 Megasquirt Write-up for KA24 series engines.First  1 2 >  Last
The_Chosen_One
2005 Subaru Impreza 2.5RS
Boca Raton FL
10-17-2006
With permission by the crew at DIYAutotune (Jerry, Matt) I am posting up the write up they did to install a Megasquirt ecu on stock KA ignition.
Quote, originally posted by DIYAutotune »
Jerry and I have put together a guide to setting up Megasquirt on the KA-series engine. Right now this article covers what specific mods you will need to the Megasquirt and what wiring you will need to set up Megasquirt on an S13 with a KA24E or KA24DE. We'll be adding more information on settings, the S14, and the factory ignition module soon!
How to MegaSquirt your 240SX
Directly driving the coil with the MegaSquirt-I PCB 3.0 and MSnS-E 029v or later or the MegaSquirt-II
Updated 1/10/2007
Application(s): 1989-1994 Nissan 240SX with KA24E or KA24DE
Also applies to 1994.5 and later converted to an external coil distributor from the 89-94.
Other vehicles with KA series engines, such as Nissan pickup trucks, are similar.
Level of control: Full Standalone EMS-- Fuel and Ignition Control
The optical trigger on a 240SX may look a bit complicated, with two rows of slits and the unequal slit sizes in the inner ring. However, setting up Megasquirt to work with this ignition is surprisingly simple. Megasquirt does not need or use the information provided by the second ring of 360 slits or the length of the inner slits, so you just need to obtain a signal from the trailing edge of the ring of 4 slits. This writeup covers using a VB921 for controlling the coil.
ECU Modifications
It's choice time, MS-I with MSnS-E firmware, or MS-II. The choice is yours. It's possible to make your KA run with either ECU. The MS-I with MSnS_E is extremely mature, has a ton of features, and is pretty near the end of its development cycle. The MS-II is much newer, faster hardware, though the development is really just getting kicked off. While it has some features that MSnS_E doesn't have, the reverse is also true in that MSnS_E has some features that the MS-II doesn't have (though most require mods to enable them). The writer of the MSnS_E firmware has been conducting some tests on the MS-II firmware and I expect to see some really cool things happen soon...
Using the MS-I PCBv3 with MSnS-E firmware
This is assuming you are starting with an ECU built up like I build my assembled MS130-C MegaSquirt-I PCB3.0 units. If you are building your unit up from a kit you can implement these changes during assembly.
  • Flash ECU with MSnS-E version 029v or later. (How? Click Here.) (Or Here)
  • Jumper IGBTOUT to IGN to send to IGBT ignition coil driver signal out of pin 36 on the DB37.
  • Cut out C12 and C30. (Only needed when triggering from the - terminal of the coil, which you are not)
  • Remove D1 and jumper it, or just install a jumper wire across it's leads. (Only needed when triggering from the - terminal of the coil, which you are not)
  • Cut out R57 if fitted (this won't be there on my units though).
  • Get a 330 ohm 1/4w resistor and cut the leads down to about 1/2" at each end. Maybe a bit less.
  • Tin each end of the resistor with a bit of solder.
  • Cut a 5" piece of hookup wire (22ga is fine) and strip just a 1/8" or so. Tin the stripped wire with solder.
  • Melt the tinned wire tip to one end of the tinned 330 ohm resistor tip and let it cool.
    • Heatshrink wrap this wire/resistor assembly.
    • Use this wire/resistor combo to jumper the 'top' (top as in when you facing the silkscreen side of the PCB, with the text so that you can read it normally) lead of R26 to IGBTIN on the opposite side of the PCB.
    Thats it!
    Using the MS-II PCBv3 ECU
    • Build the ECU up to trigger from the Hall/Optical Input (all of our MS230-C units are by default configured this way).
    • The only change is to enable the IGBT High Current Ignition Coil Driver Circuit to directly drive the coil.
    • Remove the jumper from JS10 to IGN (if exists)
    • Jumper IGBTIN to JS10
    (This will enable the VB921 Ignition Coil Driver)
    Thats it!
    Wiring]
    The output is quite straightforward - you will just need to connect the negative terminal of the coil to pin 36. The specifics of the input wiring will depend on which year 240 you have; Nissan changed the wiring colors in 1991. However, the wires serve the same purpose; only the colors changed. Note that these years apply to the 240SX and are not the same for other KA-powered vehicles. For example, it appears that some Nissan pickup trucks with the KA24E engine retained the earlier color scheme for considerably longer.
    Distributor Wire Colors
    '89-'90 [Purpose]
    B/W [12v]+
    G/B [MS Trigger (to Pin 24 on DB37, or Relay Board TACH terminal)]
    G/Y [not used]
    Black [Ground]
    '91 and later Purpose
    B/W 12v+
    White MS Trigger (to Pin 24 on DB37, or Relay Board TACH terminal)
    Black not used
    Black Ground
    Fast idle valves, relays and other components
    The 240SX used a thermal type fast idle valve that just needs to be supplied with 12 volt power when the engine is turned on. The valve will open on its own, so you do not need to set up any sort of idle control with Megasquirt.
    The stock Nissan ECCS relay is grounded through a circuit in the ECU. Also, the stock S13 wiring harness is set up to send the injectors 12 volts at all times, even when the ignition is turned off. When converting to Megasquirt, the injectors must not have 12 volt power unless the Megasquirt is also powered up. Sending the injectors 12 volt power with the Megasquirt ECU off can result in damage to the injector drivers.The wiring diagram below shows one possible way of modifying the stock wiring so that the ECU and injectors power up at the same time, and also allows the other components drawing power from the ECCS relay to work as normal.
    An alternate method of dealing with this is to use the Megasquirt relay board instead of the stock ECCS relay to power the Megasquirt, injectors, and crank angle sensor.
    MegaTune Configuration for MSnS-E
    On the 'Spark' menu choose 'Spark Settings' and set 'Spark Output Inverted' to YES. It is critical to get the Spark Output Inverted setting correct, as setting this wrong can result in damage to the VB921. Dwell settings will depend on the coil used. A typical rule of thumb is to back off the dwell until you can just barely detect a misfire under lean cruising conditions, then add 0.2 ms of dwell time.
    If you use someone else's .msq file I do recommend you check the MSnS-E firmware version the .msq file was built on as you cannot always use a file built on one version of MSnS_E with a different version-- it's best to use the .msq files with the same version of the MSnS-E firmware that it was built on.
    MegaTune Configuration for MS-II
    As this is a 'path less traveled' thus far you probably won't find people with maps to share for your car just yet. You can however dial it in with a bit of patience and some 'how to tune' homework, most of which you can do in the Megamanual at http://www.megasquirt.info.
    Set ignition capture to "Falling Edge."
    Important when using the VB921: On the 'Ignition Settings' menu make sure to set 'Spark Output' to 'Going High (Inverted)' and set 'Coil Charging Scheme' to 'Standard Coil Charge'.
    We'd like to hear from you!
    These settings cover the basic hardware changes required and some of the MegaTune settings based on our research and customer feedback, but we would love to hear from anyone who has set up Megasquirt firsthand on a KA24E or KA24DE and would like to share their configuration settings to help better this article. Also were particularly interested if you are using the stock ignition power transistor (ignition module) instead of VB921 direct coil control which will simplify things further for many. We have a couple of local 240's we may get in the shop soon to 'squirt and further improve this article.
    If you have any further information, contributions, or questions about this article, please contact us..
    Again I do not take credit for this, this was done by the awesome crew at DIYAutotune and gave me permission to post this.
    Definatly will go great with the other write up for the CA.
    fiznat
    Supporting Member
    S13 240sx x 2
    Middletown CT
    9-15-2002
    Nice, thanks Chosen One and thanks DIY AutoTune!
    I'll add it to the stickey.
    Fiznat
    KATwo40
    1993 240sx KA-T
    2-1-2005
    Very cool.
    The longer the sig, the slower the car...
    Biggamehit
    89 KA24DE-T
    Misawa, Japan
    1-30-2005
     « Re: (KATwo40)
    cool
    im so glad I did great in electronics in highschool very straight forward and simple schematics
    im doing it very very soon
    Http://BigGameHit.TeamMNR.Com
    Http://DonaldJackson.TeamMNR.com
    WDRacing
    Porn Crusader
    1995 240SX, K5 Blazer
    USA
    11-25-2002
     « Re: (Biggamehit)
    I added it to the articles forum. Great info, pass on my thanks.
    WD
    Truth is Treason in the Kingdom of Lies - Ron Paul
    bige240
    3-21-2006
     « Re: (Biggamehit)
    The guy from DIY autotune posted this link in the ka section. This is some of the best info out there besides the megasquirt Mega manual... I wish I woulda found this first. Great info for megasquirt interested people.
    http://www.diyautotune.com/tec...s.htm
    daconkiftador
    Classified$ P0st Wh*re
    '92 Coupe SE, '83 Rabbit GTi
    Clarkston WA
    1-14-2006
    awesome!
    FS: DOHC KA24DE Timing Chain Kit, OEM(yes real Nissan) Brand-New! eMail me.
    WDRacing
    Porn Crusader
    USA
    11-25-2002
     « Re: (bige240)
    Added that to the sticky as well, what we need are a few more members running MS.
    WD
    S13FX
    Polish Forum Moderator/ Web Dude
    1990 Something or Another
    Lake Villa IL
    4-30-2005
    Great now that I crash my car you guys post this. Maybe if this came a week earlier I wouldn't have crashed my car, cause I would have been busy installing MS lol. Awesome JOB BTW.
    The_Chosen_One
    Boca Raton FL
    10-17-2006
     « Re: (WDRacing)
    Quote, originally posted by WDRacing »
    WD
    You'd be surprise how many people are running megasquirt on Nissans and 240's
    Biggamehit
    89 KA24DE-T
    Misawa, Japan
    1-30-2005
     « Re: (WDRacing)
    im comign soon, wait up
    bige240
    3-21-2006
     « Re: (Biggamehit)
    I promise I'm still gonna do a megasquirt write up...I'm just waiting until I've done all the tuning first, so I'm not talking outta my ***...But one thing my buddy who is well versed in megasquirt told me, he said you could run two different engines with it (pikes peak style). because it works in banks.. Thought that was a cool idea...
    The_Chosen_One
    Boca Raton FL
    10-17-2006
    do you mean 2 different maps? If so yes you can.
    TheOne
    93 240sx FB
    Arlington TX
    8-9-2004
    nice writeup, seriously makin me think about using MS, i though 1 of the hard parts was gettin the ignition installed, guess that made it easy.
    but really, somebody needs to do a full writeup of all the wires that go here and there on a 240, what sensors are kept, or wires, what gets used to control the idle and other things.
    93' 240sx fastback - 10.240 @ the local 8th mile.
    "Horsepower sells cars, torque wins races" - Carroll Shelby
    "Horsepower is the force that determines how fast you hit the wall. Torque is the force that determines how far you take the wall with you after you hit it." - Unknown
    "Real cars don't make power at the front wheels....they lift them."
    KATwo40
    1993 240sx KA-T
    2-1-2005
    I'd like to discuss with someone their thoughts on the reduction in map resolution when going with MS.
    The stock ECU uses 16x16 tables, whereas the MS uses 12x12.
    While both use interpolation to fill the gaps between cells, I wonder if anyone finds that they need to tune a particular area that just can't be accessed because it's an interpolation spot, rather than a tuneable cell on the map.
    I'm still not giving up on using MS, as I've been SERIOUSLY contemplating using it. WD and I have discussed this pretty in-depth and I'm nearing a point when I can do some MS testing.
    The_Chosen_One
    Boca Raton FL
    10-17-2006
    in reality really 12x12 is actually more than enough.
    The cool thing about the megasquirt software if their is a trouble spot, you can expand it and tune it more.
    you can also run Dual maps 1 for each bank of injectors.
    Interpolation happens on every single ecu because its impossible to map every point on a motor no matter how big your maps are, thats why it's EXTREMLY important that the code is solid to make good calculations when the system interpolates.
    I'm a megasquirt user with boost, to be honest my car actually feels a lot better than any stock ecu setup that I've driven or used. To put it bluntly it feels like I'm driving a brand new car thats how smooth it is, from normal cruising to boosting hard.
    Also a lot depends on the person tuning, after speaking with a few people that have used both stock and MS. Some said they had issues because their wasnt enough map points, it was the result of crappy tuning.
    Here are examples of insane Megasquirt setups with high boost.
    http://diyautotune.com/cars/cu...k.htm
    http://diyautotune.com/racing/...6.htm
    Dont forget these are computers based on user inputs "Garbage In, Garbage Out"
    The_Chosen_One
    Boca Raton FL
    10-17-2006
     « Re: (TheOne)
    Quote, originally posted by TheOne »
    Aside from the wires that are listed above for the distributor. Their is only 2 other wires to connect. 1 is Fuel Pump, their is a plug near the battery hold down area, its a Brown 8 pin plug, look for a Black/Pink wire thats your fuel pump relay wire thats where you wire up for Megasquirt. The 2nd wire is the 12volt ignition, you can find it on the ignition cylinder where you insert your key, test for the wire that gives power while cranking and on the run position I'm pretty sure its Black/White on the cylinder and when you follow it, it changes to a Black/Red wire.
    Go here for more info and pics.
    http://forums.nicoclub.com/zerothread/164446
    KATwo40
    1993 240sx KA-T
    2-1-2005
    So, with the MS2, you can pull the stock ECU out and sell it?
    WDRacing
    Porn Crusader
    USA
    11-25-2002
     « Re: (KATwo40)
    I believe basically yes. Although IIRC some people use the factory ECU for gauges.
    Great thread so far.
    KATwo40
    1993 240sx KA-T
    2-1-2005
    The only way I'm gonna use any standalone is if I can completely remove the stock ECU and still retain the OEM gauge operation.
    Hopefully Neo (The Chosen One) will chime in here with some good news for me!
    WDRacing
    Porn Crusader
    USA
    11-25-2002
     « Re: (KATwo40)
    Why? is it that important to remove the ecu? Are you being gay?
    S13FX
    Lake Villa IL
    4-30-2005
     « Re: (WDRacing)
    Do you really have to ask?
    KATwo40
    1993 240sx KA-T
    2-1-2005
     « Re: (WDRacing)
    Hell yeah, it's important. What's the use in spending several hundred dollars on MS (or any other standalone) if you still must shoulder the stock ECU? If I have to keep the stocker, I'll just use it for the whole deal.
    The_Chosen_One
    Boca Raton FL
    10-17-2006
    The Gauges are standalone, all the sensors run right to the gauge cluster.
    Just remove the engine harness, and ECU, but keep the lower harness as that connects your speedo, reverse lights etc etc. The lower harness connects to the main body harness which Tees off to the cluster harness.
    At the moment the DIYAutotune crew is experimenting with A/C load detection which is what the stock ecu does when you turn on the A/C. But if you arent using A/C it doesnt matter and your good to go.
    So yes removing harness and ecu is ok and cluster still works fine.
    The only thing you have to do is run a wire for your Tach to Megasquirt.
    The wire on the Tach is Yellow/Red.
    babowc
    KDM-NESS
    240sx
    Lawrenceville/Suwanee GA
    10-25-2004
    Nice! This should be a sticky! Unless it already is?
    WDRacing
    Porn Crusader
    USA
    11-25-2002
     « Re:
    What about ABS...any issues with ABS? I have no real idea how thats controlled, is it also a standalone system? This could sound stupid I guess but I don't care.
    The_Chosen_One
    Boca Raton FL
    10-17-2006
    For ABS I'm pretty sure it becomes neutralized, since its controled by the ecu. I'm sure Megasquirt can control ABS if you truly wanted because in reality ABS is just a hall sensor on each wheel, but come on real men dont need ABS
    WDRacing
    Porn Crusader
    USA
    11-25-2002
     « Re: (The_Chosen_One)
    Maybe I'm really a women inside of a man
    The_Chosen_One
    Boca Raton FL
    10-17-2006
    than whats with the Fetish of Flesh Lights as Your Avatar?
    WDRacing
    Porn Crusader
    USA
    11-25-2002
    I like to keep everyone guessing...
    sil80drifter
    1990 240SX Hatch
    Middle of CT CT
    8-18-2002
     « Re: (WDRacing)
    Can someone describe what exactly constitutes the "engine" harness which we can take out and have completely replaced by our own MS harness? We wouldn't want to cut out important wires thinking we don't need them...
    Also, I am a bit rusty on this, but does the engine harness control only fuel/spark? What controls thins like the alternator, starter, etc?
    I am trying to figure out whether it's worth to just make one's own harness for the MS...
    Has anyone removed the engine harness completely and made their own relay box? What would be included in such a relay box?
    My HUGE Part Out Thread
    I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
    bige240
    3-21-2006
     « Re: (sil80drifter)
    okay...If you throw away the entire engine harness, (every single little bit of wire in the engine bay), You would have to replace the injector, TPS, O2, coolant temp., and distributor wiring. You would also have to tee off the FPR vaccum line to go to the map sensor and add a GM ambient air temp sensor.
    The alt and starter are controlled by the ignition...
    In actuality you could just pull every one of the wires out of the back of the stock ECU and connect them to the relay board or make the pigtail to go to the megasquirt and just leave the rest of the stuff hanging.
    You can't make your own relay box, at least I don't think so. You have to buy the relay board, or make your own pig tail
    sil80drifter
    1990 240SX Hatch
    Middle of CT CT
    8-18-2002
     « Re: (bige240)
    Thanks!
    Well here is the deal... I think one of the really good reasons for making a new harness is that the one in there right now is between 13-18 years old. It's cracked, rusted, heat cycled, salted, oiled, etc etc etc. And in many cases (such as mine) the many engine pulls have nicked or damaged some wires to the point where they make the engine run poorly on the stock ECU.
    What you'v described below is SO easy to make! What about the various relays/fuses and etc, are those at all involved with the engine operation? Things like the fuel pump fuse, and etc...
    I just saw the ending of your post about buying the relay board.
    Has anyone got an examples of such a board on the 240? What relays are needed and which can be re-used?
    Also, does the tach use the engine harness for signal? I know that once I've connected my SAFC, the RPM's wouldn't work right on the SAFC (but worked fine on the tach), but then, oddly, when I connected the MSD BTM (some wiring on the coil) the SAFC started working great but the tach died. As soon as I unplugged the BTM and replugged the wires on the coil, the tach came to life again and the SAFC started showing rpms poorly like before.
    So those are some of my worries about the engine harness...
    bige240
    3-21-2006
    You are right about just wanting to make a new harness, the stockie is old and messed up, and has some stuff you don't need. It'll also help you trouble shoot, since you know exactly what wires are going where. Just snip off the stock plugs with some wire to spare and splice your wiring onto them.
    Looking into the megasquirt relay board is something you might want to do, since it makes hooking up the harness 100x easier. The relay board has fuses in it, and also has a signal for the tach and the fuel pump. You just screw your wires into a block that has everything simply labeled for you.
    Yes the tach gets its signal from the engine harness, namely the dizzy wiring, but with the relay board you just connect everything up and you run a signal wire to the tach from the relay block, along with a power and a ground.
    I'm not sure what relays you'll want to keep, since I went buckwild and tore them all out.
    You can also do ABS Megasquirt, if you so choose...The hall sensor is a powerful thing...
    98240kat
    1998 Nissan 240sx
    Pembroke Pines Fl
    2-5-2007
     « Re: (bige240)
    My only real qualms are these. Assembly for one. Although I have quite a bit of expirience in electronics from building computers to electric race cars assembly is still an annoyance and risk. All its takes is one slip with a soldering gun and ur out 256 bucks pretty much depending on what part u happen to score. My other qualm was I believe somewhere on the page it stated the map sensor was only good for 21 lbs of boost, which i plan on running possibly more on occasion. And our course the wiring could be a bit crazy all depends on the person and what have you. My one question is does anyone know if it will work with 98 style KA24de? If so do all the same guides above apply? Also if it was a matter of 1000 dollar difference would u just buy an AEM EMS if you had te money?
    bige240
    3-21-2006
     « Re: (98240kat)
    You do not have to assemble the board by yourself!!! You can buy boards already built from several places including DIY autotune and Ebay for not much more money.
    This ecu will work on ANY fuel injected engine.
    You can get a 2bar (26psi) or a 4bar (52psi) map sensor for the Board also and run boost until your engine explodes.
    The wiring is very simple and not much different than the wiring you already have in your engine bay.
    I could buy just about any standalone out there and I still like the megasquirt. If more 240 guys would buy it, I'm sure someone would make a plug-and-play harness for it just like someone did for the Toyota 4AG series (corolla, mr2) engine.
    FattyMcBaggins
    1990 Nissan 240SX
    San Antonio Texas
    1-22-2005
     « Re: (bige240)
    I am very interested in using this for my KAE-T. I'm not so great with wiring, but I think this would be a really good way to get a handle on it.
    98240kat
    1998 Nissan 240sx
    Pembroke Pines Fl
    2-5-2007
     « Re: (FattyMcBaggins)
    I think Im going to go with the MegaSquirt does anyone know of any diagrams or DIY's for a 95-98 model??
    sil80drifter
    1990 240SX Hatch
    Middle of CT CT
    8-18-2002
     « Re: (98240kat)
    Google it, but I'd doubt it.
    The guys above are the first ones to do a 240sx DIY as such, and I think they were doign it to show how to us a general kind of distributor setup with MS-I. I've already written tot hem and asked about any differences from that to MS-II, and will post their answer as soon as I get it.
    Their write-up above states that "We'll be adding more information on settings, the S14, and the factory ignition module soon!"
    So keep your fingers crossed and try to reasearch it on your own for now. Best of luck and don't forget to post any findings!
    sil80
    sil80drifter
    1990 240SX Hatch
    Middle of CT CT
    8-18-2002
    Don't I love myself for not reading things properly the first time!
    The MS-II changes are right there in the explanation!
    That's it!
    Well, at least the guys from DIYAutotune are really nice. Matt responded to my email almost immediately and was the one who pointed out that there are very few differences between the two boards in terms of set-up, so hey! I'm an idiot but at least it's all settled now.
    Let's hope they come out with something for the 95+ 240s soon.
    In the mean time I am selling my SAFC II, VAFC II (Honda phase, don't ask), SOHC VTEC Head and MSD BTM, so I can buy the MS! Whoo!
    sil80
     First  1 2 >  Last
