POLL: s13/s14 chassis w/ rb25det swap, does your speedo work?
Carl H
does your speedo work and what does it read?include who did your wiring if you know.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Speedo works, but not sure of it's accuracy. Should be testing tonight. Will verify and vote then.
Shocker
Car: 89 240sxHB rb26/30
No Jon Powell did mine. Nothing worked to the trans, including the rev lights and neutral switch.
2 winters ago when I removed the motor and trans I couldn't get the stupid sensor clips off of the trans, so I just cut the wires after about an hour of struggle. I have nothing going to my trans now.
Darius
Mine worked and read the same as before my swap. I did the wiring. Verified with radar detecting speed limit sign. S14.
lucky7
Car: 97 RB25 S14
mine works fine. i sent to lsauto to be recalibrated. i forgot this was even an issue.
Bwana
Car: Denali
Mine reads exactly half, I do the math.
Carl H
now this raises an interesting question, we have two s14 owners one who had theirs recalibrated and the other worked out of the box...
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
My speedo was perfect just by hooking it up to the RB speed sensor.
S14 + RB25 SII
Darius
lucky7 wrote:mine works fine. i sent to lsauto to be recalibrated. i forgot this was even an issue.
Did you hook it up to see if it actually was off before you sent it to lsauto or did lsauto just take your money and ship your cluster right back to you untouched?
240z4u
Car: '95 Nissan 240SX
I was using an S13 speed sensor in a Z32 transmission with J30 rearend in an S14.
WAYYY off.
I recalibrated it ala stickies at freshalloy and its within a couple MPH. Verified by GPS.
I did my wiring.
Evan
HPF Chrisk
Car: 240sx
Mine works but its off, about half as fast as it says it is if its on mph, if i switch it to kilomiters then its about 15-20 off if you were to pretend kilomiters were mph. If that makes sense
lucky7
Car: 97 RB25 S14
nope. who knows. but at this point, i dont know, nor do i care. it works, so im happy.
Shocker
lol looks like I'm the only lazy bastard who doesn't care about a speedo and uses his Tach. It's only good to 115 anyways.
Carl H
seems like this issue is s13 only, apparently the s14 speedo can 'read' the rb speed signal.we finished the neo swap that i was working on (in the rain and me under the car for the better part of last saturday) but the speedo reads low...i bet there is a fix for it some how.
240z4u
Carl are you doing the swap in an S13?
Pretty hardcore working in the rain!!
Evan
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
mine is dead on balls accurate..wiring done by me..lol
Bluefire
RB25 SII into an S13 and the speedo read slow. Using a JDM S13 speed gauge i was able to recalibrate kmh to mph using the pot on the back.
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Mine worked for a bit. Not sure if it was accurate or not, but its dead now and doesn't move. Time for a new cluster since I think its dead.
Carl H
rb25 swaps only please.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
LoL served.
lilskyline240
Car: 90 240sx w/ rb30det
Bluefire wrote:RB25 SII into an S13 and the speedo read slow. Using a JDM S13 speed gauge i was able to recalibrate kmh to mph using the pot on the back.
i got the same thing. JDM 180km/hr speedo converted to MPH with the pot on the back
ninety1two40
Car: 1991 240sx SE
S13 - Rb25 S1
HUD speedo, works perfect with Dakota Digital speedo signal modifer.
300Plus
Car: 1995 S14 w/ Rb25det Series II
S14 rb25 SII
Swapped the R33 cluster in, my wiring works perfectly, GPS proven
matafied
Car: 1989 240 rb25det 1992 240 rb25det
all 3 s13's i have done with rb25's thay all read at about half
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I just put a Z32 speed sensor in and used the red gear.
It seemed accurate.
Now i have an RB20 trans though with a KA24DE speed sensor so its almost perfect.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
both of my stock s14 speedo and my converted jdm speedo work perfectly when i run my stock tires (diameter) but when i run my 255-50-16 tires in the rear it reads about 7mph high. i did my own wiring and my reverse lights work and speedo.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
My s13 speedo reads nothing. Which doesn't bother me cause I flow with traffic anyways. But the only thing that works on my cluster now is the gas gauge. So Im happy with just that
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
I have a SI RB25 in my S14. I am using the Gauge cluster from the clip that came w/ the motorset. It reads just fine in Km/Hr, and I do the MPH conversion in my head. The guy that I bought the car off of did my swap. Everything in the cluster works, CEL/brake/oil/etx
RBSilvia
Car: '89 RB25 S13 Coupe
'91 SR20 S13 Coupe
S13, RB25DET
speedo seems to be about half of actual.
mattleegee
Car: s13+19 corolla
is everyone using the rb25det cluster?
