rocastro71 wrote:The coupon code is "nicoclubsponsor" for 10%.
I have tried blendmount before (both long and short) versions but have to return them as it triggers false laser alerts on my 9500ix. The closer the RD to the RVM for some reason causes it and it's very annoying.
You are only protected from radar, Red light cams, speed cams by your 9500i. How about laser protection. Once your hit and you RD alerts you to laser, the LEO already has your speed in less than a second. And that means a hefty ticket.
Do you remove your RD when your park in the open? Your location is very easy to see from the outside for thieves to smash your window and steal them. I moved mine high on the driver side at the tinted part of the wind shield. I can flip the visor to hide them when I leave my car in the open so thieves won't see it easily.
Laser protection is a joke with radar detectors. Once a LEO has a bead on you (they usually aim for your licence plate or bumper), it is too late anyway. They only way you would pick up laser is if it bounced off a car ahead of you or around you. If a LEO has a bead on you, on your bumper, your detector still isn't going to pick it up until it reflects off and it's too late by that time. I have tested this mounting the detector in different locations with the same results.
I never had the false laser issues. Although the intelligent cruise control on Infiniti's will set it off.
I have no issues with thieves. Car is always garaged and if I go somewhere, I simply remover the RD and take it with me.
