Too much lag? Mine was hitting full boost around 3k before it grenaded.crazygrk3 wrote:i got a ca motor with the turbo of a sr motor and its i getting a to much lag and i run pretty rich anybody got any ideas on wat i can do to getting running normal
Yep sames hererico05 wrote:Start with the A/Rs of the turbine housing and compressor. My SR (.80a/r T25G) spools full before 3k RPM.
What do you want us to do? I don't have a "fix his car" button on my keyboard. And yes, that does help your problem by reenforcing the fact that your setup is messed up. What could it be? 10,000 different things. Start with the turbo itself. Are the turbine/compressor blades chewed up or broken? Is your manifold/turbine housing cracked? Do you have a big exhaust leak somewhere between the head and turbine housing? Do you have any boost leaks in your intercooler piping or intake manifold? Is the timing setup right on the motor?crazygrk3 wrote:i happy for you but how does that help my problem
