the pics or the cluster ?Carl H wrote:
old pics of my s13 with the gts-t cluster, pita to make work imho.
12hrs to rewire a cluster wtf?you have to be straight up retarded to do that, i did mine in about an hour and a half...POOPmouth wrote:i dont know about thatmaybe- i v talked with the owner of that carand asked him what he did -
used both 240sx cluster dohc wiring dygramand r32 gst clust dygram - said it took him like 12hrs as for speedometer - he used an electric one - im in process of looking for all info needed to do it - then ill do a write up to be contunied
Might have been a pita but wow, it looks so nice compared to the stock one. I'm hoping that someone comes up with a writeup soon .Carl H wrote:
sorry i didnt do a write upwhen i did it. its a r33 cluster by the way. i just sat there and followed the wires in the back. not that hard but pretty time consuming. the wiring from the s13 to rb cluster is not close. it would also help if you have the pig tails from the rb cluster.Tictakman wrote:240slide- did you ever do a write up on how to install that rb gauge cluster? would you mind telling me how to wire it up? is that a r32 cluster?
i wonder how close in color matching the wires are between the s13 and s14?
thanks,
Zak
The wires don't match color wize at all. unless just by chance one out of the 30 or so wires does.Tictakman wrote:240slide- did you ever do a write up on how to install that rb gauge cluster? would you mind telling me how to wire it up? is that a r32 cluster?
thanks,
Zak
More or less, you need an R33 wiring chart, S13 wiring chart, and an S14 wiring chart. Use your guide and edit the S14 info and convert to S13. A simple, 3-step process! *ducks* But seriously, is that the logical thought process? I do happen to already posess the R33 FSM & S13 FSM, so I would assume the S14 would not be hard to get as well. I just havent looked since, well, I do not own an S14.300Plus wrote:The wires don't match color wize at all. unless just by chance one out of the 30 or so wires does.
