 V1 Short Shifter InstallFirst  1 2 >  Last
idahotuner
93 Sileighty and 95 chevy pick up 1500
St. Maries/ Walla Walla ID/WA
6-28-2007
  V1 SHORT SHIFTER INSTALL
Installing this was a little confusing for me at first and i did alot of searching so i decided to write on here. for every one else.
I am installing new lower dust boot and the circuit sport short shifter, all the v1's are the same wether it is meagan racing for fidanza. so following these instructions should help with any of the other installs
things you will need:
V1 shifter kit
graphite lube
5mm allen wrench
C clip pliers
10mm socket w/ ratchet or phillips screw driver.
replacement lower dust boot. - you can get them at your local nissan dealership
1. You will need to remove your radio trim along with shift knob and shifter boot. ALSO MAKE SURE THE CAR IS IN NEUTRAL
2. you will end up with something that looks like this.
3. you will take all four 10mm bolt off holding upper dust boot. you can use the screw driver or socket and ratchet for this part.
when you remove it you will have this
4. next you need to remove the lower dust boot. you can cut it off since you will be installing a new one.
mine was torn a little already so it slid off easily.
5. no you will need to remove the C clip holding the short shifter in.
using these
you reach in. inserting each end of the pliers into each of the holes on the c clip and squeeze,
should be able to pull it out no problem
this is the c clip removed
6. now if you remembered to put your tranny in neutral you should be able to slide the stock shifter out.
this is what it looks like with out the shifter
7. now take the new shifter just the lower half. and lube up the plastic part on the bottom.
you can slide the new shifter into the hole now. with it angled back.
EDIT: farther down some posted the rest of the way to do it.......
Modified by idahotuner at 12:16 AM 9/3/2008
"wound more tightly than a triple shot of espresso with a red bull chaser."
tu_bryan
None =(
San Jose CA
4-23-2006
 « Re: V1 SHORT SHIFTER INSTALL (idahotuner)
great info, you make it seem so easy! kudos to you
Strap in, Do the Dance, Drive.
White Comet
type x fanboi
fc, s13 and mazda3 (owned!!1!)
lancaster Pa
6-15-2006
 « Re: V1 SHORT SHIFTER INSTALL (tu_bryan)
glad u figured it out. see, it wasnt that bad
door panels hatch sunroof
Quote, originally posted by Logan76 »
I swing it around like a helicopter and all the ladies want to go for a ride.
Quote, originally posted by mrgreeneyes »
sorry i cant satisfy you, jeff
StricNyne
10-30-2003
my ****ty short shifter had the plastic bushing fall in the ****in trans and it was like half of the size of the stocker
le_ryan
Locura Controlada
is more posts than I should have been alowd to make
E Saint louis IL
7-5-2005
damn, very informative, good stuff man.
AKA vroom-chirp
My contributions to Nico :
Arm rest CUP HOLDER mod
S13 Lit sleepy eyes mod.
Padded arm rest mod
S13 E-brake boot mod
Make your own Master Cylinder bleeder kit
idahotuner
6-28-2007
 « Re: (vroom-chirp)
hey thanks guys.
took forever for me to figure out something to do a write up one. so i kidna gave up. but then when iwent to install this i couldnt find any instructions
so when i figured it out i figured i would do a write up
duffman1278
Moe Man
89 240sx Hatch, the wildcats!
The Mutha Land ca
4-1-2007
Good work should come in handy soon for me. BTW, what'd you use to lube the bottom part?
How much stiffer does it feel than the OEM?
Edit: mybad, just read "graphite lube" hehe
idahotuner
6-28-2007
 « Re: (duffman1278)
it feels alot stiffer then stock. and alot tighter. but i think it will loosen up some when i fill the tranny with new fluid. which is one of the next things i will do. i might end up pulling the shifter back off to fill the transmission. s o i dont have to do it from under the car. but we will see.
i am worried about over filling it. s o if i new the correct amount. then i could do it trough the shifter hole and not worry about it.
duffman1278
Moe Man
The Mutha Land ca
4-1-2007
Just check the FSM for the correct amount. Thats what I did when I filled mine, drained it and put it in from the top.
idahotuner
6-28-2007
 « Re: (duffman1278)
i read it was 2 and half quarts
fsm?
duffman1278
Moe Man
The Mutha Land ca
4-1-2007
Factory Service Manual
idahotuner
6-28-2007
 « Re: (duffman1278)
were will i find that. i guess i will have to search.
PMSing Chicken
1993 Nissan 240sx Fastback
Santee CA
6-17-2005
How's the vibration?
mrgreeneyes
Built Coupe
Lancaster PA
1-11-2006
um, not to be a negative nancy, but the aluminum collar is supposed to go UNDER the stock lower white ring, spacing the shifter HIGHER than stock, allowing the reduction in shifter movement.
so from the bottom, up:
aluminum spacer
wave washer
stock white lower ball pivot-y plastic ring
shifter ball
new white top ball pivot-y plastic ring
then the weird-arse top plate w/ retainers.
i used to have one of these and this is the proper way to do it. your way will leave the small shifter bushing about .5" too far into the trans, not letting the bushing interface with the trans fork piece, but rather letting the "wrist" of your lever make the contact.
THE BUILD
THE BLOG
Quote, originally posted by MMaxeyJR »
I will need your Moses abilities
Quote, originally posted by blacksrjdm »
If we cant install an intake, then we shouldnt be modding our car.
Quote, originally posted by JustDriftMore »
yea its MGE he knows
ahhh input from the lancaster kedz, it adds flavor to these threads i.e. reason why im on 240sx.org at 2:48 am
White Comet
type x fanboi
lancaster Pa
6-15-2006
 « Re: (mrgreeneyes)
^ good catch, i didnt even notice
Quote, originally posted by idahotuner »
look around a little. u can download them for free
D3stro
Nissan Silvia K's Ca18det 90,Nissan Sentra Ser SpecV 02,Nissan cube 1.8s 2009 & Nissan Versa 1.8s 20
Joliette QC
11-6-2007
 « Re: (White Comet)
Well done how-to. Simple and clean. Good work.
Nissan Sentra SeR SpecV 2002 with QR25DE: Apexi WS2-OBX header-AEM CAI-TA 17-No DLR-BS chainless-Faktion SS-RevolutionAutoworks TD-ES MMI-Technafit SS brakes & clutch lines-Unorthodox crank pulley-Tanabe NF210-Nismo RSB
Nissan Silvia K's 90 with CA18DET:Falken Hanabis 17x9 +20 on 4 corner-Exedy Stage 2 clutch-GAB front strut bar-Tom's Motorsport rear strut bar-Tein HA-Megan Racing tension rod-Nismo chrome knob shifter.
Nissan cube 1.8s 2009 with MR18DE Bone stock
Nissan Versa 2008 1.8s with MR18DE girlfirend ride.
idahotuner
6-28-2007
 « Re: (D3stro)
aluminum spacer
wave washer
shifter ball
it wouldn't have worked that way. i tried it. first off there is no wave washer.
the aluminum ring has to go on top, because the hole on the top plate hole isnt small enough to hold the shifter and every thing in. i can take it apart to show you.
the aluminum ring acts as a washer. from what i can tell. and if it was on the bottem everthing would not be held in place.
i dont have time to mess around wiht it today. but i will later. this week
mrgreeneyes
Built Coupe
Lancaster PA
1-11-2006
i had the exact same one so i KNOW it works the way i said... and the stock shifter has a wave washer.. just tryin to help ya out so when you go to make your first boosted shift, your lever doesnt snap/rattle like a mofo.
mrgreeneyes
Built Coupe
Lancaster PA
1-11-2006
that image shows EXACTLY what im saying
"collar" is the aluminum piece
idahotuner
6-28-2007
 « Re: (mrgreeneyes)
yea i will pull it apart and see. what i can do. i just dont see how it will work doing it that way. but i will try it again.
Quest4beasT
Fort Stewart Georgia
1-21-2008
 « Re: (idahotuner)
Those washers are a pain in the a$$, i think they mess with the trany staying in reverse when engaged.
White Comet
type x fanboi
lancaster Pa
6-15-2006
 « Re: (Quest4beasT)
greeneyes is right, i installed this exact piece as well on a friends car. im not really a fan of these shifters though, i'll stick to my b&m
niemczykj
1992 240sx fastback, 1986 Z31 Turbo
Vernon CT
11-26-2006
 « Re: (idahotuner)
WOAH, the metal bushing goes underneath!... u put that in first, then the plastic yellow piece with the metal cylinders, then the yellow plastic washer/bushing.
the metal goes on the bottom to make up for the higher position of the metal ball on the short throw.
1986 300zx turbo; Black on Black. K&N fuel injection performance kit, turboXS boost controller @ 10psi, cmperformance exhaust 3" turboback with testpipe, MSA sway bars and end links, cusco strut bars, z32 brakes and master cylinder, stainless steel braided lines, hawk pads, electric fans, Jason's springs with poly spring seats, and still working on it.
idahotuner
6-28-2007
 « Re: (niemczykj)
Quote, originally posted by niemczykj »
its a work in progress. i am going to fix that part.
s14tan
95 ZenKi SE w/ S14 SR GT28r and bolt ons
Dallas Tx
6-17-2007
 « Re: (idahotuner)
Hope fully you get it right cause ima be using this.. I just got my Megan racing Shirt shifter.
Quote, originally posted by gribbs »
At least i know guys like you are willing to help a noob out.
Anyways thanks for all your help s14tan, it wont be forgotten ...why is there no 'cheers' icon lol
Quote, originally posted by WesTnine9 »
S14tan, you are by far the most helpful NICO member I've come across when it comes to simple "newbish" questions. Thanks for understanding that everyone has to start somewhere.
Thanks for the help man.
idahotuner
6-28-2007
 « Re: (s14tan)
yea sunday i will fix it so settle down lol
s14tan
Dallas Tx
6-17-2007
 « Re: (idahotuner)
I need it tomorrow!!!! lol
derrick113
'91 Hatch SR, '93 Vert
waynesboro pa
6-29-2004
 « Re: (s14tan)
great write up man. I had the same fidanza one in my car for about a week and got sick of it casue it felt weak and just didnt seem like it would last and got a B&M. i must say the b&m is a much better unit.
idahotuner
6-28-2007
 « Re: (derrick113)
yea i wish i had got the B&m shifter but i will make do.
White Comet
type x fanboi
lancaster Pa
6-15-2006
 « Re: (idahotuner)
out of curiosity whats the price on one of these shifters? im curious to see how it compares to the b&m for pricing
idahotuner
6-28-2007
 « Re: (White Comet)
the price is about 70 dollars for one of these compared to b&m for 250, or 230 which was the cheapest i found
mrgreeneyes
Built Coupe
Lancaster PA
1-11-2006
 « Re: (White Comet)
Quote, originally posted by White Comet »
haha, the ebay addict asks for ebay prices? lol...
derrick113
waynesboro pa
6-29-2004
 « Re: (idahotuner)
yeah i wasnt bashing on ya man, i went through that same process and trying to tighten the nuts up on the plates was def no fun. Then i got the B&M and was very pleased with the shifting throws but d*mn that thing was noisey. I'm a little skeptical about getting the revised version now but who knows. Good luck with the rest of the build.
White Comet
type x fanboi
lancaster Pa
6-15-2006
 « Re: (mrgreeneyes)
i know lol but u forgot i'm lazy. i was also curious to see what he paid for it as opposed to what they're going for. imo i woudl have gone with teh b&m its more but worth it. i dont like these style short shifters so maybe i'm biased.
Quote, originally posted by derrick113 »
up until recently i wasnt even aware these things were making noise for some people. i might have gotten the revised version but my b&m doesnt make a sound
hayai_240
1989 240sx Coupe
Seattle WA
7-8-2006
I just paid $180 shipped for my B&M shifter. Cheapest i've found around is $210 shipped or so. Got mine through a vendor that sells B&M shifters on Honda-Tech. =)
idahotuner
6-28-2007
 « Re: (hayai_240)
Lucky you ^ i wanted to get my motor in my car and thought i need to or it would be easier to install it with the tranny out. and i wanted to save a little money but for 180 shipped that is a a good deal
Didderson
1990 240sx fastback sr daily.
Harrisburg/Lancaster PA
3-18-2006
 « Re: (hayai_240)
Yea Ben I just wanted to confirm once again that Greeneyes is correct. You'll be hurting your synchro slider shaft using the spacer in that position as of now.
I have the same style shifter. I love it, then again, I've never tried anything nicer. But I would reccoment you use the stock bushing that goes on the little ball. It's much nicer for fitment and won't break like the ones that usually come on these shifters.
Fix it or
Current "Blue Space Shuttle" SR'd 240 | *Lanc blog*
s14tan
Dallas Tx
6-17-2007
 « Re: (Didderson)
I got my Megan Racing one for like 40
noneckgus
240sx
la puente ca
9-21-2007
should it be stiff when its bearly put on or how could i take care of that
MRNA
'99 Maxima, '84 Porsche 944
Johnson City TN
1-18-2008
Swell dude, very swell.
Chuki Crew Member
Aftermarket Steering Wheel Clan Member
KA24DE Part Out
 First  1 2 >  Last
