skydragoness wrote:How do you live in NY and not have dedicated snow tires? Bare minimum width for snow/winter tires should be 215, and your'e running 245 rear and 225 front? My god.
Bridgestone Potenza R3504 ? Haven't heard of them. The part you said about the Futura tires (or as i like to call them--Futurama tires) is probably right as well but you may have been able to slice thru that patch of snow with the smaller width Futarama's. Wide tires cause a 'sled' effect that you don't want.
My advice is to get snow tires for the 16's you have and put them back on. Run a 205/215 50 series on them. My recommendation: Dunlop Wintersport M3 (if roads in your area are dry 75% of the time, I grew up in Elmira, NY and I don't think NY is that lucky in the winter).
Also countersteering is bad, as soon as you feel the back slip up you are supposed to hold the car straight as possible. Countersteering causing the 'pendulum' affect. Please, for the sake of yourself, your car, and others, get snow tires.
http://www.tirerack.com/winter...e=118
Very good advice and good post.skydragoness wrote:How do you live in NY and not have dedicated snow tires? Bare minimum width for snow/winter tires should be 215, and your'e running 245 rear and 225 front? My god.
-- Or a set of really nice all seasons and some tubes of sand. Glad to hear you and your car are okay.PoorManQ45 wrote: Now, go get your snow tires mounted up on those 16s and be safe
Do you personally use those? They don't even have test results from the TireRack, and the reviews from customers do not appear favorable. Pirelli's are overated, you know somethings amiss when Ferrari equips their cars with Bridestones and not even tires from the 'motherland'OriginalWheelman wrote:Wide tires in winter = death.
http://www.tirerack.com/tires/...ace=8
Put those on the OEM rims for winter and keep those sweet looking wheels for summer's dry pavement when you can actually hook up.
This advice can be used for everything in life children.xekushnr wrote:Forget the other mods until you have good rubber.
They should be summer tires as the only viable reason to lose control so fast at low speed 30mph. I drove my car a few times last month and it got hairy at night. BFG kdw2's 225/255 (summer tire) first 15mins its like ice skating the eventually warm up but not that to proper temp. My tail came around twice 1 time at 60mph not all the way just 50degrees. This was when I decided it was time to garage the car and take out the beater for winter. This was just in cold night+wet pavement(stoneish cobble)skydragoness wrote:Also, I looked up the tires that come standard on the G35 coupe sport package, Bridgestone RE050A---which are summer tires. That's probably what nearly killed you. Summer tire compounds turn into solid rocks as soon as temps drop under 50 degrees. I'm really surprised at all this, I hope you correct me and tell me there were at least all seasons on the set of tires your "friend" sold you.
I recently spent a day in a snowy parking lot testing many of the newest snow tires, thank you Tires Plus . I am also an avid supporter of snow tires and have owned 4 different sets, I want to know what is out there so every time I need a new set I get somthing different.skydragoness wrote:
If you want to talk about hardcore snow tires nothing beats Nokian Hakkapeliittaa's (only thing close are Bridgeston Blizzak's but they wear down a lot faster). I recommended the Dunlop Winter M3's because of their superior test results from TireRack, the exc. customer reviews and because they are more suited to a sports car vs a true snow tire that rides like saltwater taffy.
Good post, you built on what I mentioned w/ more experience. I would hate to live in MN with the winters you guys get. I wouldn't even have a 240, i'd have an STiSideWays=smiles wrote:I recently spent a day in a snowy parking lot testing many of the newest snow tires, thank you Tires Plus . I am also an avid supporter of snow tires and have owned 4 different sets, I want to know what is out there so every time I need a new set I get somthing different.
Hakkapeliittaa's FTMFW I have driven on a few different snow tires and the Hakk Qs or RSI's have no equal, the traction is unreal. For extreme snow and ice traction this is the tire to choose. There is a set on my wifes car now.
The Blizzak's are the closest to the Hakks, the WS 50 (discontinued) was awsome, but the WS 60 does a very good job filling its shoes. For low profile applications the LM 22 and LM 25 do a decent job, but their sidewalls are stiffer to protect the wheel. This stiffness reduces snow traction.
The Michelin Arctic Alpine's are a decent snow tire, on dry they rode the best of all, and they also had the best dry tracking characteristics. My only complaint is the damage caused to aluminum wheels a problem Ive seen in all Michelin tires. The Arctic Alpine has been replaced by the Pilot Alpine.
Currently I am running a set of Yokohama Ice Guards. They have great snow traction, and the ice traction is linear and easy to sense. The only complaint I have is the lack of wet traction, an issue I didnt notice with the Hakks, the WS 50s, or the Pilot Alpines.
The Pirelli's are decent but I havnt spent enough time with them to form a decent opinion.
The Dunlop Winter M3's are a great all around snow tire, and they are priced just right.
The Winterforce M+S is a snow tire for those on the cheap, it cant match the true winter tires in performance, but its a bang for the buck that many people find to good to pass up.
Also, dont forget, sizing is just as important as tire choice, for a snow tire you want a skinny contact patch, and a tall sidewall. For a 240SX with a 16 inch wheel, your choices are rather limited, a 205/55/16 is your best choice. If at all possible, change to a 15 inch wheel, this will allow you more options, and it will also reduce the cost of the tires themselves.
Cliff notes\\ If you drive in the snow, get some Hakkapeliittaa's, your car will thank you.
I wish more people would realize this.skydragoness wrote:All-seasons just don't cut it for winter, they're only okay if you live as south as I do or further down.
Exactly right!!skydragoness wrote:All-seasons just don't cut it for winter
, but what matters is your safe.PMSing Chicken wrote:Shouldn't you switch those around. Nice G35 rims with low profile rims for the summer and stock one rolling on winter tires in winter. I think that would make much more sense.
