 Working Cruise on 5 Speed SR20DET Convertible
240sxConvert
1992 SR20DET Powered 5-Speed Nissan 240sx Convertible
Liberal KS
1-5-2006
I just thought I would let you guys know that I got my cruise working on my SR20DET powered 240sx Convertible with the 5 speed conversion. And the top works. I know this is not an easy task and if anyone is interested I will make a write up of how to do it. Please let me know...
Hijacker
240SX Moderator
'92 240sx Convertible
Roanoke VA
8-13-2003
I would LOVE to know. I've spent weeks trying to get the ASCD to work on some swapped verts to no avail. If you want to mail me at tenkawa_akito@hotmail.com that would be cool. Or we can do a write up to put in the vert forum kind of like my 5 speed swap faq
BTW, i deleted your post of this in the SR forums. It's more of a vert specific deal, but once you get a write up posted about it, i'll add it to the SR FAQ sticky
-Bart
Quote »
Hey wait. My balls don't hang too low yet
Stacey L. Childs, NICO Mom
Eikon
Super Moderator
'92 240sx 'vert with RB20
hidden
4-24-2004
 « Re: Working Cruise on 5 Speed SR20DET Convertible (240sxConvert)
Nice work!!! Please do share.
I've got an RB20, but I would guess the procedure is relatively similar. I'd really like to have cruise as well.
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
240sxConvert
Liberal KS
1-5-2006
 « Re: (tenkawa_akito)
I started this project yesterday after driving on the highway for six hours and finished it today. I converted my convertible to 5 speed a while back and just made it where my top worked. Also, make sure that when you swapped the 5 speed, you connected the brake kill switch (for lack of a proper name), that turns off cruise control when you press on the brake pedal. After I swapped my SR in I decided it would be nice to have. First I swapped the SR throttle body with the KA throttle body. The SR's never came with cruise control and thus they do not have another throttle pulley for the cruise control. It is necessary to do this. When you change the throttle body use the KA TPS and just change the connector or just directly connect the wires. They should be the same color and it should work. For the coolant line on the throttle body, I just connected the two hoses with a piece of pipe and did not run it through the KA throttle body.
I connected the speed signal wire from the cruise control module to the ECU. If you do not know how to do this, here is a link with pictures.
http://forums.nicoclub.com/zerothread?id=182123
Now for the inhibitor switch wiring. In the wiring there is a wire that completes the circuit. This is the black wire. Depending on which wire it is connected with, that tells you car "what gear it is in." On the connector, the green wire is used for reverse lights. I just wired that to the reverse switch in the transmission so that it worked how it was supposed to. The blue wire is to tell the car that it is in park or neutral, which for convertible owners, allows the top to work. The yellow wire tells the car that it is in drive and this is what allows the cruise to work. None of these can be connected at the same time or the cruise will not work. The reverse is fine as long as it is wired into the switch for the transmission. In order to get the top to work and get the cruise to work you need to make a switch. Only one will be able to work at a time. I am cheap and just cut out the overdrive switch in the stock auto shifter and used this.
That is what I did and everything worked fine for me...I hope it works for you too. As of now my clutch pedal kill switch does not work but it'll work for now.
240sxConvert
Liberal KS
1-5-2006
 « Re: (240sxConvert)
The Wiring
Attachment: MVC-001F.JPG (129424 bytes, downloaded 621 times)
240sxConvert
Liberal KS
1-5-2006
The KA Throttle Body
Attachment: MVC-003F.JPG (126721 bytes, downloaded 624 times)
240sxConvert
Liberal KS
1-5-2006
The Overdrive Switch I Used
Attachment: MVC-002F.JPG (130906 bytes, downloaded 593 times)
Hijacker
240SX Moderator
Roanoke VA
8-13-2003
Looks excellent! I'm gonna see what might be done about your switch for the park wiring/drive wiring. I bet we may be able to incorporate that switch into something else to streamline it a bit. From the looks of it, you have to manually get out of the car and complete that circuit with the chopped off OD switch. I have a nagging feeling that it may be possible to have the cruise on switch on the dash do the same function.
240sxConvert
Liberal KS
1-5-2006
Yes...I do have to get out of the car and pop the hood to change it from top mode to cruise mode...if that's what you would call them. I just wanted to get it working and so this is how I set it up for now. By the way, the switch just needs to be on the blue wire for the top. The yellow wire for the cruise to work can be on all the time, just when you try to incorporate the top with that, it tells the vehicle it is park and drive and it will not work.
Eikon
Super Moderator
hidden
4-24-2004
Fantastic Work. I added this to the 'vert Facts sticky.
Thanks for the contribution!
devonkyle77
hagerstown md
5-14-2003
"For the coolant line on the throttle body, I just connected the two hoses with a piece of pipe and did not run it through the KA throttle body. "
can you explain that in more detail?
240sxConvert
Liberal KS
1-5-2006
 « Re: (devonkyle77)
Coolant runs through the throttle body...which is not necessary unless you live in a really cold climate...so for the coolant line on the throttle body, i just used a piece of transmission coolant line and cut it and bent it to connect the two rubber hoses that used to connect to the throttle body...
Hijacker
240SX Moderator
Roanoke VA
8-13-2003
Just a small update to something I've been thinking of lately, if you solder the green/orange on the back of the top up/down switch to a voltage source (an ignition source would be best). All you would have to do is splice the wire for drive (Br/W from what I see in the service manual) to the G/L wire at the inhibitor to make the cruise work without needing a rocker switch
» Return to 240SX Convertible Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
