stangalot
93 240sx vert 96mustanggt conv 95mustangSC
tampa fl
3-1-2008
| « Re: rear window replacement 94 vert (jmaggioc) | 4:28 PM 3/18/2008 |
Well if your rear window was as bad as mine then i have a great $20 fix.. Step 1 go to wal mart and buy 1 yard of heavy duty clear vinyl, $1.97 ....... Grab about 20 feet + of velcro $16.98 ....... And Some glue stick (providing you own a hot glue gun) Step 2 measure out window area, you'll have enough vinyl to screw up once. Hot glue Velcro around Vinyl and Conv Top Thats important... Step 3 Enjoy your new window.. And It looks great if you take your time to do it... A lot better then 400 for new top window..
Eikon
Super Moderator
'92 240sx 'vert with RB20
Green Bay WI
4-24-2004
| « Re: rear window replacement 94 vert (stangalot) | 5:00 PM 3/18/2008 |
That is one hell of a great first post!Welcome to the 'vert forum.
92 Nissan 240sx Convertible with RB20det 5 spd conversion. http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
 Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
inertiadrft
Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
Where the angels chill.. ca
5-23-2006
| « Re: rear window replacement 94 vert (Eikon) | 1:25 AM 3/24/2008 |
Explended First post!
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
| « Re: rear window replacement 94 vert (stangalot) | 3:25 PM 3/30/2008 |
| Quote, originally posted by stangalot » | Well if your rear window was as bad as mine then i have a great $20 fix.. Step 1 go to wal mart and buy 1 yard of heavy duty clear vinyl, $1.97 ....... Grab about 20 feet + of velcro $16.98 ....... And Some glue stick (providing you own a hot glue gun) Step 2 measure out window area, you'll have enough vinyl to screw up once. Hot glue Velcro around Vinyl and Conv Top Thats important... Step 3 Enjoy your new window.. And It looks great if you take your time to do it... A lot better then 400 for new top window.. |
i was thinking of doing that too, is there any leakage after u did it
 AIM: daruebenwhocould http://www.myspace.com/c0mpr3ssi0n http://www.rjmarket.com MODS: Engine rebuild, 5 Speed swap, 5 Lug conversion, J30 brakes, Megan Coilovers Next on the list: Godspeed Sway Bars and Megan End Links
stangalot
tampa fl
3-1-2008
| « Re: rear window replacement 94 vert (-RJ-) | 4:30 PM 3/31/2008 |
No leaks at all including highway driving..Holds up well to wind and rain. only one piece of advice... hot glue tends to melt in direct sun especially in Forida.. liquid nails holds up well though.. It looks great though, when i get it out of the shop(Tranny rebuild) I'll post a pic in case anyone is affraid of what it looks like..
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
oh boy i cant wait lol seriously. i need a back window bad and i sure as hell dont wanna pay 300 dollars for it
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
PICS!!!
S13xCrazy
Online
1993 240sx Vert/1986 Nissan D21 4x4
Dousman WI
10-8-2006
| « Re: (-RJ-) | 5:17 PM 4/14/2008 |
yeah...Thats straight up ballin.
 Check out our Nissan diagnostic cables! Get your ECU Tune chip! Tuned to your modifications!**NOTE: Some vehicles need daughterboards. 93 240 vert project - GT28 turbo, FMIC, SSQV bov, 370cc injectors, meth injection, much much more.
srphoenix
1993 white sr'd vert
Green Bay WI
12-5-2004
| « Re: (S13xCrazy) | 5:57 PM 4/14/2008 |
pics or a walkthrough would be awesome if you have the time, I plan on doing this sometime soon.thanks for the great idea!
 Sr'd Vert
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
im going to attemp it this sunday if it doesnt rain
The Inflicted
1995 Nissan S14.5, 1992 Nissan 240SX Convertible
Chattanooga TN
12-30-2005
| « Re: (-RJ-) | 5:16 PM 5/6/2008 |
I did the replacement on this car last weekend. I used the method described above, only I used loctite plastic/vinyl adhesive on the sides and bottom and only velcro-ed the top. It looks pretty crap, I'll admit, but it was only my first try and it's still WAY better than what I had. Before: After:
S13xCrazy
Online
Dousman WI
10-8-2006
| « Re: (The Inflicted) | 5:57 PM 5/6/2008 |
looks a MILLION times better then before.Just try and get it a little tighter next time How did you remove the rear window?
The Inflicted
Chattanooga TN
12-30-2005
I actually didn't remove the the rear window, not all of it. The new window is glued to the old window with the vinyl adhesive and then the old window was cut out.At least, that's what I SHOULD have done. I laid a piece of vinyl over the window and used a sharpie to mark where the lower edge was. Then, I cut along the line and glued the new vinyl to the old window. In order for this glue to make a good set you have to be sure and use sandpaper to rough up both the old and new vinyl. I let the glue dry, then measured and sharpie-ed around the rest of the window and cut it out. I then removed the old window using an exacto-knife, leaving about half an inch of vinyl all the way around. THIS WAS A MISTAKE! It turns out that the stock window is very tight and is pulling all the fabric together! When I removed the old window suddenly the new piece I cut out wasn't big enough anymore. I had to use the velcro along the top in order to make it long enough to reach. This is why it ended up bunching up so badly along the sides. What I SHOULD have done: 1. Leave old window in place. 2. Lay new vinyl over old window. 3. Sharpie the TOP of the new window to the old window and glue the TOP first (There's an overlapping piece of canvas that makes it hard to do the top last) 4. Let top glue dry. 5. Glue sides, making sure to leave enough new vinyl on the side to have something to pull on to leave no excess. It would help to have someone on the inside of the car to push outwards as you are pushing inwards to make sure the glue touches. 6. Glue the bottom, again making sure to glue new vinyl to old vinyl and leave enough excess on the bottom to give your fingers something to grip onto and pull tight. 7. Let all glue dry. 8. Cut off excess new vinyl. 9. From inside, CAREFULLY cut out old vinyl, making sure not to cut the new vinyl OR to cut off the old vinyl that the new vinyl is glued to. At least, that's the procedure I THINK would work, given the mistakes I made. At any rate, the new window is still a thousand times better than the old one, and after letting the glue cure overnight (like the bottle said) I was able to lower and raise the top without anything coming undone.
The Inflicted
Chattanooga TN
12-30-2005
We had a big storm today and....NO LEAKS! I've also had the top up and down a couple times and all the glue and velcro is still holding.
S15nS13vert
95 240sx with a s15 engine 6speed tranny, 94 S13 SKYLINE VERT and a 08 Lexus RX350
Ft. Lauderdale Fl
5-28-2007
| « Re: (The Inflicted) | 7:32 PM 5/8/2008 |
you d the man
onosqv
Q to the V
'92 240sx Vert & '91 300zx TT
bewbews.com
8-7-2002
| « Re: (The Inflicted) | 12:29 PM 5/9/2008 |
That's pretty neat!So, The Inflicted, the way you did it, you are gluing the inside of the new vinyl w/ the outside of the old vinyl - that means if someone were to look closer @ your car, they would see some of the old nasty vinyl from the outside correct? Just trying to see if there is a way to do this w/ the minimal amount of old window visible.
bewbews.com
The Inflicted
Chattanooga TN
12-30-2005
| « Re: (brokeAs240sx) | 1:20 PM 5/9/2008 |
| Quote, originally posted by brokeAs240sx » | | That's pretty neat! So, The Inflicted, the way you did it, you are gluing the inside of the new vinyl w/ the outside of the old vinyl - that means if someone were to look closer @ your car, they would see some of the old nasty vinyl from the outside correct? Just trying to see if there is a way to do this w/ the minimal amount of old window visible. |
Yes, but only along the bottom, since the canvas overlaps the plastic on the top and sides. Also, a neat side-effect of this glue is that it actually tends to restore the old vinyl a bit- I guess because it partially dissolves the upper layer and fills in the pores. At any rate, the sections of old vinyl that are visible don't look as bad as the old vinyl before the glue went on. Not that care- I'm just happy I don't have to say the Lord's Prayer every time I back out of my parking spot!
The Inflicted
Chattanooga TN
12-30-2005
Here's a pic of the worst-looking place. I could probably crawl inside and trim away a lot more material, but I don't want to risk leaks, and since I'm planning on re-doing the window again anyway I want to leave myself as much usable surface as possible.
sleepyeyed240
1993 rb20 vert, 1989 hatch
janesville wisconsin
10-2-2007
| « Re: (The Inflicted) | 9:52 AM 5/24/2008 |
i have a replacment back window can i just do it or does it need to be sewn in or what
92 coupe-sold 89 hatch-rusty 93 convertible-skyline powered
The Inflicted
Chattanooga TN
12-30-2005
| « Re: (sleepyeyed240) | 3:03 PM 5/24/2008 |
| Quote, originally posted by sleepyeyed240 » | | i have a replacment back window can i just do it or does it need to be sewn in or what |
I'm not 100% sure, but based on what I've read the only way to get a new factory window into the factory top is to have a professional sew it in. Now, I have read stories of people replacing the entire top themselves, but it's a major project and not something I'm ambitious enough to attempt.
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
i was just going to cut off the middle part of the window and glue the new window on with nail glue... or whatever that stuff is called. its not gonna be the best looking thing but my top is almost always down anyways
sleepyeyed240
10-2-2007
| « Re: (The Inflicted) | 1:42 PM 5/25/2008 |
| Quote, originally posted by The Inflicted » | I'm not 100% sure, but based on what I've read the only way to get a new factory window into the factory top is to have a professional sew it in. Now, I have read stories of people replacing the entire top themselves, but it's a major project and not something I'm ambitious enough to attempt. | the new window has fabric around it and everything and i was lookng at it and it looks like u can just put it in.. but im not sure.. someone must know!
The Inflicted
Chattanooga TN
12-30-2005
| « Re: (-RJ-) | 10:57 AM 5/26/2008 |
| Quote, originally posted by -RJ- » | | i was just going to cut off the middle part of the window and glue the new window on with nail glue... or whatever that stuff is called. its not gonna be the best looking thing but my top is almost always down anyways |
If you're just going to do the middle portion don't sacrifice a rare factory window to do it- Wal-Mart's thickest vinyl wil be good enough. Also, make sure you're using a glue that is specifically approved for vinyl. A lot of super glues and epoxies will melt right through it, or not make a good bond. I used Loctite's brand.
 One other thing I would reccomend to make your window last longer and look clearer is using Plexus spray every couple weeks. I notice a big difference in clarity after using this stuff. They sell this at most paintball stores.
krash
1993 Nissan 240sx Convertible (W.I.P.)
Silver Spring MD
4-11-2005
| « Re: (sleepyeyed240) | 11:23 AM 5/26/2008 |
| Quote, originally posted by sleepyeyed240 » | | the new window has fabric around it and everything and i was lookng at it and it looks like u can just put it in.. but im not sure.. someone must know! |
Its a pain in the arse! I guess the toughest part is that you have to staple the curtain (the peice you were talking about) to one of the convertible bars and have it tight enough to make the rear window wrinkle free. and also when your stapling its hard to keep the actual fabric wrinkle free. IMO well worth it to shell out the $250 and get it done professionally.
 Bored? check out my DevArt: krash51491.deviantart.com/
