DominickJ30
1993 Infiniti J30t
Chicago IL
1-18-2005
| « Re: Moonroof gasket seal weatherstripping ...whatever, how to replace (Augy) | 6:21 PM 2/20/2006 |
You have to remove the whole sunroof assembly, have fun.I think driverdriver will chime in with instructions on how to do it exactly.
93 J30tMy SoundDomain Page
Gerardjg
1995 J30t & 1997 J30
Deltona Fl
1-24-2006
| « Re: Moonroof gasket seal weatherstripping ...whatever, how to replace (Augy) | 2:08 AM 2/21/2006 |
This is on my list of things to do, here is a link with instructions. http://www.fuzzycats.com/docs/sunroof_repair.pdf
Augy
2-18-2006
| « Re: Moonroof gasket seal weatherstripping ...whatever, how to replace (Gerardjg) | 4:27 AM 2/21/2006 |
Thanks for the link. Looks like a real PITA but pretty straight-forward. Anyone know how long this should take? What does the dealership charge in hours?
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
| « Re: Moonroof gasket seal weatherstripping ...whatever, how to replace (Augy) | 6:21 AM 2/21/2006 |
Dealer would take a long time, at least 8 billable hours. Id just do it at home over a weekend...  Just think, at least it wont leave the car incapacitated in case you have to go somewhere.... Most delicate part is going to be taking the headliner down without destroying clips... it can be done, but look at it this way, the dealer is going to be less concerned about being careful, just getting it done as fast as possible.
SHIFT_it yourself
 1994 Q45t- 5 Speed The Infiniti Q45 Resource, Q45.org | Nissan VH series website NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328
driverdriver
NICO's longtime resident Canuck!!!
Toronto, Canada
8-1-2003
I did it myself a few years ago. Be patient and take your time with the headliner, you don't want any clips to break. I think it took me a whole Saturday.Its pretty straightforward to do. Just long and tedious.
Currently in the Garage: Daily Driver: Acura EL Daily Driver: Saab 9-5 2.3t Aero Sportwagon Spring/Summer/Fall Screamer: '94 Infiniti J30t gold package w/HICAS (10+ years of ownership and she still looks&runs like day one!!!)
Augy
2-18-2006
After reading through this procedure I'm wondering if I actually HAVE to completely remove the sunroof assembly just to change the weatherstripping. It almost looks like you can detatch the interior panel (part covered in the same material as the headliner), slide it back, and gain access to 4 of the 6 bolts holding the "lid" to the sunroof assembly. Not sure if you can do this and even if you could I'm not certain you can access the remaing 2 bolts. Has anyone ever replaced just the weatherstripping and, if so, did you have to remove the whole assembly to do so?I'm pretty sure I'm not going to like the answer
driverdriver
Toronto, Canada
8-1-2003
The rail assembly needs to be out of the way for you to properly access the sunroof lid in order to remove the old weatherstripping and affix the new one. Don't roll back the headliner or lining material, it will crease badly-I think this has something to do with age of the material. In my experience, I didn't remove the backseat, I did remove the front seats and tarped the back seat with painters drop cloth. It is a little harder to remove the headliner from its rear clips but not impossible. It helps if you have an assistant for some of this work. I paid a few buddies with beers and a BBQ. It helped that one was a mechanic and the other an engineer. These guys are creative in solving problems on "the fly". The most important advice is to be patient when doing this work. Get rid of any distractions (i.e. wife, girlfriend, etc) - I sent my wife (and my buddies did the same) to a spa downtown for the day, so we could work in peace.
DominickJ30
1993 Infiniti J30t
Chicago IL
1-18-2005
| « Re: (driverdriver) | 12:24 PM 2/21/2006 |
The biggest pain is just getting the headliner OUT of the car, I did this with all my seats in but I slightly bent it and there is a small crease now, not a biggie.I would recommend at least removing the passanger seat tho.
Augy
2-18-2006
Thanks for all the replies and advice. I think I'll wait for a little warmer weekend (I'm in Iowa) to tackle this project. My neighbor, who works for beers, suggested the obvious in that I won't be using the sunroof for a few months anyway  I guess I'll have plenty of time to really read and re-read the TSB on this so I am fully confident I can get 1/2 way through it before the beer-fridge gets opened
carlos_knology
1995 Infiniti J30
Columbus, GA
7-25-2002
| « Re: Moonroof gasket seal weatherstripping ...whatever, how to replace (Augy) | 8:41 PM 2/24/2006 |
Hey guys, long time since I've gotten on here. You CAN remove the lid without having to take everything apart... headliner, etc.Here's what you do... Open sunroof about half-way. You want to open it just enough to fit your head in the opening. Kneel on the driver seat (facing rear of car) and look between the outer lid (the outer metal part) and the felt lined part. On the right and left sides, you'll see two black spring loaded plastic clips that you have to unhook. I used a couple putty-knives for this. The trick is to push the felt liner towards the back of the car as you pull up on the spring loaded clips. Basically you're trying to separate the liner from the sunroof lid to expose the six bolts that attach the lid to the sunroof rail. Anyway, as the felt-lined half starts to slide back close the sunroof a little more, this will allow the felt piece to slide further. You'll need to keep doing this until the sunroof is completely closed and the felt liner half is basically slid all the way back. Don't worry, it can't slide too far back (there's a metal bracket in the back of the assembly that keeps the felt from going too far back). Anyway, once the 6 bolts are exposed, you can easily remove the lid and replace the seal/weatherstipping. Put the lid back on and reattach the 6 bolts. Once finished, open the lid all the way. Opening the lid all the way will make the metal lid slip back over the felt-lined half and you'll hear the spring-loaded clips re-engage. Close the sunroof and both halves will close like the always have. Good luck.
Augy
2-18-2006
| « Re: Moonroof gasket seal weatherstripping .. ... (carlos_knology) | 1:53 PM 2/26/2006 |
Yep, carlos_knology was right. I just did this and it took all of a half-hour to get the lid removed. That was with 15 minutes trying to figure out exactly what clips needed to be lifted to allow the liner cover to move back.I was looking for a spring-clip but that isn't what it was. Rather, it's a lever type device witha spring on it to hold it down. Once I figured out what needed to move, it was very simple. I just installed the new weather-stripping and am waiting for the silicone to dry enough to put the lid back on. Thanks for all the help and a special thanks to carlos...his post saved me an entire day and who knows how much headache!
carlos_knology
1995 Infiniti J30
Columbus, GA
7-25-2002
| « Re: Moonroof gasket seal weatherstripping .. ... (Augy) | 5:50 PM 2/26/2006 |
Awesome news. Glad to hear it worked out for you.
elwesso
Super Moderator
2-23-2003
| « Re: Moonroof gasket seal weatherstripping .. ... (carlos_knology) | 12:26 PM 2/27/2006 |
Great info!!
rdorman
1995 j30
columbus ohio
7-27-2006
I just used Carlos method and it worked perfectly. Entire job took about 1 hour.
yodawill2000
Online
94 Infinti J30
Grand Prairie Tx
3-24-2005
His website has been a blessing for me !!! Just wish he would change the Tie rod link to tension rod !!! LOL I sent you an email about that moons ago Carlos.
94 J30 w/180 K miles Dark green and sexah !!!
emdeee
Infiniti J30t
Toronto ON
4-7-2007
| « Re: (yodawill2000) | 10:38 PM 4/7/2007 |
Hey guys, I was having problems with my sunroof seal as well but I was too lazy to buy a new one and go through the whole ordeal. It was at a stage where there was a little bit of water leaking when I would go through car washes etc. but rain wouldn't come in. I just pushed up the seal from the sides what it was come off from and used a resin epoxy (super glue) mixture and mader it a permenant seal. Now there's no water entering and the rusty parts are hidden and covered nicley too. There is still a gap between the liner at the rear side of the sunroof but I am just going to fill it up with a clear sillicon paste which is removable anytime and will fill up the gap nicely. All the posts were very nice though. Was good to learn various techniques!
[IMG][/IMG]
suren
Austin Tx
4-27-2003
| « Re: Moonroof gasket seal weatherstripping .. ... (Augy) | 1:03 PM 4/8/2007 |
where did you bought the part and what did you pay. Since it it simpler to install, now I want to change gasket also. Thanks.
jamesmost
"95Qmodded, M30 Conv. both in minty, 1986 MB 560sec
Strong Island NY
7-8-2003
| « Re: Moonroof gasket seal weatherstripping .. ... (carlos_knology) | 1:28 PM 8/8/2007 |
| Quote, originally posted by carlos_knology » | | Hey guys, long time since I've gotten on here. You CAN remove the lid without having to take everything apart... headliner, etc. Here's what you do... Open sunroof about half-way. You want to open it just enough to fit your head in the opening. Kneel on the driver seat (facing rear of car) and look between the outer lid (the outer metal part) and the felt lined part. On the right and left sides, you'll see two black spring loaded plastic clips that you have to unhook. I used a couple putty-knives for this. The trick is to push the felt liner towards the back of the car as you pull up on the spring loaded clips. Basically you're trying to separate the liner from the sunroof lid to expose the six bolts that attach the lid to the sunroof rail. Anyway, as the felt-lined half starts to slide back close the sunroof a little more, this will allow the felt piece to slide further. You'll need to keep doing this until the sunroof is completely closed and the felt liner half is basically slid all the way back. Don't worry, it can't slide too far back (there's a metal bracket in the back of the assembly that keeps the felt from going too far back). Anyway, once the 6 bolts are exposed, you can easily remove the lid and replace the seal/weatherstipping. Put the lid back on and reattach the 6 bolts. Once finished, open the lid all the way. Opening the lid all the way will make the metal lid slip back over the felt-lined half and you'll hear the spring-loaded clips re-engage. Close the sunroof and both halves will close like the always have. Good luck. |
LETS STICKY THIS IN THE DIY I attacked my seal this morning \ bty MONSOON outside tilted the roof up and started pulling, next thing i know im in overmy head and my roof is stuck half open and had to cut part of the gasket off to un stuck it. Turn to my old friend NICO and SEARCH I find this thread and start reading , Guess im not going to work today and sweating like a pig for 8 HOURS while destroying my head liner. Then i find this post, whammo 30 minutes later new seal instaled. Love it. Sticky it up
95Q w/TCS-Tokico blues w/Eibachs, 20mm rear sway bar, NICO switcher ecu,JWT tcu, Stock Air Box, solid urathane sub frame & sway bar bushings, Stillen upper control arms rear, SPL's front, Stillen strut tower brace, BBS-RK rims - 245/45/WR17 95W - Yokahama a/s, Stillen adjustable tension rods, all urathane bushings, Hella HID headlights & driving lights, t-spoiler, Stillen 2.5" cat back exhaust (removed the 2 cans under the car, lower cats & gutted uppers), B&M trans cooler, SS braided brake lines, Power Slots w/Hawk HPS pads. 91 transmission w/performance rebuild, 2,800 stall Billet Dragon torque convertor, additional clutches, cranked up pressure solenoid, crosshatched clutches & shift kit. Powertrain industries driveshaft. Timing advance to 17. JDM motor installed w/45k miles. Body freshly painted,JDM clear lenses,all rear plastic smoked out w/35% film, windows tinted, GTR32 rear 4.08 gear synthetic fluids
geauxapl
1993 and 2000 Infiniti Q45
Kenner LA
9-6-2007
| « Re: Moonroof gasket seal weatherstripping .. ... (jamesmost) | 12:45 PM 9/12/2007 |
Great info - just what I needed to replace the seal. Thanks!!
