Photos of my LS6 Swapped S13
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Just got done with the Engine swap. Still debating what rear to use, and a lot of body work needs to be done. I have an s15 conversion for the front.
There is to much to list but the basics
1991 240 FastbackLS6 V8TH350 with shiftkitRear???Fuel CellOptima RedtopLarge trans coolAll new suspension bushingsAdjustable traction, toe, and camber rodsGodspeed Anti-sway bars5 Lug conversion18x10 rear, and 18x8 Konig UnknownsAutometer gauges in custom gauge cluster50MM widebody quartersS15 Front-end conversion180SX Tails
Tip of the iceburg
Pics Moved, Go herehttp://s32.photobucket.com/alb...40SX/
Modified by OutToWinPAHC at 11:38 PM 7/11/2007
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Nick240sx
Car: 2009 Ford Fusion SE Sport
Thank you.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
im thinking about using a Nismo 1.5 rear. I havent one my research on the rear options too much yet. ITs not going to be a drift car, just a fun street car, plan on doing some racing
the_momo
Car: 1997 VW Golf K2 (His)/ 2001 Black Lexus IS300 (Hers)
fwiw, i have the same trans as you in my sbc swapped coupe, and it is rather hard to come up with a useable gear for a nissan diff. i had considered going to a solid rear axle with something like a 3:08, but thats a little too low for me really. unless you have an e overdrive youll find the same problem.
im actually going to go to a 5 speed so i can have an overdrive gear and keep a decent rear end gear, and not have to spin to engine way out to get any kind of speed.
http://www.f-body.org/gears/
this helped me a lot. good luck!
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I would prefer a 3.7 gear, this is a good trans but when it goes i plan on using a 5 speed auto with OD. The trans in here now ran me about 1200 bucks to have build so I didn;t want to waste it.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
why a 5speed, why not a T56?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Just ordered some new goodies. 90mm Intake, Throttle body Fuel rails, and 60# injectors. A pair of used LS2 heads which I will get redone, but I have to talk to the guy at the performance shop to see what he thinks I should do for a cam. 500 ponies here I come
The good thing is now I have LS6 heads, Cam, intake, and throttle body for sale so I can re-coop some of my cost.
the_momo
i already have one. t56 costs more than free. and iirc the t56 doesnt exactly bolt up to the gen 1 iron block sbc. but i dont remember exactly.
either way, if i got a t56 for free, thats what id use.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Just get it built up. The T5 can be built for serious power, or for a 4 banger. It was used in so many applications, but the good thing is theres parts kits for what you desire.
Return to “Hybrids”
