DropTopRB »
https://forums.nicoclub.com/droptoprb-u61454.html
Mon Apr 16, 2007 3:27 pm
The sensor imput is on the end of the transmission. The transmission came on the engine, it just didnt have any sensors in it. Do you think that the transmission will work, ive had it off to put the clutch and flywheel on, and i replaced the throw out bearing, and everything went smooth. What are the possiablities of trannys that it could be, the sensor looks like it needs to be alot shorter??? I need some serious help, i got fu**ed on this engine. Wrong ecu, wrong transmission, wrong wiring harness, and the shop wont do anything for me....Im really starting to get discouraged. Maybe i should have just stuck with the sr. Thanks everyone...
