Nacho_240
1991 240sx LE
Anaheim CA
8-15-2007
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (94_240sx) | 4:37 PM 1/28/2008 |
These look very well made. I like the fact that it slopes and extends all the way to below the radiator and not just below the oil pan. My question is how messy does it become when changing the oil? It seems kinda hard to get to the drain plug. A pic directly below the drain plug (KA w/ stock oil pan to be more specific) would really help me make a certain decision on a purchase. Thx.Nacho
Timeless beauty...
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (Nacho_240) | 6:31 PM 1/28/2008 |
| Quote, originally posted by Nacho_240 » | | These look very well made. I like the fact that it slopes and extends all the way to below the radiator and not just below the oil pan. My question is how messy does it become when changing the oil? It seems kinda hard to get to the drain plug. A pic directly below the drain plug (KA w/ stock oil pan to be more specific) would really help me make a certain decision on a purchase. Thx. Nacho |
Nacho, It looks like you know about similar skid plates from other companies. Yes, this one stretches all the way from radiator support to steering rack. Oil shouldn't touch the panel when you drain the oil. Drain hole is good for both KA and SR. I took extra time to come up with good size and location of the drain hole. This pictures is my car w/KA and I have aftermarket drain plug, but still it'll give you an idea where the plugs are going to be. You will NOT have any problem using your wrench and draining the oil, and it's not going to be messy at all.
DJButton
240SX Moderator
1919 In your face
Wherever May Roam
3-22-2005
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (94_240sx) | 8:41 PM 1/28/2008 |
I really like these good work man! Glad to see some more people in the Fabricator Market!
HIGH PRESSURE POWER STEERING LINES FOR SALENow carrying Nardi and Personal steering wheels and Works Bell hubs! Also new, SPLPARTS adjustable arms and much much more!
Nacho_240
1991 240sx LE
Anaheim CA
8-15-2007
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (DJButton) | 1:31 PM 2/1/2008 |
This is good work man. Unfortunately, I be broke . If I can't make one myself when I try it, I'll definitely buy yours.
d3vilskid
240sx '95 coupe
Bayou La Batre AL
1-31-2005
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (Nacho_240) | 10:19 AM 2/3/2008 |
No love for the s14?
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (d3vilskid) | 2:58 PM 2/3/2008 |
| Quote, originally posted by d3vilskid » | | No love for the s14? |
I would have made one if I had an access to s14, but sorry.
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
| « Re: S13 Under Engine Cover/Skid Plate Available KA/SR/Greedy Oil Pan (94_240sx) | 5:45 PM 2/4/2008 |
I have one of those plates from way back when they first came out, they are great, cept I'm modding mine so that it doesn't get in the way of the engine crossmember for jacking up the car - it's doesn't "really get in the way", but I don't like it being there where I can't line up the crossmember w/ the jack easily, haha.
bew bews!
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate Availab ... (brokeAs240sx) | 8:09 PM 2/4/2008 |
I think you can cut the rear and just use 3 bolts to install, one front and two on tension rod brackets.
iitywygms
1993 sx se
windsor ca
1-30-2005
Money sent.
greensx
93 240sx hatchback
san antonio tx
5-5-2006
| « Re: (iitywygms) | 11:49 PM 2/6/2008 |
Do you know if this would work with a CA?
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (iitywygms) | 6:33 AM 2/7/2008 |
| Quote, originally posted by iitywygms » | | Money sent. |
Got it!! It will go out tomorrow morning and I'll email you tracking number after I ship it. Thanks!
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (greensx) | 6:38 AM 2/7/2008 |
| Quote, originally posted by greensx » | | Do you know if this would work with a CA? |
Sorry. I have no idea. I didn't have an access to s13 with CA when I developed it. I wonder if you have a friend with KA and compare the locations of oil drain plug. ***** Tomei Oil Pan Owners ***** Tomei oil pan looks similar to GReddy oil pan and someone who has Tomei oil pan on his SR bought Version II like 2 days ago. He will get back with me with some installed pictures as soon as he receives it.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate Availab ... (brokeAs240sx) | 6:43 AM 2/7/2008 |
| Quote, originally posted by brokeAs240sx » | | I'm modding mine so that it doesn't get in the way of the engine crossmember for jacking up the car - it's doesn't "really get in the way", but I don't like it being there where I can't line up the crossmember w/ the jack easily, haha. |
Wait... If you stick some cardboard between the panel and cross member, you should be able to jack it up the cross member with no problem. Just think about it before you cut it. It's not going to hurt to have extra coverage under the cross member. I think you can put that piece of card board when you install the panel, and just leave it there.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (iitywygms) | 7:35 AM 2/8/2008 |
Shipped and tracking number has been emailed. Thanks!
Temple240
93 s13 coupe
Schwenksville pa
2-8-2008
| « Re: (94_240sx) | 2:46 PM 2/8/2008 |
money sent!
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (Temple240) | 9:24 PM 2/8/2008 |
| Quote, originally posted by Temple240 » | | money sent! |
Got it! I'll pack Version 1 panel tomorrow, and ship it out on Monday morning before noon. I'll email you the tracking number. Thanks!
Modified by 94_240sx at 6:18 AM 2/9/2008
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (Temple240) | 10:00 AM 2/11/2008 |
Went out as promised and tracking number has been emailed. Thanks!
d3vilskid
240sx '95 coupe
Bayou La Batre AL
1-31-2005
| « Re: (94_240sx) | 10:25 AM 2/11/2008 |
I wonder if i can drill holes in it to make it fit on the s14
Temple240
93 s13 coupe
Schwenksville pa
2-8-2008
| « Re: (94_240sx) | 10:30 AM 2/11/2008 |
Looking forward to installing it! Thanks!
Temple240
93 s13 coupe
Schwenksville pa
2-8-2008
| « Re: (Temple240) | 11:44 AM 2/14/2008 |
Got mine in the mail today. Unfortunatly I won't be able to install it before my trip to va but I'm excited to get it on the car when I get back!
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (Temple240) | 7:53 PM 2/14/2008 |
| Quote, originally posted by Temple240 » | | Got mine in the mail today. Unfortunatly I won't be able to install it before my trip to va but I'm excited to get it on the car when I get back! |
Cool! Let me know how it went after you put it on the car.
reccakun08
Rockville, Maryland
8-2-2003
How far off is the version 1 and version 2? do you have pictures side by side for comparison on the hole placement? currently i have a stock sr oilpan and later want to go greddy so if i buy version 2 now can i still do oil changes just as easily?
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (reccakun08) | 6:04 PM 3/1/2008 |
| Quote, originally posted by reccakun08 » | | How far off is the version 1 and version 2? do you have pictures side by side for comparison on the hole placement? currently i have a stock sr oilpan and later want to go greddy so if i buy version 2 now can i still do oil changes just as easily? |
No it'll be way off. GReddy oil pan drain hole is far out and SR is right below the engine. KA drain plug is in between SR and GReddy drain plugs. I'll try to post some pics tomorrow.
gumby74
San Antonio Texas
1-7-2007
I have considered making one of these myself, but as I have no access to a bending brake/laithe, I doubt I would make something as thorough as what you have here. Expect to here from me later this week for a version 1 plate. Don't be charging me state taxes either dammit!
reccakun08
Rockville, Maryland
8-2-2003
ooops double post.
Modified by reccakun08 at 12:29 AM 3/4/2008
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « March sale!!! | 6:47 AM 3/3/2008 |
reccakun08, sorry for the delay. I'll try to post pics tonight.gumby, no state tax, so don't worry. Here's better news. I'll knock off $10, so $80 shipped for the version 1 and $90 shipped for the version 2. I only have like 6 or 7 version 2 left, so order while you can.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (reccakun08) | 7:24 PM 3/3/2008 |
| Quote, originally posted by reccakun08 » | How far off is the version 1 and version 2? do you have pictures side by side for comparison on the hole placement?
Version 2 for GReddy oil pan
 Version 1 on top of Version 2. Holes are not even close since GReddy oil pan stretches toward outside and front.
s14tan
95 ZenKi SE w/ S14 SR GT28r and bolt ons
Dallas Tx
6-17-2007
| « Re: (94_240sx) | 6:25 PM 3/4/2008 |
make one for a s14 or ban.
| Quote, originally posted by gribbs » | At least i know guys like you are willing to help a noob out. Anyways thanks for all your help s14tan, it wont be forgotten ...why is there no 'cheers' icon lol |
| Quote, originally posted by WesTnine9 » | S14tan, you are by far the most helpful NICO member I've come across when it comes to simple "newbish" questions. Thanks for understanding that everyone has to start somewhere. Thanks for the help man. |
Tulsa_S-13
1991 SR 240sx
Stillwater Ok
6-19-2005
| « Re: (s14tan) | 7:59 PM 3/23/2008 |
You still have any of these?
 I ride a bicycle.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: (Tulsa_S-13) | 9:30 AM 3/24/2008 |
| Quote, originally posted by Tulsa_S-13 » | | You still have any of these? |
Yes, both versions available. It'll take 2-3 days for you to get it since you live in OK.
Devil Man
naples fl
6-5-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (94_240sx) | 10:50 PM 3/30/2008 |
i am interested in the version one. question is can these be made out of steel? i am worried that the aluminum wont be strong enough. i dont know maybe i am being crazy. thanks
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (Devil Man) | 7:55 AM 3/31/2008 |
| Quote, originally posted by Devil Man » | | i am interested in the version one. question is can these be made out of steel? i am worried that the aluminum wont be strong enough. i dont know maybe i am being crazy. thanks |
Steel might give you more problem because it'll rust. This is aluminum, but it's still pretty thick and sturdy. I haven't received any complains regarding thickness or fitment. If you don't like it after you receive it, please return it. I'll give you a refund(minus shipping) right away.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (94_240sx) | 8:00 AM 3/31/2008 |
I have a picture of another s13 whose oil pan got hit. This car is not lowered and running stock suspension setup.
Devil Man
naples fl
6-5-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (94_240sx) | 3:53 PM 3/31/2008 |
ok so what do i need to do then to get one of these. i need the v1 i just have a KA. can you please relpy back to me at my email at jackassbam@yahoo.com. thanks... its easier to check at work.. hehehe..
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (Devil Man) | 6:57 AM 4/1/2008 |
| Quote, originally posted by Devil Man » | | ok so what do i need to do then to get one of these. i need the v1 i just have a KA. can you please relpy back to me at my email at jackassbam@yahoo.com. thanks... its easier to check at work.. hehehe.. |
Email sent! Thanks!
KiNgEnMa
Brooklyn NY
5-3-2007
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (94_240sx) | 9:52 PM 4/22/2008 |
im interested in version 1, i dunno how to use paypal (never made a account) if u can help me out on how to properly send the money that would be awesome, hit me up with a reply at madisonknight87@yahoo.com
iitywygms
1993 sx se
windsor ca
1-30-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (KiNgEnMa) | 6:09 PM 4/23/2008 |
I love it when stuff just bolts right on. Good stuff. Makes it look real clean under there. VERY NICE..
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (KiNgEnMa) | 8:10 AM 4/24/2008 |
| Quote, originally posted by KiNgEnMa » | | im interested in version 1, i dunno how to use paypal (never made a account) if u can help me out on how to properly send the money that would be awesome, hit me up with a reply at madisonknight87@yahoo.com |
I just emailed you with my address. You can send me a check or M/O if you want.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: S13 Under Engine Cover/Skid Plate available for K ... (iitywygms) | 8:12 AM 4/24/2008 |
| Quote, originally posted by iitywygms » | I love it when stuff just bolts right on. Good stuff. Makes it look real clean under there. VERY NICE.. |
Thanks, man. I had to make several adjustments to make it fit right.
| First 1 2 3 4 5 > Last |
