skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Wed Aug 23, 2006 7:18 pm
Quick update:
Replaced the turbo with one that has perfect seals, and its still screwing up. Replaced the O2 with a new Z31 unit, still screwing up. Soooo, I started unplugging stuff to see if it made any changes. I may be going vrazy but nothing I unplugged seems to do anything Maybe Im just getting frustrated...
Anyways, still could be a bad FPR I suppose, even though I unhooked the vacuum line to it and it actually did idle worse, same other issues though.
Some clarification also. The car runs rich all the time, but every now and then it just completely kills itself. It will BARELY even drive, so much black smoke I dont know, its crazy. Bucks and kicks, etc. If I dont rev it at idle it will die, and sometimes it wont crank back up for awhile, usually after the ECU has been cycled off and on.
Someone PLEASE help me out, I know there has to be something Im missing. Could it be a bad ECU? When I put the new O2 in it cleared up for a few minutes, ran nice. Then it started all over again.
I have done the following:
replaced/regapped spark plugschecked the timing at the front and rearreplaced the MAFSchecked/rewired all the MAFS wiringreplaced the O2replaced the turbopulled CAS and checked to see it is firing on all 6replaced coolant temp sensor with another used RB20 unitchecked for boost leaks. has a SMALL pinhole on a weld, thats it.unplugged the TPS, MAFS, coolant sensor, IACV, O2, no changes
Things I havent done:
Knock sensors, but no codes for itnew Ignitornew CASnew ECUgrounding systemnew TPS
Any thoughts? Anyone? Im about to light it on fire and claim insurance on a stock 240.
