was time for some welding
and painted up with more rust bullet
also finally painted over these welds
just some comparison pics of the engine bay after the rust fixage
now the hard part... started on the rear section first (basically from rear seats back)
after sandblasting
 and some rust bullet
 and then... a full coating of rust bullet
started the floor section next
rusty seat mount
 where the e-brake cable goes through
 glad i got that off...
 more surprises
 wtf, i thought i was done with this crap...
 after a little bit of cutting and poking
 after a lot of cutting
 okay... this is where i stand now, the last pic was from sept '07, the car's hibernating again and will come out in less than a month for me to continue working on it. btw, so far ALL of this work has been done only by myself.
i have decided to cut those sections of frame rail out and replace with clean metal. also i will have more pics up later sometime of new parts that i've been getting over the last few months. i know it's a TON of pics at once haha, yes some things i didn't get a chance to snap during the moment. keep in mind this "project" has been going on for the last almost 3 years now. but now that i actually started a build thread, i will have tons more pics from here on out. in short, my plans for the car is to be rust free with brand new parts everywhere (i will get pics of the rest of my new parts later), basically a "brand new" car that i can drive daily on the street and is reliable (for the most part). a brief list of what's left to do: finish fixing rust on floor section remove glass and sand everything down for paint get most of the suspension powdercoated new poly bushings installed throw everything back together anyways, i guess that's about it for now. thanks for looking and let me know what you guys think.
offroadbob
96 240sx, 84 720 4x4
Flagstaff/ now Tucson AZ
3-2-2007
| « Re: m tr4nch's restoration/build thread !! (m tr4nch) | 4:20 AM 4/16/2008 |
Awesome work! Very nice progress. I can't wait to see it finished.
Shift__BODOM
1993 240SX Hatch
Giant Rock, Space
10-7-2004
| « Re: m tr4nch's restoration/build thread !! | 5:48 AM 4/16/2008 |
I admire your dedication. I'd like to think I wouldn't quit halfway through and just sell off all the parts, but I probably would. Serious kudos for sticking with it and doing all that hard work by yourself. I can't wait to see how everything comes together.
| Quote, originally posted by tenkawa_akito » | | chainsaw > rooftop |
numbnuts240
Learned'd crew #1 aka "Tita"
1995 silvia speshul edishun lhd wif ka swap, 1974 fairlady z
meriden ct
7-1-2006
| « Re: m tr4nch's restoration/build thread !! | 6:00 AM 4/16/2008 |
you missed a spot . jk, looks real good man, i wish i had the time and funds to do all that with my car. i'm loving your engine choice btw.
| Quote, originally posted by Gold Digger » | | numbnuts240, NICO's resident bicycle...LOL |
pg. 606 & 1767 got broked'd  pg. 759 is teh suck "TAKE THAT TITA CUMFARTER... I'll unban you in a minute fag..." "i may be an idiot, but there is one thing i am not, sir, and that, sir, is an idiot." i like big butts and i cannot lieMy funtoi... Meets my dirty caramel desires. tested and approved by "The Tita" himself.
StricNyne
10-30-2003
hey turd sniffer you didnt post your most important peice of equipment your FnFIII Poster !!!!! seriously it looks awesome man now i gotta search up a AWESOME jpeg you havent seen and post it up
StricNyne
10-30-2003
| « Re: (StricNyne) | 6:41 AM 4/16/2008 |
 there we go..
homeslicej2
CIA Informant
90 240sx hatch Redtop SR
Rome GA
1-15-2007
| « Re: (StricNyne) | 7:03 AM 4/16/2008 |
Nice job so far I too admire your dedication. I hope to restore mine in future as well. I think Nissan still sells those front frame rails. I've seen someone post them up here on NICO. It might be easier/better to just get new ones (if they still sell them), cut the old ones out, and weld in the new.
http://hybridangle.com/ Looking for a great photographer? Check out this friend of mine.
kouki-gymkhana
1993 240sx (only 90,000 mi!)
Boston and So. FL
8-16-2003
| « Re: (homeslicej2) | 7:50 AM 4/16/2008 |
Holy shiznit! Awesome work! I admire your dedication and the shell looks awesome so far. Be careful with that RB25...make sure you take the time to sort it through thoroughly before you drop it in. It will save you a sh*tload of headaches down the road. What mounts are you going to use? Might want to think about banging in the firewall where the starter will sit before you finish painting the bay to make it pretty. It will hurt your heart a little less if you do it now than when it's all painted. Don't ask me how I know...No plans to stitch weld the frame to stiffen it up? Might as well think about it since it wouldn't be that much of a stretch to do at this point. I look forward to seeing more updates soon. Keep up the good work!
1993 Hatch with R33 SII RB25DET now running on 5 cylinders...Thanks SPEEDLAB [UPDATE 5/12/07-->FIXED for $43]
mirochuki13
1992 240SX Hatch
Leonia NJ
7-29-2006
| « Re: (homeslicej2) | 8:03 AM 4/16/2008 |
This is my favorite pic.
My whole car would be blue if I marked all the dings on it... lol. Also, I think you should try to get sponsorship from rust bullet.
LS1 Drift Build Thread
240SX Factory Service Manuals
BMAR240SX
1993 240sx Coupe
QUEENS NY
8-21-2006
| « Re: (kouki-gymkhana) | 8:14 AM 4/16/2008 |
Did you hit the effin lotto?
 FS: Xenon lip pre-cut for front mount, with Canadian DTRL's and JDM Side Marker http://forums.nicoclub.com/zer...marke
Hijacker
240SX Moderator
'92 240sx Convertible
Olney IL
8-13-2003
Subscribed. I'm digging this resto project, and I totally understand your hatred of rust. My car is an ex-jersey car and had the fortunate luck to be pulled out of there many years ago. The few years it did spend up there did damage though, which I've been slowly fixing. Just not to the extent that you're doing. I don't have the patience or garage space to sideline a car for years to do what you're doing.
-Bart
| Quote » | Originally posted by Movingviolation240 What hammer, all I see is a Poundometer, it's a percision adjustment tool. |
| Quote, originally posted by audtatious » | Hey wait. My balls don't hang too low yet |
S13 Auto -> Manual Swap / My 240SX / Convertible Top Replacement / Silvia Fog Light Wiring / DIY: SR20DET Rebuild Stacey L. Childs, NICO Mom
white90esex
2 SRed S13s
Ft C CO
12-25-2005
| « Re: (Hijacker) | 11:06 AM 4/16/2008 |
wow, seems like way more work than its worth lol.good luck with it.
 Titan | 90' 240sx DD | 240sx goin all out | bB on air
homeslicej2
CIA Informant
Rome GA
1-15-2007
| « Re: (kouki-gymkhana) | 11:33 AM 4/16/2008 |
Kouki-gymkanan....whatever, made me think of something, other than take your time to make sure the RB install is great. Look into the SKYO mounting kit for the RB25. I looks like the best one out there right now.
Hijacker
240SX Moderator
Olney IL
8-13-2003
| « Re: (white90esex) | 1:00 PM 4/16/2008 |
| Quote, originally posted by white90esex » | | wow, seems like way more work than its worth lol. good luck with it. |
It is a lot of work, but so long as he enjoys it, it's worth it. Not to mention he's doing a great job at it so far. m tr4nch, Are you going to respray the underside with rubberized undercoating? They make it in a spray can and it's worth every penny if you do do it.
the converted
1991 240sx, 2003 Maxima 6 speed, building a Lotus 7 replica
Boston, Ma Danbury CT
2-21-2007
| « Re: (Hijacker) | 1:44 PM 4/16/2008 |
Damn..... that's some attention to detail. Just keep it up.
Rellik27
240sx
The Bottom FL
8-21-2006
| « Re: (Hijacker) | 1:52 PM 4/16/2008 |
wow looking good keep it up
nwmrkt
S13
8-12-2006
| « Re: (Rellik27) | 2:05 PM 4/16/2008 |
damn man nice job! You knew I was waiting for this thread.
Lopin18
240sx Hatch 89 KA24E
Santo Domingo FL
3-1-2007
holy, at first i was like Restoration my *** this thing is brand new!. then i saw the dings out and i was like, ok, looks more NEW, then i saw the stack of stuff i was like, hmm ok thats overboard, he wants to assemble the whole car?, then freaking doing chassis work cleaning, now rb25, OMFG, LOL THIS IS ONE HELL OF A COOL PROYECT, this car is gonna be BRAND new, beautiful. IM IN, Love this car, thread, work, everything!
Unhappy member of over 150 spamming lists after posting my email on Nicoclub sales section ^_^ 1989 240sx KA24E @ Dominican Republic
2.4Loflove
1993 Nissan 240SX SE
Statesboro GA
11-21-2006
| « Re: m tr4nch's restoration/build thread !! (m tr4nch) | 4:51 PM 4/16/2008 |
your rust problems are somewhat worse than mine, and you tackled them! good luck on whatever is coming. where did you get all the $$$ for the OEM parts?
m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: (homeslicej2) | 5:20 PM 4/16/2008 |
thanks for the comments everyone. it's really hard work. i actually almost gave up on it a couple of times but i figured what i had done up to that point would have been a waste, so i stuck with it and now i'm almost finished i'll try and answer everybody's questions. | Quote, originally posted by homeslicej2 » | Nice job so far I too admire your dedication. I hope to restore mine in future as well. I think Nissan still sells those front frame rails. I've seen someone post them up here on NICO. It might be easier/better to just get new ones (if they still sell them), cut the old ones out, and weld in the new. |
yeah i've seen people get those frame rails, i heard they are discontinued now? either way it's just that section that is rusty (where the rail bends upwards). the reason is because there's another layer in there for added strength (you can see it in my pics) and that hole there isn't such a good idea, so it just started rusting in between the layers. so i will get some sheet metal from the metal fab place around here and make some new one foot long sections for both sides. | Quote, originally posted by kouki-gymkhana » | | Holy shiznit! Awesome work! I admire your dedication and the shell looks awesome so far. Be careful with that RB25...make sure you take the time to sort it through thoroughly before you drop it in. It will save you a sh*tload of headaches down the road. What mounts are you going to use? Might want to think about banging in the firewall where the starter will sit before you finish painting the bay to make it pretty. It will hurt your heart a little less if you do it now than when it's all painted. Don't ask me how I know... |
| Quote, originally posted by homeslicej2 » | | Kouki-gymkanan....whatever, made me think of something, other than take your time to make sure the RB install is great. Look into the SKYO mounting kit for the RB25. I looks like the best one out there right now. |
yeah the RB has been sitting on the engine stand for over 2 years now so i will pull things off that generally need to be replaced when doing a swap. as for mounts, i am almost 100% sure i will be going with the SYKO mounts. i already have the r33 crossmember, and when it's all said and done it will be cheaper than getting mckinney's. speaking of banging in the firewall, would you (or anyone) happen to have a pic of where exactly to do this? and how far in? | Quote, originally posted by kouki-gymkhana » | | No plans to stitch weld the frame to stiffen it up? Might as well think about it since it wouldn't be that much of a stretch to do at this point. |
you know, i was originally thinking of stitch welding the whole chassis, but i decided against it. for a street car i don't think it would be worth it. plus i can always add a cage in the future for added stiffness if i ever wanted to. | Quote, originally posted by BMAR240SX » | | Did you hit the effin lotto? |
lol i wish... | Quote, originally posted by Hijacker » | | Subscribed. I'm digging this resto project, and I totally understand your hatred of rust. My car is an ex-jersey car and had the fortunate luck to be pulled out of there many years ago. The few years it did spend up there did damage though, which I've been slowly fixing. Just not to the extent that you're doing. I don't have the patience or garage space to sideline a car for years to do what you're doing. |
lots of people don't take care of their cars around here during the winter (mine's a prime example). it looks like the previous owner parked it in the damn ocean for a while, lol. | Quote, originally posted by white90esex » | | wow, seems like way more work than its worth lol. good luck with it. |
maybe, i guess we'll find out hehe, thanks! | Quote, originally posted by Hijacker » | | m tr4nch, Are you going to respray the underside with rubberized undercoating? They make it in a spray can and it's worth every penny if you do do it. |
yesssssir. i got my 5 cans of 3m rubberized undercoating sitting in my basement. | Quote, originally posted by nwmrkt » | | damn man nice job! You knew I was waiting for this thread. |
haha yes i know you were thanks! | Quote, originally posted by Lopin18 » | | holy, at first i was like Restoration my *** this thing is brand new!. then i saw the dings out and i was like, ok, looks more NEW, then i saw the stack of stuff i was like, hmm ok thats overboard, he wants to assemble the whole car?, then freaking doing chassis work cleaning, now rb25, OMFG, LOL THIS IS ONE HELL OF A COOL PROYECT, this car is gonna be BRAND new, beautiful. IM IN, Love this car, thread, work, everything! |
thanks man! yep everything (mostly) will be brand new. i really need to go downstairs and take some pics of my last nissan order  | Quote, originally posted by 2.4Loflove » | | your rust problems are somewhat worse than mine, and you tackled them! good luck on whatever is coming. where did you get all the $$$ for the OEM parts? |
haha thanks. $$ is from me working for 5 years and saving most of it.
op.tic
5-22-2003
Ive actually been waiting for this thread, the pic in your sig got me interested in this build. I have a 90 240sx hatch that i used some parts off of, theres rust here and there just like yours, this really makes me want to restore it and give it another chance, rather than giving it to a junkyard.
1994 Hardbody 1992 240sx Coupe 1990 240sx Hatch
slipipinoi
91 240sx hatch
Northridge, Los Angeles CA
3-7-2007
| « Re: (op.tic) | 7:12 PM 4/16/2008 |
soooo manyyyy partsssssssss
baoweezee
93' ChuFoTy EsSex
Ft. Worth TX
1-4-2008
been waiting for your write up ina long time..Gj btw, hey wat do ya use for sandblasting? and can u take a picture of the rust bullet ur using? wanting to do this on my car
Shift_Determination
3down1togo
R.I.P. 95 gold 240sx, 97 white kouki, and 92 red chucki... NOW a new one 92 maroon chucki coupe
Philadelphia PA
2-11-2007
| « Re: (slipipinoi) | 7:42 PM 4/16/2008 |
Ummm Ummm Ummm all i can say is You Are The S***!! lolz congrats on your progess times a MILLION...
xckid
I didn't make dickie a CkY CD
1991 240sx
McAllen Texas
12-16-2004
will you marry me loldamn man sweet restoration though...omg !!! this thread is so getting marked
MILESTONE: AVOIDED SIG POLICE SINCE SIG POLICY WAS IN PLACE.
| Quote, originally posted by dickie » | i want a fake id too, but i want mine to be from the local high school to make me seem YOUNGER. "yeah i just turned 19 sweetheart, let me get another beer for you and your friend." |
I AR I LEARNED'D <blink 182 fan for life>
Gottoknow
1993 240SX Coupe
Thunder Dome
2-21-2008
| « Re: (3down1togo) | 8:15 PM 4/16/2008 |
Right now you are my inspiration.
m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: (baoweezee) | 9:56 PM 4/16/2008 |
| Quote, originally posted by baoweezee » | | been waiting for your write up ina long time..Gj btw, hey wat do ya use for sandblasting? and can u take a picture of the rust bullet ur using? wanting to do this on my car |
for sandblasting i use one of these guns with the hose attached
with my air compressor
and a bucket of sand edit: forgot about the rust bullet lol... all i'm using is their automotive version. i also got some of their blackshell to try out. both are kind of thick and you're not supposed to thin them or it can screw up its rust inhibitive properties. for everyone saying i'm inspiring, thank you  i got all of my inspiration from people that have done this sort of thing: "powerhousemike" on vwvortex forums (white 240 coupe in FL), sillbeer, etc. thanks to them as well
Modified by m tr4nch at 4:21 AM 4/17/2008
m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: (m tr4nch) | 10:10 PM 4/16/2008 |
some more parts pictures..sold the tein he's and bought a set of stance gr+ back in october
main reason is that i want to use the z32 knuckles in the rear and for some reason tein is "unable" to send me some rear z32 mounts.. my cleaaaan J30 vlsd and axles (thanks to UNISA JECS on zilvia)
jdm chuki sideskirts with no cracks
catco high flow cat
now for the good stuff
new fuel tank and sending unit
 all new weatherstripping
 e-brake T cable, hood lock cable, hood latch assembly
 random clips/screws/floor plugs
 overflow tank, rear view mirror, mirror glass, front bumper emblem, wiper arms
 new combination switches (since every s13 has sun faded switches), pedal pads, door stuff
 headlight bezels
 all new lamps (front turn signals, front and rear side markers, 3rd brake light, license plate lamps)
 clutch hardline, fenderwell plastic, door moulding also stuffed in there
 will have more soon, maybe tomorrow
Modified by m tr4nch at 4:54 AM 10/10/2008
Didderson
Online
1990 240sx fastback sr daily.
Harrisburg/Lancaster PA
3-18-2006
| « Re: m tr4nch's restoration/build thread !! (offroadbob) | 10:47 PM 4/16/2008 |
I've always wondered what your sig was about. Now I know. You're one crazy perfectionist! Big props on the real restoration and not doing tube frame. It'll be nice and OEM one day for barret jackson hehe. subscribed. finish it this summer! BTW great choice on the motor. Had I had more time and money I'd love to have done an RB25.
Modified by Didderson at 12:31 PM 4/17/2008
KA24E (SOHC) ECU 4 sale
 Version 1 s13 build RIP, "The Mad Hatter" B13 VERSION 2 White Elephant SR20 Build '09!
pflicht
Krylon King
1991 Nissan 240sx
Andover KS
3-11-2007
| « Re: (m tr4nch) | 11:50 PM 4/16/2008 |
Damn dude, thats fcuking amazing@ I would have been pissed at the whole damn thing and just did a shotty job and would have finished it up within a year. Way to stay motivated and not cut corners. And for the DIY on everything, +100BTW, when you are done, I will allow those rust killing hands to come out to Kansas and clean my car of rust! jk I will definately be looking for updates!
Project: Kontrollverlust
| Quote, originally posted by The_Chosen_One » | I hope to god you mean I made your decision hard and not your willy wonka. |
Hijacker
240SX Moderator
Olney IL
8-13-2003
Matt, do you have the part numbers on hand for the light and wiper switches? Convertibles tend to get theirs sun faded worse than other 240s, so I've been wanting to replace them and I've been having trouble pricing out the wiper switch. I'll have a lot better luck with a p/nI'm actually surprised that you got a lot of the parts you did. It seems every time I go to order something oddball, Nissan has it on backorder.
homeslicej2
CIA Informant
Rome GA
1-15-2007
| « Re: (Hijacker) | 7:15 AM 4/17/2008 |
Holy crap. Nissan must love you cause I'm sure most of that stuff is $$$. | Quote, originally posted by Hijacker » | | ...I'm actually surprised that you got a lot of the parts you did. It seems every time I go to order something oddball, Nissan has it on backorder. | I bet he had to wait awhile for a lot of those parts to come in from Japan or something.
urcaptnspeaking
Face Melter Belter
1990 Hatch-2007 Ford Fusion
Washington WV
12-9-2007
this is nuts. I love it
Project Milk Money
http://www.myspace.com/loganakazeus Build Thread: http://forums.nicoclub.com/zerothread?id=327738 DIY Hatch Repair: http://forums.nicoclub.com/zer...id=44
m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: (urcaptnspeaking) | 12:17 PM 4/17/2008 |
thanks guys yeah hopefully it will be drivable by the end of the summer, or at least rolling on the ground. | Quote, originally posted by Hijacker » | | Matt, do you have the part numbers on hand for the light and wiper switches? Convertibles tend to get theirs sun faded worse than other 240s, so I've been wanting to replace them and I've been having trouble pricing out the wiper switch. I'll have a lot better luck with a p/n I'm actually surprised that you got a lot of the parts you did. It seems every time I go to order something oddball, Nissan has it on backorder. |
headlight switch: 25540-44F00 wiper switch: 25260-44F00 and yeah, every time i place an order it takes at least 3 weeks since i order all the random sh*t lol.
Hijacker
240SX Moderator
Olney IL
8-13-2003
At least your parts dept. orders it Mine has been notoriuos for forgetting to order stuff. A set of main bearings for my motor rebuild comes to mind.But everytime I go to order something oddball, like a set of power mirror interior sails, it seems to be on indefinite backorder.
Didderson
Online
3-18-2006
| « Re: m tr4nch's restoration/build thread !! (offroadbob) | 1:09 PM 4/17/2008 |
wtf 2xpost sry
Flicktitty
92 Z71 / S13 Coupe
Delavan WISCONSIN
9-21-2004
That is an awesome build! you very dedicated to your build! let me just say it's easy to tear **** apart put having to put it back together is where it gets tricky, then again i geuss everything you have is brand new in bags so you shouldn't have a problem. Did you go through a nissan dealership to get the parts or a website?
Are you from the midwest? If so you should be here! midwest240sx.comInterested in doing a JZ Swap? check out this! MyJZswap.com
m tr4nch
RS13
Ocean, NJ
7-23-2004
| « Re: (Hijacker) | 4:20 PM 4/17/2008 |
| Quote, originally posted by Hijacker » | At least your parts dept. orders it Mine has been notoriuos for forgetting to order stuff. A set of main bearings for my motor rebuild comes to mind.But everytime I go to order something oddball, like a set of power mirror interior sails, it seems to be on indefinite backorder. |
| Quote, originally posted by Flicktitty » | | Did you go through a nissan dealership to get the parts or a website? |
haha, that sucks. i go through http://www.midwaypartsteam.com in AZ. talk to mike jones there, he's taken care of most of my orders, awesome guy. he will get what you need, unless it's discontinued. or you could go through courtesy nissan's catalog online. midway's a little bit cheaper though | Quote, originally posted by Flicktitty » | | That is an awesome build! you very dedicated to your build! let me just say it's easy to tear **** apart put having to put it back together is where it gets tricky, then again i geuss everything you have is brand new in bags so you shouldn't have a problem. |
thanks! i actually think it will be much easier to put back together than tear apart. most importantly because i wont have to deal with bolts/nuts/screws that are rusted to sh*t.
Lopin18
Santo Domingo FL
3-1-2007
O.O Whats your real name man? Mat Gates Nissan? or something around nissan? thats a lot of EXPENSIVE things there, the beauty of oem stuff can we get an estimate on how much have u spent buying all that stuff (i mean the oem stuff only, vsld and all that are normal stuff to buy, but ALL that oem stuff is off the hook!)
| First 1 2 3 4 5 6 7 8 9 10 > Last |
