You won't get a better power band, you will just shift the powerband up in the RPMs. For example, instead of having your stock power band from 3000-6000, it will be more like 5000-8500. Remember, big cams = loss of low end. I had HKS 272's on my eclipse and my spool on my turbo went from 3200 to almost 4200. But it pulled ridiculously around 7k rpms.OmarM wrote:I am going to be getting my motor rebuilt soon, so I will have machine shop install upgraded valve springs, then when I get the motor broken in and new injectors, etc sorted out, I will look at installing cams to get a better power band at lower levels of boost.
The DSM guys used to run a 264/272 combo. It solved the lumpy idle and kept some of the low-end torque. But if you ever got to the point where you were using a sheet metal intake or anything like that, the less aggressive intake cam may be a restriction. There is a set of HKS 264's on ebay right now that I REALLY want to buy. Too bad I am broke now.tyrannix wrote:im just checking my knowledge here, but if you do 260 on the intake and 270 on teh exhaust, wont that retain some of the midrange? but still move the powerband up with. (with more lift having more air go in&out of the turbo so faster spool?)
or am i all *** backwards
If you want good power at lower rpm levels, you better stick with what you got or get a 256 degree camshaft pair. The 10.25mm lift camshaft is a bit of work and will require an extra bit of work to the head as well. If you're trying to get 300-400whp, go invest your money in a decent engine management system before you start screwing with the engine. The stock engine is capable of holding up to more boost and power than you guy care to imagine.OmarM wrote:iliketocrash, yeah I am planning on getting the cam gears if i go with the Procams. There was a deal to good to pass up on ebay but they were for Tomei Procams with 10.25m lift. That would require solid lifters and is too involved fo me.
Something's gotta give here guys! You want a decent idle and you want good power, right? Stick with 260ish camshaft and stray away from the 270+stuff. But if you must have it, I have a set of camshafts that are 276 with an 11.45mm lift on the intake and 268 with a 11.35mm lift on the exhaust side that will make you spend more money just to get them into your head. The point I'm trying to make is, learn the engine before you go dumping money into areas that are not uber important. If you're not going to have a drag machine or a dyno queen, then huge cams are a waste. One of my engines are outfitted in JUN gear from solid lifters to 272 cams with a 10.5mm lift and it wasn't cheap by a long shot. This is engine has one purpose, dyno and drag (Never on the street).tyrannix wrote:well... a CPC is close enough (just sent him the measurements for a q45 TB for it) ... maybe ill just have to get 2 sets of cams and play with thembut i would like to have a decent idle .. looking like ill start with 260/270 and play with that for awhile then get another 270 for the intake and compare
boost_boy wrote:Something's gotta give here guys! You want a decent idle and you want good power, right? Stick with 260ish camshaft and stray away from the 270+stuff. But if you must have it, I have a set of camshafts that are 276 with an 11.45mm lift on the intake and 268 with a 11.35mm lift on the exhaust side that will make you spend more money just to get them into your head. The point I'm trying to make is, learn the engine before you go dumping money into areas that are not uber important. If you're not going to have a drag machine or a dyno queen, then huge cams are a waste. One of my engines are outfitted in JUN gear from solid lifters to 272 cams with a 10.5mm lift and it wasn't cheap by a long shot. This is engine has one purpose, dyno and drag (Never on the street).
dee
float_6969 wrote:I'm kinda with Dee on this one. If you talk to the UK guys, they pretty much say that unless you plan on 350hp+ (IIRC) the stock cams are actually your best bet.
I'm putting myself in harm's way with this one, but those little honda tuning books you find at high performance stores or ebay or whatever, are very useful in understanding functionality of a high performance engine. There's a gang of books out there with experts sharing their theories and facts, upto and including the laws of physics. I'm no physics major and I sure as hell don't gig at Roush racing, but everything that I've learned about high performance engines and their operations bled into my love for the CA series engnine. And with that said, I wasn't afraid to pick-up a Haynes or Chilton manual for reference and nor was I afraid to ask for advice or take constructive criticism.tyrannix wrote:besides trial and error and straight experience, where would you suggest somone start? (no sarcasm here)im trying to expand my knowledge and engine/turbo theory any good books or fact sites you would reccommend over others?
(with theory like how different lifts or durations on intake or exhaust effect airflow/power/powerband potential .. or like smaller turbines = faster spool but less max airflow?)
ive read Mike Kojimas articles, not his book(s) tho
Understood and we'll be here (If god permits) to help you in anyway possible.tyrannix wrote:ill see if i can grab one while im out today (picking up the ca20)and i dont want to build teh frankenstein engine just to make power, i want the experience. i just like building things, i think one of the best ways i can spend my free time is building an engine.... the only problem, again is that ive only been doing the fast car thing for about 1.5 years now (since i happened to get the silvia while i was in oki and i got hooked, hard)
i dont just want 400+whp, i really want 400+usable Wft/lbs over a bunch of the powerband. ... if i have an engine capable of like 500-600 peak whp, then i should be able to tune it to less peak, and wider powerband
the eventual goal is to have an entirely custom drivetrain, i actually just ordered the enjuku aluminum driveshaft (rated for 800 ft/lbs) and at some point after my car is running, i will get halfshafts and build a transmission to match that capability
with the CA20, i want to put together what i think will make power, get it to run, then play with variables to see what makes even bigger numbers until i get it to where i want it (for circuit/road racing)but thats where you guys and other sources come in, so i can make those decisions on what parts to use so they work together and not have any big bottlenecks in power
i iknow as a driver i cant handle that much power, i wanted to just rebuild my silvia, then make it hoss ... thats why i got a corolla. to practise my skills (and it gets great mileage too)
of course those numbers are a bit arbitrary to me, as ive never driven a 400 whp car before (been in a few skylines and a supra that were probably close tho)
but if you/i/whoever can do 400 whp with a stock engine, then i should be able to get more with more displacement, right? (forced induction just multiplies the capability of the stock engine, right? )
i want to have fun building and tuning an engine with *stupid* power, but usable powerband and have it be somewhat streetable (if i can.. i may have to put this engine in another car ) but thats the direction im heading for now...
edit> and i am going to try the jb weld -> smaller intake ports on the 4port euro head thats coming in (mototuneusa).com and see if that gains me anything
Modified by tyrannix at 12:43 PM 4/20/2006
boost_boy wrote:Understood and we'll be here (If god permits) to help you in anyway possible.
Off topic: What branch of service were you in? And where at in Oki were you based? I was on Camp Foster when I was stationed there.
Dee
Dee
Outstanding "Devil Dog"........I was with HQ Battery 4/12 HQ company when I was on Okinawa. I was sent to Tripler Army Medical Center in Hawaii for surgery and after surgery, I was attached to Marine Barracks Pearl Harbor HQ company, after which I was later medically retired after 5.5 years of faithful service. But my love for the CA came when I was stationed on Okinawa when I saw CA16DE powered 1986 nissan sunny at a car lot not too far from the Naval hospital outside of camp foster. Semper Fidelis leatherneck . Now let's get back to car businiess. How much more do you have to go on your CA20 thinga-majiggy?tyrannix wrote:i was with HQ for 3div (USMC) on Camp Courtneyim at the mountain warfare training center in california now (it might as well be nevada, its about 10 minutes to the border, and theres really nothing within normal driving distance in california, except maybe sacramento in summer (the pass is closed most of winter)
CJ
