Power Seats - Back n Forth Dont Work, Relay Clickin. How do you access?
W O T
Car: 2001 Infiniti Qx4
hey guys
found a problem with the 01 qx4 today, havent touched the seats in a long time but today my girl wanted to drive and i went to move the seat forward and it doesnt go!!, the recliner knob works but the back and forth one does not, it makes a relay clicking noise from the switch when you move it though.
One thing I should point out, my girl said one day she went to move it back and forth and it didnt work for her, but insteadshe said she felt something moving the BOTTOM of the seat (where your *** is) UP and DOWN, like towards the ceiling (ofcourse she didnt say anything)
I cant see anyway to get access to the switch or anything so I really dont even know how to diagnose this.
Anyone got any ideas or tricks of the trade?
Thanks
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
This probably doesn't help a great deal, as I don't have power seats in my Pathy, but I seem to remember a while back that there was a discussion around this problem, and that it is more common than one would think. I also remember reading something in the Maxima forum about power seat failures.Try a search and see what you get. Good luck.
slickroger
Car: 2001 Nissan Pathfinder
my first pathfinder had the same problem. i took the seat out and just disconnected all the plugs and i couldnt figure anything out. so i plugged it back in and the seat was working. it stopped again later and i just did the same thing and it worked again. you may also have something in the track small bic lighters fit in there pretty nicely.
i hope you have the same luck as i did.
if you havent removed the seat yet, make sure you disconnect the battery. just to make sure you dont deploy any airbags if you disconnect the yellow connector. good luck
W O T
I dont even see any freakin plugs!
I hope nothings down there in that track, but Id like for this **** to be working again so I can bust out the lounge seating
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
This same thing has been happening in my 01 QX4 for some time now. This is funny because everything that's wrong with my car is currently being posted on this board, what a great forum! The up and down action works and so does the recline but no front back motion. I also have the same problem with my Passenger seat, what a pain! Thanks for posting.
Billy
bmgiene
I had a similar problem in my QX4. I narrowed the problem down to the Power Seat Motor. (There was power going to it when the button was pushed)
I have worked on Electric Motors before and know that sometimes they get "Stuck". I tapped the motor a few times with a hammer and it started working again. No problems since. (Its been about a year)
Empty V
Where exactly did you tap it? Thanks
Billy
bmgiene wrote:I had a similar problem in my QX4. I narrowed the problem down to the Power Seat Motor. (There was power going to it when the button was pushed)
W O T
Fixed it
Like the guy posted a few posts up there, all it took was to disconnect the power from the motor, then I disconected my battery, connected the seat plug, then connected the battery.
WORKS AGAIN!!! WOOO
bmgiene
I just tapped the motor itself. I hit it a few times lightly but tried a little harder when it would not come loose. Maybe quarter swings.
Empty V wrote:Where exactly did you tap it? Thanks
Billy
Empty V
Worked like a charm, thanks for the help!
Billy
bmgiene wrote:I just tapped the motor itself. I hit it a few times lightly but tried a little harder when it would not come loose. Maybe quarter swings.
Fafdawg
Car: 2001 Infiniti QX4 4x4 (Silver) & 2006 M35X AWD With Tech package. (Blk on Blk)
1st I like to say, Thanks for every information that was posted. Very helpful info.I had a similar problem in my QX4 2001. The up and down action works and so does the recline but no front back motion, and it makes a relay clicking noise from the switch when you move it though. I tapped the motor a few times with a long metal object with a hammer and it started working again. No problems since. It's has been about 5 days. I hope it will continued to work.
imorrin
Car: QX4
Sorry, but where exactly did you guys tap it? From the front, the side, the back, just random tapping from all around? I guess I'll go tap on anything I see, but was wondering where the best spot was!thanks
Fafdawg
Try to taping it from the back side. Slide the seat forward to get a better view of the motor. Good luck
Modified by Fafdawg at 5:38 AM 10/27/2008
imorrin
Car: QX4
Well, I simply tapped on a few things under the seat and it is working now! If only everyhting else on the car was so easy to fix. I', going to start tapping on the O2 sensors now Thanks for the help.
W O T
mine still works since I made this post.
I betcha a dealership is making some coin on this fix
garyd333
Car: 2002 Infiniti QX4
Hi WOT,
I stumbled onto this topic since my wife's QX4 is having the same issue as everyone else has described. Could you tell me if:- you had to remove the seat or were the seat connections accessible without removing anything- is there a diagram for QX4 power seats available on line anywhere (is it needed?)- has the "fix" lasted...is your seat still working?
Thanks (to you and all that post on this forum)...this isn't the first time I've come to this forum for a QX4 fix! I'm sure that I've saved several hundred dollars because of this forum.
Regards,Gary
W O T
Hey, no i didnt have to remove the seat at all, the motor is like right in the middle and maybe 4" back from the front of the seat you cant miss it if you get your head down there. There isnt a mahual needed (or atleast I didnt), I simply undid the 2 connections that go to the motor, cleaned them with electrical spray cleaner, reassembled, gave it a few taps with a small ratchet and voila it worked, dont know if it was the electrical or the tapping that fixed it, but its still working great to this day....
slickroger
I keep getting this problem over and over again maybe because the seat is always as far back as it can go, but i noticed it seems to sit in its own little groove right at the end.
so what i do is put my hand in the crease of the seat and hold forward on the button than give it a good couple tugs and it works. I pull it toward the steering wheel but it seems to get it out of that spot and it works again.
<IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/werd.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/slap.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... huckle.gif" BORDER="0">
Modified by slickroger at 4:49 PM 12/2/2009
masimo
Car: Infiniti QX4
Hi; Just few tap on the motor under the seat and you gone be happy guy like me.
sapp4l
Car: 2000 Maxima
I must say I'm amazed by 'old school' mechanics. Like the others, I had power seat motors that didn't budge (the up/down/tilt motors), despite voltage at the motor terminals. I figured the motors were bad.
A couple taps on one motor with a hammer, and one was working.
The second one took a couple more taps, and I manually turned the shaft with some pliers. It too took to working right away.
I love fixed that don't involve cash outlays, just a little knowledge.
Thanks forum members for doling out the knowledge.
DRIPS
Car: 2003 Infiniti M45
i LOVE this place....the tap / bang method worked on my Y34 m45. WOrked like a charm! Saved me the hastle of purchasing a new motor-- for now anyway!
utenavajo
Car: 2000 Infinity I30
Just got thru tapping that black cylinder seat motor underneath the seat and whaa lah! damn thing works like a champ. Thanks to previous members who posted this extremely useful bit of info.
tomR
Not unusual for the motor to go out. Happened on mine twice. had it replaced under warranty.
I think mine stopped working when the rear seat belt connection cover came loose and jammed the front seat when I tried to move it back. Will be trying the "hit" trick if it happens again.
joestrummer77
Car: 2002 QX-4
Ahhhh the old tap/bang methodology. Definitely worked on the wife......hey you left that one wide open for me....haha
I'm going to try this on my drivers side up/down motor in a few minutes - been out for 4 months now.
Thanks for the great post!
MachinegunT
Car: 2001 Infinity QX4
I am having the same problem on my 01 QX4! Hope this fix works!
T
REZN
Car: Nissan Pathfinder
i just pushed it while i was pressing the button....it got stuck all the way back and then it got stuck so u pushed it forward while pressing the forward button and it worked
lookinglucky
Car: 2001 pathfinder le
these forums are great ....would just like to add a little of my information ...my power seat would not move forward or backwards , tried tapping and pulling nothing worked for me....what i did was i used a small pair of vise grips and turned the large threaded rod under the seat , after playing with it in both directions i got it to operate ...i also used wd40 on the rod where it enters the female fitting ...now the seat operates as before ....hope this helps someone
thanks a bunch .....keep posting , its a big helps these forums
Fisherdude
Car: 1996 Nissan Pathfinder 4x4 SE
this is my 3rd car and these pathfinder seats are the worst seats in the world. It wont slide front to back and i had an old mechanic check it out and hes stumped... they are so uncomfortable and i even have the heated lethar seats... Its almost worth buying a chevy for the seats
W O T
Ya mine stopped working like every month or so now, kinda sucks but oh well, I always got a screwdriver in the back , giver a tap and she goes
skassamali
Car: 2003 Infiniti I35
Am having this same issue on my 05 G35. Tried tapping the motor with no luck. The motor is working, it just gets jammed. Like the seat tries to pivot. Any advice?
