PCV Valve
Information on the naturally-aspirated KA24E and KA24DE engines.
zoom_zoom240
Car: 95 240sx
I was wondering where is the PCV Valve located on the engine. I asked the technicians that I work with but they cant find it either.
onosqv
Car: '92 240sx Vert
for sohc or dohc?
sohc is easy - right between the fuel rail and throttle body - there is a 3/8" inner diameter hose going to the TB, the pcv valve is right there.
on the dohc, it is hidden on the bottom side of the intake mani.
If you search, you'll find the answer .
240crawler
Car: 1991 240sx
On the DOHC, the PCV is in an awful place to get to.
slydin'240
Car: 1993 240sx Coupe, 2003 Maxima SE
This will help, it helped me.http://www.240sx.org/faq/index.html
Red coupe
Car: 92 Nissan 240sx Coupe
like the said, you can barely see it on the back left side of the engine (when standing in front of the car looking at the bay)
Also the FSM does a good job of giving the general locations of the emissions controls...
dj4u2no
Car: STOCK 93 240SX
How important is it to change the PCV valve anyways....is it really worth removing the alternator? My oil does get dark rather quickly, but will a new pcv really be worth the time and effort?
onosqv
Car: '92 240sx Vert
dj4u2no wrote:How important is it to change the PCV valve anyways....is it really worth removing the alternator? My oil does get dark rather quickly, but will a new pcv really be worth the time and effort?
Unless it's directly causing any trouble, it's not that important. I'd replace it as part of a maintenance routine when working around that area.
It depends on what you consider being "worth the time and effort." If the pcv fail and cause all sorts of madness - idling issues, stumbling, etc. It may be hard to trace it down to the PCV (if it's the cause) bcs there are so many diff things that could be it.
If you replace it before it goes bad, then you have the peace of mind that it should be fine for another 100k+ miles.
hkssupratt1994
Car: 92 240sx hatch
i was tuning up my car and i bought one and i couldnt find the bastard so i gave up.my idle started get a little high latey so im going to try to change it its behind the alternator right?
nymphoprkinglot
Car: 96 Alpine White S14
i know this is old, i found the valve and can get to it, but has anyone had the problem of it being on so effing tight you can remove it for the life of you?
BadMojo
Car: 2007 Mazdaspeed 3
nymphoprkinglot wrote:i know this is old, i found the valve and can get to it, but has anyone had the problem of it being on so effing tight you can remove it for the life of you?
PB Blaster or some other penetrant oil?
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
mine was tighter than my first girlfriend, its a pain to change it.
Return to “KA24E / KA24DE Forum”
