Simple S13--> Sr20 wiring question
Henry G
Black / Pink stripe Black / Pink stripe Fuel pump relayGreen / Orange stripe Green / Orange stripe Transmission neutral switchRed / Black stripe Red / Black stripe ECU relayGreen / Yellow stripe Green / Yellow stripe AC relayBlack / White stripe Black / White stripe ECU powerBlue / Green stripe Blue / Green stripe AC relayBlack / Yellow stripe Black / Yellow stripe Idle air control solenoid powerBrown Any +12V Switched O2 sensor powerRed Red ECU backup powerBlack / RedBlue / Red Black / Red stripe Main ignition power
Using the frsport.com's wiring guide and I'm not 100% sure on which wire to use for the brown wire. Which +12V wire should be used?
highmilehatch
There is a brown wire on the SR harness for the 02 as well. Just connect them together.
Henry G
highmilehatch wrote:There is a brown wire on the SR harness for the 02 as well. Just connect them together.
Which?
ILikeMy240sx
Car: SR Power
the brown wire coming from your SR harness is for O2 power. I just hooked that up to ECU power (black w/ white stripe) on KA plug
Henry G
ILikeMy240sx wrote:the brown wire coming from your SR harness is for O2 power. I just hooked that up to ECU power (black w/ white stripe) on KA plug
Thanks!
