G35 Auto Transmission Bang/Bump
A general discussion forum for G35 and G37 owners and a great place to introduce yourself to the NICOclub G-Series Forums!
2004G35Coupe
Car: 2004 G35 Coupe
I know I've read posts here on this topic, but the search function isn't much help. I may be missing how to search *just* the G35 forum but I'm getting threads from all over the Nico forums when I try.
So, I apologize if this has already been discussed...
My 2004 Coupe has a problem with the transmission where it "bangs" or "bumps" as it shifts...usually around 40mph. I had read on this forum where this was a simple fix for the dealer to make and wanted to make sure I had that info when I take it in for the service. Can anyone remember or find where this was discussed? It would be greatly appreciated, thanks!
2004G35Coupe
Car: 2004 G35 Coupe
So, no one remembers what I posted about above?
G_whizz
Car: 2010 G37 Coupe Sport
Sorry...I never even saw your thread??
I have posted this question to the online mechanic ... help will be on the way soon!
Q451990
Unfortunately, I don't remember anything about this... I found one TSB, but this isn't from a complete list, and I don't think it applies to your model year. Maybe this is what you were thinking of though?
http://www.infinitihelp.com/Ow...4.htm
http://www.infinitihelp.com/Ow...M.htm
Good luck!
Heath
2004G35Coupe
Car: 2004 G35 Coupe
Okay, thanks for the replies, guys.
I know I read a thread on this topic here at Nico shortly after I bought my car back in March. But my searches aren't fruitful as it returns everything from all of Nico, not just hte G35 forum. Anybody got any suggestions for more effective searches?
The solution was a simple replacement of an item in the transmission, so Q45's service bulletin item sounds like the ticket...but my car is newer than what is listed in that service bulletin.
The harsh shifting I'm experiencing is very consistant (not to mention disconcerting) and I would like to get it addressed.
2004G35Coupe
Car: 2004 G35 Coupe
Well, no wonder my searches were coming up empty. It looks like the G35 forum only goes back to mid-April even with the "365 days" setting enabled.
Anybody know how to get to threads older than April?
Beancooker
Search using the "archived content" in G35 forum and you can alternate from "topic title", "to post bodies", and it will give you a much larger response.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Pretty common on the Q45s. What I woudl do is get a bottle of lubeguard RED and throw it in there....
Q45tech
In the case of 5AT Lubeguard BLACK would be more useful as it is closer to the special ATF used to deal with the dual lockup clutches.
2004G35Coupe
Car: 2004 G35 Coupe
FWIW, this must be the thread I was thinking of in my initial post here:
zerothread?id=229339
(thanks for the help with searching the archives, beancooker!)
Just to followup, but my dealer didn't notice any problems with my car when they tested it last weekend (figures). It happens pretty consistantly for me though. It's almost exactly like the documented problem with the 2003 and earlier G35 transmission's though. A harsh transmission shift at low speeds, and slow ability to engage at all speeds. Frustrating.
Q451990
See if you can get the tech. to ride with you on a test drive. The area around d!ck Smith has a wide variety of hills and speeds... you should be able to recreate it, even if the tech. didn't.
Good luck!
Heath
Return to “G35 and G37 General Discussions”
