Sounds like Maxnix is getting feeling up his Q.... groping under the plenum... "So soft, so supple!"maxnix wrote:Without any maintenance history, it is very difficult to comment.
Have you established all your vacuum hoses are intact, soft and supple, and not brittle?
Just in case he doesn't........... '94 Q45 FSM http://phatg20.net/modules.php...d=203squeefoo wrote:Check your Throttle Position Sensor. Did you move it to put the injectors in ? Check connectors for corrosion?Do you have an FSM? Ohmmeter?
We need more concise info to help...
.. actually I pulled the plenum as I had like 7 bad total to replace. I have an OHM meter also but just seems odd as like it ran good before and runs good 1/2 the time now I have no idea whats up. Where's the valve and bypass located at? Thanksmaxnix wrote:Without any maintenance history, it is very difficult to comment.
silverQ wrote:.. actually I pulled the plenum as I had like 7 bad total to replace. I have an OHM meter also but just seems odd as like it ran good before and runs good 1/2 the time now I have no idea whats up. Where's the valve and bypass located at? Thanks
Its less than 40 megs.anlasak wrote: '94 Q45 FSM http://phatg20.net/modules.php...d=203
Excellent! I really glad you wrote back and told us this.silverQ wrote:Hello giving update with a fix for the problem.
When I originally removed the plenum to replace some injectors and then
reinstalled the plenum the small coolant hose running to the idle cam assy
(uses thermal wax to control idle) was kinked causing the high
idle. All is now well ..
