are you telling me that you're going to attempt this mod now? come on MEX, i'm expecting more from you
assuming you have the DPDT, you're going to see 6 poles total. find the common ground by testing it with continuity on your multimeter. now you're going to need two wires because one is going from the original plug to the switch and one back from the switch to the plug. for example, you cut the pink wire, you're going to have two wires; one end goes to the switch and you need another wire to go from the switch back to the plug.
you know what, drive up to CT, buy me some wings and beer and i'll hook it up for you
