young-gunn »
https://forums.nicoclub.com/young-gunn-u33524.html
Thu Aug 03, 2006 8:49 am
ok, so my car wasn't firing on cylinder 2&3 before. I found out it was the computer. I changed the computer yesterday, and it ran fine and on 4 cylinders. I adjusted the idle, then I drove the car out of the garage and parked it outside, started it again and moved it. I left it there, did the sleepy eye mod, then left it for the night, came out today, Dead battery. So I boosted it and it was running terribly. So I checked, not firing on cyl. 2? huh? So I shut it off. Started it again and it ran worse, now it's not firing on cylinder 2 AND 4 (the idle also slowed down by about half). So I got the test light, power at all 4 cylinders, then to check for ground. Only the Cylinders that weren't firing had a ground, and it was constant (cyl. 2 had a strong ground, and cyl. 4 had a weak ground). and the cylinders that were firing had no ground!? My dad also pointed out as he walked by that it is firing pretty much raw gas out of the tailpipe. I have no clue what could be wrong here, it ran fine yesterday after I installed the new computer. Could this computer have fried? I am so lost on this one. Please help!
