DIY: Greddy Rocker Arm Stoppers Install (with pics)
DuckyD
Car: 1995 240SX
This is taken from my website that I am still developing. In the meantime I'm happy to share with the NICOClub family!
Installing Rocker Arm StoppersFor S13 SR20DET motors---------------------Rocker Arm Stoppers (or RAS's for short) are a must for any SR20DET. They're pretty cheap, easy to install, and will prevent bent valves. Think of this as an insurance policy for your SR20. ---------------------First and always, disconnect your battery before servicing your vehicle. Drain your oil. Next, remove the spark plugs and get them out of the way. Also disconnect the air-line to the factory oil catch-can and remove the line that goes to the throttle body.Now start removing the 10mm valve cover nuts. There should be 13 in all (5 on either side and 3 down the middle. ---------------------Now you can see the guts, pretty confusing, eh? Well first, be very careful as you don't want to get any debris in your head.Begin to loosen the cam bolts in alternating order. ie, loosen the front two then the back two, etc. The FSM (available here, page #59) details exactly how to remove them.
Pic from the FSM:---------------------A detailed look at the cam bolts and cam brackets. You're going to remove the "outside" cam bolts but you still want to loosen the "inside" bolts as well. Keep the bolts in order as you take them out. ---------------------The "fingers" of the RAS's will sit down inside the head and sit just above the rocker-arm. Now you see why they're called Rocker Arm Stoppers.---------------------Tighten the bolts. Factory spec is 8.7 ft-lbs but many owners like to go just a tad tighter. Again double check your factory service manual.
---------------------The "driver" side is very similar with the exception of this oil baffle. After a search on NICOClub, I found that some owners remove the baffle. Others cut it down for fear of blow-by. Since I have the time and tools, I am going to cut mine. ---------------------Removed, as you can see the curves on the end will get in the way of the RAS's. ---------------------After a little time with the Dremmel, the edges are now flat. I will install the RAS under the baffle and it'll be just like stock. Be sure remove that the new cut is nice and smooth, you don't need any metal shavings in your head.Again this part seems to be optional as some owners have just thrown theirs away. If you don't have the tools or if the baffle is already missing, don't sweat it. ---------------------Fits like a glove. ---------------------There, done. The Rocker Arms Stoppers are in. You're not going to gain any performance but I guarentee that you'll sleep better at night. ---------------------The factory rubber gasket is reusable and I used Permatex Ultra Gray liquid gasket for a good seal. Other liquid gaskets and RTV's may work as well. This is the gasket for the sparkplugs.Edit: Again, I did use the rubber gasket, although it is not pictured here.---------------------On a side note: If you like, you can remove the timing chain guide that sits between the cam sprockets. It's only held on by two 10mm bolts. Some owners remove this guide because it can create some extra noise from the valvetrain; it is especially common to remove on KA's. I left my installed because I figured it would give me an early warning if my timing chain is starting to fail. ---------------------
This write-up is for an S13-SR20. S14 SR's have a different valve cover that has to be modified to fit Rocker Arm Stoppers.Head over to Zeroyon.com and check out their Tech section for an S14 specific writeup.
Time Spent: 2 hours Total cost: $50
***Important Notice*** Please follow all safety precautions when servicing your vehicle. Failure to do so may result in expensive damages to your car and injury to yourself. This write-up was done in good faith to assist other auto enthusiast. Please check the factory service manual and your local dealer before attempting any work on your car. I take no responsibility for your actions. If you chop off your finger, you're on your own :D
Modified by DuckyD at 1:26 PM 1/17/2007
Blown240sx
Car: 1996 240sx
Confused as to why you used RTV Sylicone on the valve cover when the factory gasket is reusable?
ILikeMy240sx
Car: SR Power
I cant believe you used RTV instead of the rubber gaskets... Why would you do that?
I highly do NOT recommend using RTV gaskets as they will not seal properly since its not a seal between a flat surface and a flat surface. The valve cover has a groove for the rubber gasket so if you use RTV, it will NOT seal properly.
The only part that RTV is required is for the half moons on the front and the back of the gasket.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
nice writeup. i have the modified magazine where they put ras in an s14 sr and you have to cut out part inside the valve cover.
fregisr
Car: 240sx 1990
you should edit it and put down the Torque for each bolts and the order it goes back in so we don't have to look it up on the fsm...lol. nice write up though
DuckyD
Car: 1995 240SX
I'm sorry I should have clarified. I did use the rubber gasket and applied RTV to get a better a seal. I went back and looked at the pictures and realized that it could be confused that I did not use the rubber gasket.
Per suggestion, I took the pictures from the FSM and added them in.
Modified by DuckyD at 1:20 PM 1/17/2007
dickie
Car: Killer Turtle
need those watermarks removed to be able to article-ize this.
SilviaSlydSydway
Car: 1991 Red KA-T~~~1989 White Coupe
This write-up is awsome. i didn't really want to do this myself, but i definatly will now...
nwmrkt
Car: S13
so even on a stock SR this should be done for extra insurance?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
nwmrkt wrote:so even on a stock SR this should be done for extra insurance?
Yes.
GOD DAMNIT i just bumped a 2 year old thread to say Yes.
At least that is cleared up?
xiaphin
Car: 10' Genesis Sedan 71' Datsun 510 90' S13 Fastback SR
[quote]After a search on NICOClub, I found that some owners remove the baffle. Others cut it down for fear of blow-by. /quote]
Couldn't find any helpful info in the FSM on this piece so it must not be that important. In the cylinder head breakdown it has an arrow saying refer to timing chain install but nothing there. Thought the baffle might have something to do with this thing in top of valve cover but its on the intake side. Any one know what the baffle and/or the peice in valve cover is for???
OM3GA - Great minds think alike. Bumped a 5 month old thread.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
The baffle is to prevent oil from splashing into the T fitting that gets recirculated into the intake... This is why, sometimes, you see some modified SRs have 2 catch cans.. The factory (ugly) black one, and then some sort of an aftermarket one...
xiaphin
Mines not installed and I dont really feel like putting the baffle on if its not necessary. So without the baffle installed how much extra oil are we talking? There cant be a whole lot of pressure in the valve cover if there is only one baffle.
