oh, good catch! i'd also like to know this as i have a set of these on the way as well. it seems as though all the cheapo ebay stores got their shipments in. i jumped on them quickly.S-13 wrote:I just finished dropping in my smoked version of these lights and after putting it all back together I realized I couldnt re-use the 8mm nuts that were on the factory lights and ended up buying 10mm to secure them in place. Did anyone else run into this problem?
all reports i've heard are that all of these clear tails for the coupe/vert are made from the same manufacturer that makes the origin lights. everyone that i know who has them says they're really good quality. i don't know. i'll find out soon enough.S-13 wrote:looks like cheap made in taiwan mass produced item
Something's not right. I reused all my nuts and they fitted just fine. Manufacturer must have changed something or your lights came from different manufacturer.S-13 wrote:I realized I couldnt re-use the 8mm nuts that were on the factory lights and ended up buying 10mm to secure them in place. Did anyone else run into this problem?
Now having said that the new bolts will most likely be 10mm you might have to enlarge some of the holes a little bit to be able to get them flush again.
That's exactly what I did. It's summer time, so it's going to be easy to remove factory tail lights. Heat up old butyl rubber with hair dryer and use this method.S-13 wrote:I was able to get rid of all the old butyl without any solvents by tacking a small chunk into a sizeable ball and quickly "jerking" the strips away from the body and repeat.
Yeah, that's how I've always done it, but it takes awhile and is a PITA to do on two broken wrists =/ Does that 3M stuff help in the actual removal of the tailights though? That was one of the hardest parts for me, that dum-dum gets stuck in there good.94_240sx wrote:^^Actually, you can grab a chunk of dum dum and tap it along the old seal. That way, dum dum will pull all the old stuff. It's fun too.
Not on my 240 or SE-R. Both required lots of scraping. I think it varies from car to car.94_240sx wrote:^^Actually, you can grab a chunk of dum dum and tap it along the old seal. That way, dum dum will pull all the old stuff. It's fun too.
No. The best thing to help remove the tail lights is heat...so after sitting in the sun for an hour or more, mine came out with ease. I pushed mine from the inside with my palm and they were no trouble at all. As for the 3M adhesive remover...it helps clean-up after the tail lights are out. Actually I used a plastic scraper and a wooden paint stirrer to get the big chunks of dum-dum off then used the 3M adhesive remover to get the rest off. It just melts it away.Loki wrote:Does that 3M stuff help in the actual removal of the tailights though? That was one of the hardest parts for me, that dum-dum gets stuck in there good.
