s13 sr20 bad idle before reaching normal operating temp
DailyDrivenS14
Car: 1996 Nissan 240sx KA24DET, 2007 Gsxr 1000
anyone got any ideas...? after it is warm it runs perfect...
Fenvy
Car: 2005 350Z Base 6MT
is it stock?
if you upgraded something like injectors and it's not tuned cold start then this will occur
DailyDrivenS14
ya pretty much all stock. it has a safc on it but as far as i know other than small bolt ons (z32 afm, fmic...). I have only had the car around a month and it did NOT do this when i bought it...
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
When the motor is cold, the idle speed should higher like around 1200 rpm. If not, adjust the 'fast idle' cam.
DailyDrivenS14
well its not just low but also when you are driving it cold (lets say at 3500 rpms) it will feel like you completely let off the accelerator for about a second and a half and then it kicks right back up
DailyDrivenS14
i meant its not just a low idle sorry
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
- Make sure the spark plugs are clean.- Check for a vacuum leak in the intake system.- Make sure ignition timing is set correctly.
DailyDrivenS14
hmmmmmm.... ok ill keep you posted thanks
