 SeaFoam
Pathfinder995
99.5 Nissan Pathfinder SE
Apopka FL
1-16-2008
  SeaFoam
Okay, so I've seen a few of you talk about SeaFoam--can somebody tell me what the best way to make use of it is? I picked up a bottle and ran it through with a tank of gas but I keep hearing to use it in the "intake" etc. - any help would be awesome.
-Jeff
Reefdiver550
2001 QX4 2002 Porsche 911
Wilmington NC
4-17-2008
 « Re: SeaFoam (Pathfinder995)
yea i need help with this too...wheres the best place to get it in into the manifold?
fueler
1999.5 QX4, 2000 Honda 2.0T
San Diego / Baja California
1-16-2007
 « Re: SeaFoam (Reefdiver550)
black rubber vacuum hose
Empty V
Online
2001 Infiniti QX4, 1982 Corvette C3 Shark, 2001 Lexus RX300, 1996 Bayliner 4788
Ventura County CA
1-21-2008
 « Re: SeaFoam (fueler)
Ummm......what's SeaFoam?
Billy
On the Surface - 2001 QX4 2WD * Grille Guard * Surco Safari Basket w/Spare Tire Mount * Baja Design La Paz HID Lights w/Custom Fabbed Mounting Hardware
Suspension - OME 922 Springs * NX4 Spacers * Rear Coil Spacers
Brakes - DBA 629 Slotted Rotors * EBC YellowStuff Pads
Audio - Pioneer AVIC-Z3 w/iPod Adapter/XM NavTraffic/Back-Up Camera * JL Audio XR650-CSi's * 10w1v3's * MTX Thunder Elite Amps * Dynamat Everywhere
fueler
1-16-2007
 « Re: SeaFoam (Empty V)
seafoam is some old school stuff in a can, you suck it into the intake manifold while the engine is running, like maybe half a can, you have to pour slowly or the engine will die. (it will sputter while you pour) But once you pour half a can, just kill the engine anyways and let it sit for a few minutes.
Put the vacuum hose back on and start the engine, and drive around the hood. Watch out for police because you will have A LOT of smoke coming out the tail pipe. Last time i seafoam'ed, i had people giving me middle fingers and little kids all jumped off their bikes and pulled their shirts over their faces. It will look like your car is broken
but then the smoke clears out, your engine will run a lot better, smoother.
video of seafoam
http://www.youtube.com/watch?v=coZVpNdJfkw
^^ personally, my qx4 put out a lot more smoke than that
it burns out all the carbon deposits from your cylinders and head!!
more info
http://www.honda-tech.com/showthread.php?t=755765
fueler
1-16-2007
oh yeah, you want to change your oil a few dozen miles after doing this. and i recommend spark plugs too. seafoam can foul plugs.
pathfinder9035
2001 Nissan pathfinder
harrisburg pa
10-2-2008
well i heard it reduces the life of your engine...is that true!!??
toyota and nissan all the way.
jcpathy69
2003 Nissan Pathfinder LE
Newport AR
1-28-2007
 « Re: SeaFoam (pathfinder9035)
I've used this many times in the past. I had actually forgotten about it. Never calculated MPGs or anything but it does make an engine run smoother. I've never done it on my pathy, when I get around to it I will pick up a can and try to video the outcome, if I have an extra hand.
03 Pathfinder LE 4x4
exvin
2000 Nissan Pathfinder
Toronto Ontario
10-8-2008
Ive have tried this also and I have never encountered anything negative with it..Ive heard it will also screw with your O2 sensors but I have never ever had any issues with it.
ALso, the smoothness doesnt last quite as long as some people think, carbon will eventually build up again, even as quick as a week or less but if you want to clean out the cylinders etc, then it works wonders
SixGuns
'04 Nissan Pathfinder SE 4x4
Hubert NC
4-22-2008
I've been using SeaFoam for years and it's great stuff....basically, it's distillates that disolve the deposits in your valvetrain, cylinders, etc...Best way to get it done is use the black rubber vaccum hose leading from the brake booster (driver's side, next to the firewall, big cylinder)....move the hose clamp before you even start, and disconnect the line....probably stuck as all hell, so it will take a little working...then, stick the hose back on the nipple so it's just barely snug...have another person start the car and hold the revs at 3,000 RPM, then disconnect the vaccum line and stick the line into the can of SeaFoam and gently pour the liquid to the line...vaccum pressure will suck it all out of the can and as soon as it's empty, shut off the engine, put the line back on the nipple and secure the hose clamp. After 5-10 minutes, all the crap will be disolved and start the car...drive or rev the engine till all the junk burns out of the exhaust system....Like said before, be careful where you do...we've had the fire department show up, 'cause someone thought the Silverado we were doing it on was burning up....Gotta hold the revs up though, or the engine will die. Good luck.
Living under the assumption that my R50 looks best covered in dirt and mud.
SnowSurfLax
1999.5 QX4, 2006 M35 Sport
San Diego CA
4-15-2007
 « Re: SeaFoam (SixGuns)
From the SeaFoam Website...
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Basically can't go wrong with the stuff. They do mention that it's possible on older engines with lots of buildup to possibly damage an engine if too much carbon deposits get loose and they can jam up some head items. My suggestion is you run a few cans through your tank first to loosen it up gradually before doing the tune-up treatment.
It's not a QX4, it's a QX$ cuz it does nothin' but cost me!
Empty V
Online
Ventura County CA
1-21-2008
 « Re: SeaFoam (SnowSurfLax)
so I just bought a can of this stuff, anyone have pics of what hose to use? With 185K miles should I do the 1/3 in the gas tank, 1/3 in the oil fill, and 1/3 in a vacuum line deal? Or should I go all out and put an entire can in each one?
Billy
fraustypath
fayetteville nc
2-19-2009
Anyone able to show a pic of what hose you guys are talking about using? I have a 96 pathfinder and am sure it could use this.
longhornsqx4
2001 Inf Qx4 2wd
JL OW
1-14-2009
 « Re: SeaFoam (fraustypath)
The FAT black hose going from your brake booster (drivers side firewall), disconnect it AFTER the white valve, closer side to the engine, pull it off with the engine running, and feel how much vacuum suction it has, you slowly suck it up through that.
I did it last week, smoked like a banshee, didnt notice much difference myself though.
fraustypath
fayetteville nc
2-19-2009
 « Re: SeaFoam (longhornsqx4)
Thanks bud, worked fine, got a video of it, but my tailpipe is gone so all the smoke came out underneath, looks like my truck is going up in flames
bmlawless
Flawless Lawless
1999 Infinity QX4
Boise ID
1-3-2008
Quote, originally posted by fraustypath »
That would be good to see. Do you plan on posting it?
fraustypath
fayetteville nc
2-19-2009
http://www.youtube.com/watch?v=XIrwsBPzaVY
here you go
Chuck Tribolet
'01 Nissan Pathfinder, '87 Corvette, '98 Boston Whaler Montauk
Morgan Hill CA
11-24-2008
All those unburned hydrocarbons cannot be good for the catalytic converter.
Freyspath
Redondo Beach Cali
10-25-2009
I put it in my pathy when I got her.. As I was replacing the spark plugs, I took a hose and shot about 20cc's into each cylinder. Then I installed the new sparkplugs, connected the car back up, started the car, and drove around until the smoke cleared. My pathy had 80k when I got it, and I noticed it starts faster and smoother after I did this.
- 2003 Nissan Pathfinder LE, stock, gray on blk. 4x4
- 2004 Audi A4 slightly modded, 280awhp (sold)
- 1993 Ford Explorer Eddie Bauer 4x4, K&N cai, Jardine exhaust, JET chipped, BBK headers, and HD Sway bar and linkage.
